| 产品名称: |
通用目的压电加速度传感器
| 型 号: |
| 价 格: |
| 品 牌: |
产品介绍: |
| Model |
灵敏度mV/g |
误差范围±% |
频率响应范围±3dB Hz |
谐振频率kHz |
温度范围℃ |
重量grams |
激励电压VDC/mA |
线性极限g |
冲击极限g |
输出方式 |
安装方式 |
连接头 |
| 782A |
100 |
15 |
0.7-12000 |
30 |
-50 - 120 |
90 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| 788A |
100 |
10 |
1.5-12000 |
25 |
-50 - 120 |
45 |
18-30/2-10 |
50 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| 793 |
100 |
5 |
0.5-15000 |
25 |
-50 - 120 |
112 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| ED-793 |
100 |
5 |
0.5-15000 |
25 |
-50 - 120 |
112 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| 797 |
100 |
5 |
0.1-12000 |
26 |
-50 - 120 |
135 |
18-30/2-10 |
50 |
5000 |
side |
中心通孔,1/4-28 |
2 pin MIL-C-5015 |
| ED-797 |
100 |
5 |
0.1-12000 |
26 |
-50 - 120 |
135 |
18-30/2-10 |
50 |
5000 |
side |
中心通孔,1/4-28 |
2 pin MIL-C-5015 |
| ED-797L |
500 |
5 |
0.2-3700 |
18 |
-50 - 120 |
153 |
18-30/2-10 |
10 |
2500 |
side |
中心通孔,1/4-28 |
2 pin MIL-C-5015 |
| 786A |
100 |
5 |
0.5-14000 |
30 |
-50 - 120 |
90 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| ED-786A |
100 |
5 |
0.5-14000 |
30 |
-50 - 120 |
90 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| 786F |
100 |
5 |
0.5-13000 |
30 |
-50 - 120 |
90 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
集成电缆 |
| 777/777B |
100 |
10 |
0.5-12000 |
30 |
-50 - 85 |
75 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
接线端/BNC |
| 787A |
100 |
10 |
0.5-10000 |
22 |
-50 - 120 |
145 |
18-30/2-10 |
80 |
5000 |
side |
中心通孔,1/4-28 |
2 pin MIL-C-5015 |
| 787F |
100 |
10 |
0.7-10000 |
22 |
-50 - 120 |
145 |
18-30/2-10 |
80 |
5000 |
side |
中心通孔,1/4-28 |
集成电缆 |
| ED-787A |
100 |
10 |
0.5-10000 |
22 |
-50 - 120 |
150 |
18-30/2-10 |
80 |
5000 |
side |
中心通孔,1/4-28 |
2 pin MIL-C-5015 |
| 784A |
100 |
20 |
2.0-10000 |
25 |
-50 - 120 |
45 |
18-30/2-10 |
50 |
5000 |
top |
中心通孔,1/4-28 |
2 pin MIL-C-5015 |
| 785A |
100 |
10 |
1.0-12000 |
30 |
-50 - 120 |
85 |
18-30/2-10 |
80 |
5000 |
side |
1/4-28孔 |
2 pin MIL-C-5015 |
| 775A |
100 |
20 |
0.5-10000 |
26 |
-50 - 80 |
45 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
集成电缆 |
| S100C |
100 |
20 |
0.5-10000 |
30 |
-50 - 80 |
28 |
18-30/2-10 |
80 |
5000 |
top |
粘贴安转 |
特殊 |
| S100CS |
100 |
20 |
0.5-10000 |
26 |
-50 - 80 |
45 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
特殊 |
| 712F |
100 |
10 |
3.0-25000 |
45 |
-50 - 120 |
35 |
18-30/2-10 |
60 |
5000 |
side |
中心通孔,8-32 |
集成电缆 |
| 732A |
10 |
5 |
0.5-25000 |
60 |
-50 - 120 |
13 |
18-30/2-10 |
500 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 732AT |
10 |
5 |
0.5-25000 |
60 |
-50 - 120 |
13 |
18-30/2-10 |
500 |
5000 |
top |
10-32孔 |
10-32 coaxial |
| 736 |
100 |
5 |
2.0-25000 |
60 |
-50 - 120 |
13 |
18-30/2-10 |
50 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 736T |
100 |
5 |
2.0-25000 |
60 |
-50 - 120 |
13 |
18-30/2-10 |
50 |
5000 |
top |
10-32孔 |
