性能参数:Functional Parameters:
产品简介:Product introduction:
祈飞网络安全平台具有稳定的性能和人性化设计,专为应用开发商、系统集成商和服务提供商设计,以提供网络连接的安全性,是最为经济实用的优质产品。
Pray fly’s Network Security Platform with suitable performance and humanity design, specialized for application developers, system integrators and service providers designed to provide the security of network connections. It is the most economical and practical quality products.
产品规格:Product specifications:
◆ 结构:重型钢箱体
Structure: heavy steel box
◆ 前面板:豪华铝面板
The front panel: luxury aluminum panels
◆ 电源:750W工业电源或冗余电源可选
Power supply: 750W Industrial power supplies or redundant power optional
◆ 驱动器空间:3个3.5″空间、2个5.25″空间
Disk drive housing: Three 3.5 "space or two 5.25" space
◆ 通风系统:2个80mm内置风扇
Ventilation systems: two 80-mm fan
◆ 扩展空间:可扩展12个内置式PCI槽
Expansion space: twelve scalable built-in PCI slot
◆ 网口位置:后置网口
LAN Location: Post-mouth network
◆ 主板说明:P4全长卡 Mother board introduction:P4 Full-length cards
物理参数Physical parameters
◆ 外形尺寸: 483mm(L)×267mm(W)×460mm(H) Dimensions: 483mm(L)×267mm(W)×460mm(H)
◆ 工作温度:0℃~50℃ Operating temperature: 0℃~50℃
◆ 储存温度:-20℃~70℃ Storage temperature: -20℃~70℃
◆ 相对湿度:0 ~ 90%, 无冷凝 Relative humidity: 0 ~ 90%,none-condensing
◆ 抗冲击:10G峰-峰加速度(11ms) Shock: 10G peak to peak acceleration(11ms)
◆ 抗震动:5-17Hz,0.1〞双峰位移;17-640Hz,1.5G峰-峰加速度
Vibration: 5-17Hz, 0.1″double-amplitude displacement 1.5G peak to peak
◆ 电磁干扰:符合FCC/VDE A级标准
EMI: comply with FCC / VDE A standard
应用行业: 网络安全、DVR、电力、交通、工业自动化、制造业、气象监测等
Application: network security, DVR, electricity, transportation, industrial automation, manufacturing, meteorological monitoring etc.
选型参考:Selection guide