10-32 coaxial |
| 793L |
500 |
5 |
0.2-2300 |
15 |
-50 - 120 |
142 |
18-30/2-10 |
10 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| 797L |
500 |
5 |
0.2-3700 |
18 |
-50 - 120 |
148 |
18-30/2-10 |
10 |
5000 |
side |
1/4-28孔 |
2 pin MIL-C-5015 |
| 799LF |
500 |
5 |
0.1-2500 |
18 |
-50 - 120 |
204 |
18-30/2-10 |
10 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| 799M |
1000 |
5 |
0.2-2500 |
18 |
-50 - 120 |
205 |
18-30/2-10 |
5 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| 991D |
40 |
5 |
0.2-12000 |
20 |
-50 - 120 |
54 |
9/# |
40 |
1000 |
top |
1/4-28孔 |
3 pin MIL-C-26482 |
| 992-1 |
10 |
10 |
2-20000 |
35 |
-35 - 100 |
45 |
8±1.5/# |
500 |
10000 |
top |
1/4-28孔 |
PC01A-8-4P |
| 731-207 |
10000 |
10 |
0.2-1300 |
2.4 |
0-80 |
50 |
18-30/2-10 |
.5 |
250 |
top |
10-32孔 |
10-32 coaxial |
| 731A |
10000 |
10 |
0.05-500 |
.815 |
-10-65 |
670 |
.5 |
10 |
top |
3/8-16孔 |
2 pin MIL-C-5015 |
| 731A/P31system |
0.05-450 |
-10-65 |
670 |
P31供电 |
.5 |
10 |
top |
3/8-16孔 |
2 pin |
| 222A |
100 |
10 |
0.5-8500 |
23 |
-50 - 120 |
76 |
18-30/2-10 |
80 |
5000 |
top |
集成安装螺母1/8-27 |
1 pin |
| 221A |
100 |
20 |
0.5-7000 |
13 |
-50-80 |
53 |
18-30/2-10 |
80 |
5000 |
top |
集成安装螺母1/4-28 |
1 pin |
| 221B |
100 |
20 |
0.5-10000 |
13 |
-50-80 |
53 |
18-30/2-10 |
80 |
5000 |
top |
集成安装螺母1/4-28 |
1 pin |
| 996LD |
12000 |
10-4000 |
14 |
-10-80 |
12-24/2 |
.1 |
10000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| 746 |
100 |
5 |
1-15000 |
30 |
-50-80 |
45 |
18-30/2-10 |
50 |
5000 |
top |
10-32孔 |
集成电缆 |
| 746F-1 |
40 |
5 |
1-10000 |
20 |
-50-80 |
45 |
7-10/# |
50 |
5000 |
top |
10-32孔 |
集成电缆 |
| 754 |
10 |
2-25000 |
60 |
-20-90 |
4 |
18-30/2-5 |
250 |
5000 |
side |
粘贴安装 |
集成电缆 |
| 757 |
100 |
10 |
2-2000 |
-50-80 |
110 |
18-30/2-10 |
50 |
5000 |
side |
两缺口式10-32螺母 |
集成电缆 |
| AC102 |
100 |
10 |
0.5-15000 |
23 |
-50 - 121 |
90 |
18-30/2-10 |
50 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015或集成电缆 |
| AC104 |
100 |
10 |
0.5-10000 |
22 |
-50 - 121 |
145 |
18-30/2-10 |
50 |
5000 |
side |
中心通孔,1/4-28或M6 |
| AC117 |
50 |
10 |
1.0-12500 |
23 |
-50 - 121 |
90 |
18-30/2-10 |
100 |
5000 |
top |
1/4-28孔 |
| AC118 |
50 |
10 |
1.0-10000 |
21 |
-50 - 121 |
145 |
18-30/2-10 |
100 |
5000 |
side |
中心通孔,1/4-28或M6 |
| AC184 |
100 |
10 |
0.5-10000 |
20 |
-50 - 121 |
170 |
18-30/2-10 |
50 |
5000 |
side |
中心通孔,M8 |
| AC192 |
100 |
10 |
0.4-13000 |
26 |
-50 - 121 |
51 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| AC116 |
100 |
10 |
0.5-15000 |
22 |
-50 - 121 |
124 |
18-30/2-10 |
50 |
5000 |
side |
1/4-28集成安装螺母 |
2 pin MIL-C-5015 |
| AC216 |
100 |
10 |
0.5-15000 |
26 |
-50 - 121 |
90 |
18-30/2-10 |
80 |
5000 |
side |
1/4-28孔 |
2 pin MIL-C-5015 |
| AC220 |
10 |
5 |
1.5-25000 |
41 |
-50 - 121 |
20 |
18-30/2-10 |
500 |
5000 |
top |
1/4-28孔 |
| AC224 |
10 |
10 |
1.5-15000 |
38 |
-50 - 121 |
60 |
18-30/2-10 |
500 |
5000 |
side |
1/4-28孔 |
| AC131 |
10 |
10 |
1.2-15000 |
25 |
-50 - 121 |
90 |
18-30/2-10 |
500 |
5000 |
top |
1/4-28孔 |
| AC135 |
500 |
10 |
0.3-3000 |
12 |
-50 - 121 |
95 |
18-30/2-10 |
10 |
top |
1/4-28孔 |
| AC136 |
500 |
10 |
0.2-3000 |
12 |
-50 - 121 |
156 |
18-30/2-10 |
10 |
side |
1/4-28孔 |
| AC210 |
100 |
5 |
0.5-15000 |
26 |
-50 - 121 |
90 |
18-30/2-10 |
80 |
5000 |
top |
1/4-28孔 |
| AC211 |
100 |
5 |
0.5-10000 |
21 |
-50 - 121 |
145 |
18-30/2-10 |
80 |
5000 |
side |
1/4-28孔 |
| AC240 |
100 |
5 |
0.6-25000 |
34 |
-50 - 121 |
20 |
18-30/2-10 |
50 |
5000 |
top |
1/4-28孔 |
| AC244 |
100 |
5 |
0.6-15000 |
35 |
-50 - 121 |
60 |
18-30/2-10 |
50 |
5000 |
side |
1/4-28孔 |
| AC150 |
100 |
15 |
1.0-10000 |
23 |
-50 - 121 |
90 |
18-30/2-10 |
50 |
5000 |
top |
1/4-28孔 |
| AC140 |
100 |
15 |
0.5-15000 |
34 |
-50 - 121 |
20 |
18-30/2-10 |
50 |
5000 |
top |
1/4-28孔 |
| AC144 |
100 |
15 |
0.6-10000 |
35 |
-50 - 121 |
60 |
18-30/2-10 |
50 |
5000 |
side |
1/4-28孔 |
| AC901 |
10 |
10 |
1.2-15000 |
22 |
-54-125 |
90 |
18-28/2-4 |
500 |
5000 |
top |
1/4-28孔 |
| AC903 |
50 |
10 |
1.0-15000 |
22 |
-54-125 |
90 |
18-28/2-4 |
100 |
5000 |
top |
1/4-28孔 |
| AC904 |
50 |
10 |
1.0-10000 |
21 |
-54-125 |
150 |
18-28/2-4 |
100 |
5000 |
side |
中心通孔,1/4-28或M6 |
| AC905 |
100 |
10 |
0.5-15000 |
22 |
-54-125 |
90 |
18-28/2-4 |
50 |
5000 |
top |
1/4-28孔 |
| AC906 |
100 |
10 |
0.5-8600 |
21 |
-54-125 |
150 |
18-28/2-4 |
50 |
5000 |
side |
中心通孔,1/4-28或M6 |
| AC921 |
10 |
10 |
1.2-15000 |
25 |
-54-125 |
90 |
18-28/2-4 |
500 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| AC923 |
50 |
10 |
1.0-15000 |
25 |
-54-125 |
90 |
18-28/2-4 |
100 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| AC924 |
50 |
10 |
1.0-10000 |
22 |
-54-125 |
150 |
18-28/2-4 |
100 |
5000 |
side |
中心通孔,1/4-28或M6 |
2 pin MIL-C-5015 |
| AC925 |
100 |
10 |
0.5-15000 |
25 |
-54-125 |
90 |
18-28/2-4 |
50 |
5000 |
top |
1/4-28孔 |
2 pin MIL-C-5015 |
| AC926 |
100 |
10 |
0.5-8600 |
18 |
-54-125 |
150 |
18-28/2-4 |
50 |
5000 |
side |
中心通孔,1/4-28或M6 |
2 pin MIL-C-5015 |
| AC951 |
10 |
10 |
1.2-15000 |
25 |
-54-125 |
90 |
18-28/2-4 |
500 |
5000 |
top |
1/4-28孔 |
| AC953 |
50 |
10 |
1.0-15000 |
25 |
-54-125 |
90 |
18-28/2-4 |
100 |
5000 |
top |
1/4-28孔 |
| AC954 |
50 |
10 |
1.0-10000 |
22 |
-54-125 |
150 |
18-28/2-4 |
100 |
5000 |
side |
中心通孔,1/4-28或M6 |
| AC955 |
100 |
10 |
0.5-15000 |
25 |
-54-125 |
90 |
18-28/2-4 |
50 |
5000 |
top |
1/4-28孔 |
| AC956 |
100 |
10 |
0.5-8600 |
18 |
-54-125 |
150 |
18-28/2-4 |
50 |
5000 |
side |
中心通孔,1/4-28或M6 |
| 3006A |
100 |
10 |
0.16-20000 |
35 |
-51-121 |
12 |
18-30/2-20 |
50 |
3000 |
side |
10-32孔 |
集成电缆 |
| 3030B4 |
10 |
5 |
2-10000 |
30 |
-51-121 |
6.8 |
18-30/2-20 |
500 |
3000 |
top |
10-32集成螺母 |
10-32 coaxial |
| 3030B5 |
10 |
5 |
5-10000 |
30 |
-51-121 |
6.8 |
18-30/2-20 |
500 |
3000 |
top |
10-32集成螺母 |
10-32 coaxial |
| 3030B5H |
10 |
5 |
5-10000 |
30 |
-51-162 |
6.8 |
18-30/2-20 |
500 |
3000 |
top |
10-32集成螺母 |
10-32 coaxial |
| 3032A |
10 |
10 |
0.66-12000 |
80 |
-51-121 |
5.6 |
20-30/2-20 |
500 |
5100 |
side |
粘贴安装 |
集成电缆 |
| 3032A1 |
5 |
10 |
0.66-12000 |
80 |
-51-121 |
5.6 |
20-30/2-20 |
1000 |
2000 |
side |
粘贴安装 |
集成电缆 |
| 3035B |
100 |
10 |
0.5-10000 |
45 |
-51-121 |
2.5 |
18-30/2-20 |
50 |
3000 |
side |
5-40集成螺母 |
5-44 coaxial |
| 3035B1 |
10 |
10 |
0.5-10000 |
45 |
-51-121 |
2.5 |
18-30/2-20 |
500 |
3000 |
side |
5-40集成螺母 |
5-44 coaxial |
| 3035B1G |
10 |
10 |
0.5-10000 |
45 |
-51-121 |
2.5 |
18-30/2-20 |
500 |
3000 |
side |
粘贴安装 |
5-44 coaxial |
| 3035B2 |
50 |
10 |
0.5-10000 |
45 |
-51-121 |
2.5 |
18-30/2-20 |
100 |
3000 |
side |
5-40集成螺母 |
5-44 coaxial |
| 3035B2G |
50 |
10 |
0.5-10000 |
45 |
-51-121 |
2.5 |
18-30/2-20 |
100 |
3000 |
side |
粘贴安装 |
5-44 coaxial |
| 3035BG |
100 |
10 |
0.5-10000 |
45 |
-51-121 |
2.5 |
18-30/2-20 |
50 |
3000 |
side |
粘贴安装 |
5-44 coaxial |
| 3041A2 |
100 |
10 |
1.0-3000 |
25 |
-51-121 |
10 |
20-30/2-20 |
50 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3041A4 |
500 |
10 |
1.0-3000 |
25 |
-51-121 |
10 |
20-30/2-20 |
10 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3041A1 |
10 |
10 |
1.0-3000 |
25 |
-51-121 |
10 |
20-30/2-20 |
500 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3049E |
10 |
5 |
1.0-10000 |
35 |
-51-121 |
3.3 |
18-30/2-20 |
500 |
5000 |
top |
10-32集成螺母 |
10-32 coaxial |
| 3049E1 |
10 |
5 |
1.0-10000 |
35 |
-51-121 |
3.1 |
18-30/2-20 |
500 |
5000 |
top |
粘贴安装 |
10-32 coaxial |
| 3049E2 |
100 |
5 |
1.0-10000 |
35 |
-51-100 |
3.3 |
18-30/2-20 |
50 |
5000 |
top |
10-32集成螺母 |
10-32 coaxial |
| 3049E3 |
100 |
5 |
1.0-10000 |
35 |
-51-100 |
3.1 |
18-30/2-20 |
50 |
5000 |
top |
粘贴安装 |
10-32 coaxial |
| 3055B1 |
10 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
500 |
3000 |
side |
10-32孔 |
10-32 coaxial |
| 3055B1T |
10 |
5 |
1.0-10000 |
32 |
-40-85 |
8.6 |
18-30/2-20 |
500 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3055B2 |
100 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
50 |
2000 |
side |
10-32孔 |
10-32 coaxial |
| 3055B2T |
100 |
5 |
1.0-10000 |
32 |
-40-85 |
8.6 |
18-30/2-20 |
50 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3055B3 |
500 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
10 |
1000 |
side |
10-32孔 |
10-32 coaxial |
| 3055B3T |
500 |
5 |
1.0-10000 |
32 |
-40-85 |
8.6 |
18-30/2-20 |
10 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3055B4 |
50 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
100 |
2000 |
side |
10-32孔 |
10-32 coaxial |
| 3056B1 |
10 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
500 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B1T |
10 |
5 |
1.0-10000 |
32 |
-40-85 |
8.7 |
18-30/2-20 |
500 |
5000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B2 |
100 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
50 |
2000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B2T |
100 |
5 |
1.0-10000 |
32 |
-40-85 |
8.7 |
18-30/2-20 |
50 |
5000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B3 |
500 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
10 |
1000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B3T |
500 |
5 |
1.0-10000 |
32 |
-40-85 |
8.7 |
18-30/2-20 |
10 |
5000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B4 |
20 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
250 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B5 |
50 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
100 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B6 |
200 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
25 |
2000 |
top |
10-32孔 |
10-32 coaxial |
| 3056B7 |
5 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
1000 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3089A |
10 |
5 |
1.0-10000 |
50 |
-51-121 |
.6 |
18-30/2-20 |
500 |
3000 |
top |
粘贴安装 |
集成导线 |
| 3100D24 |
1000 |
5 |
1.0-1000 |
26 |
-51-121 |
55 |
18-30/2-20 |
5 |
200 |
side |
10-32孔 |
10-32 coaxial |
| 3145A |
100 |
10 |
0.5-10000 |
45 |
-51-148 |
2.3 |
18-30/2-20 |
50 |
3000 |
top |
5-40集成螺母 |
5-44 coaxial |
| 3145A1 |
10 |
10 |
0.5-10000 |
45 |
-51-148 |
2.3 |
18-30/2-20 |
500 |
3000 |
top |
5-40集成螺母 |
5-44 coaxial |
| 3145A1G |
10 |
10 |
0.5-10000 |
45 |
-51-148 |
2.1 |
18-30/2-20 |
500 |
3000 |
top |
粘贴安装 |
5-44 coaxial |
| 3145A2 |
5 |
10 |
0.5-10000 |
45 |
-51-148 |
2.3 |
18-30/2-20 |
1000 |
3000 |
top |
5-40集成螺母 |
5-44 coaxial |
| 3145A2G |
5 |
10 |
0.5-10000 |
45 |
-51-148 |
2.1 |
18-30/2-20 |
1000 |
3000 |
top |
粘贴安装 |
5-44 coaxial |
| 3145AG |
100 |
10 |
0.5-10000 |
45 |
-51-148 |
2.1 |
18-30/2-20 |
50 |
3000 |
top |
粘贴安装 |
5-44 coaxial |
| 3211A1 |
10 |
5 |
1.0-10000 |
38 |
-55-121 |
9.6 |
18-30/2-20 |
500 |
5000 |
side |
Φ9.2通孔 |
10-32 coaxial |
| 3211A2 |
100 |
5 |
1.0-10000 |
38 |
-55-121 |
9.6 |
18-30/2-20 |
50 |
5000 |
side |
Φ9.2通孔 |
10-32 coaxial |
| 3211M1 |
10 |
5 |
1.0-10000 |
38 |
-55-121 |
10 |
18-30/2-20 |
500 |
5000 |
side |
中心通孔,M4 |
集成电缆 |
| 3214A1 |
10 |
5 |
1.0-10000 |
35 |
-51-121 |
11 |
18-30/2-20 |
500 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3214A1T |
10 |
5 |
1.0-10000 |
35 |
-40-85 |
11 |
18-30/2-20 |
500 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3214A2 |
100 |
5 |
1.0-10000 |
35 |
-51-107 |
11 |
18-30/2-20 |
50 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3214A2T |
100 |
5 |
1.0-10000 |
35 |
-40-85 |
11 |
18-30/2-20 |
50 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3214A3 |
500 |
5 |
1.0-10000 |
35 |
-51-82 |
11 |
18-30/2-20 |
10 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3214A3T |
500 |
5 |
1.0-10000 |
35 |
-40-85 |
11 |
18-30/2-20 |
10 |
<, TD vAlign=center align=middle lass="text2" c,>5000
side |
10-32孔 |
10-32 coaxial |
| 3220E |
10 |
10 |
1.0-5000 |
35 |
-51-121 |
2.7 |
18-30/2-20 |
500 |
2000 |
side |
中心通孔,5-44 |
5-44 coaxial |
| 3224A2 |
2 |
10 |
2-10000 |
95 |
-51-148 |
.2 |
18-30/2-20 |
2500 |
5000 |
side |
粘贴安装 |
集成电缆 |
| 3225F |
10 |
1.6-10000 |
40 |
-51-121 |
.6 |
18-30/2-20 |
500 |
5000 |
side |
粘贴安装 |
集成电缆 |
| 3225F1 |
10 |
1.6-10000 |
40 |
-51-121 |
.6 |
18-30/2-20 |
500 |
5000 |
side |
粘贴安装 |
3-56 coaxial |
| 3225F1T |
10 |
1.6-10000 |
40 |
-51-121 |
.85 |
18-30/2-20 |
500 |
5000 |
side |
粘贴安装 |
3-56 coaxial |
| 3225F2 |
10 |
10 |
2.0-10000 |
40 |
-51-121 |
1 |
18-30/2-20 |
500 |
5000 |
side |
粘贴安装 |
3-56 coaxial |
| 3225M23 |
50 |
10 |
2.0-10000 |
40 |
-51-104 |
1 |
18-30/2-20 |
50 |
5000 |
side |
粘贴安装 |
3-56 coaxial |
| 3225M24 |
100 |
10 |
2.0-10000 |
40 |
-51-121 |
1 |
18-30/2-20 |
50 |
5000 |
side |
粘贴安装 |
3-56 coaxial |
| 3234A1 |
10 |
5 |
1.0-10000 |
35 |
-51-121 |
12 |
18-30/2-20 |
500 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3234A2 |
100 |
5 |
1.0-10000 |
35 |
-51-107 |
12 |
18-30/2-20 |
50 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3234A3 |
500 |
5 |
1.0-10000 |
35 |
-51-82 |
12 |
18-30/2-20 |
10 |
5000 |
side |
10-32孔 |
10-32 coaxial |
| 3255A1 |
10 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
500 |
3000 |
side |
10-32孔 |
10-32 coaxial |
| 3255A2 |
100 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
50 |
2000 |
side |
10-32孔 |
10-32 coaxial |
| 3255A3 |
500 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
10 |
1000 |
side |
10-32孔 |
10-32 coaxial |
| 3255A4 |
50 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
100 |
2000 |
side |
10-32孔 |
10-32 coaxial |
| 3255A6 |
200 |
5 |
1.0-10000 |
35 |
-51-121 |
10 |
18-30/2-20 |
25 |
2000 |
side |
10-32孔 |
10-32 coaxial |
| 3256A1 |
10 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
500 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A1T |
10 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
500 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A2 |
100 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
50 |
2000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A2T |
100 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
50 |
2000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A3 |
500 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
5 |
1000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A3T |
500 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
5 |
1000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A4 |
20 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
250 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A4T |
20 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
250 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A5 |
50 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
100 |
3000 |
top |
10-32孔 |
10-32 coaxial |
| 3256A5T |
50 |
5 |
1.0-10000 |
32 |
-51-121 |
10 |
18-30/2-20 |
100 |
3000 |
top |
10-32孔 |
10-32 coaxial |
