点击看-CMMB (STiMi)信号源 - CMG2000-大图
产品名称: CMMB (STiMi)信号源 - CMG2000
型  号: CMG2000
价  格:
CMG2000是一台多和一的全功能信号发生器,满足中国移动多媒体广播标准,其中有DTMB-TH和ADTB-T选件。通过高性能上变频技术,其能满足步长为1hz,50MHz--870MHz的频率范围。
Main Characteristics
  • China Mobile Multimedia Broadcasting Signal Generator
  • Modulator : CMMB
  • China MobileTV/DTV Integrated Test Solution support
    (DMB-TH, ADTB-T : Optional)
  • Time-Slot Setting (Max. 40)
  • Logical Channel Setting (Max. 40)
  • MFN Network mode support
  • AWGN/Fading Simulation (Optional)
General Characteristics
  • RF Upconverter : 50 ~870MHz
  • OFDM Modulation
  • PRBS Pattern Test (PRBS-9/ -15/ -23)
  • AWGN (support future)
  • Modulation Information
  • System Information
  • Frequency Information
  • Frequency Table support
  • TS List
Intended Application
  • CMMB receiver Design and Manufacturing Test
  • Simulation of CMMB Broadcasting
  • Broadcasting Transmission
     - CMMB Chip Development (Tuner/MPEG)
     - CMMB Demonstration & Sales
Modulator Specifications
CMMB Module
  • Broadcasting system
      - Digital Terrestrial TV : CMMB
  • Transmission Parameter
      - Modulation : OFDM
      - Support Mode : 4K
      - Constellations : BPSK, QPSK, 16QAM
      - Byte Interleave : Mode 1, Mode 2, Mode 3
      - RS Coding : RS(240,240);RS(240,224);
                            RS(240,192);RS(240,176)
      - Code Rate : ½, ¾, LDPC
      - Time Slots No. : 40
      - Bandwidth : 8MHz
      - Guard Interval : 1/8
DTMB(DMB-TH) Module (MM-506)
      - Digital Terrestrial TV  : DTMB(DMB-TH)
      - Modulation : TDS-OFDM
      - Constellations : 4QAM(QPSK), 16, 64QAM
      - Guard Interval : PN420, PN945
        (Frame Header)
      - Coding Rate : 0.4, 0.6, 0.8
      - Bandwidth : 5, 6, 7, 8
      - Time Interleaver : 240, 720
DTMB(ADTB-T) Module (MM-506)
      - Digital Terrestrial TV : ADTB-T
      - Constellations : 4QAM NR, 4QAM, 16QAM, 32QAM
      - Guard Interval  : PN420, PN595, PN945
        (Frame Header)
Function Options
AWGN Module(FM-203)
  • C/N range : 0 ~ +45dB
  • C/N resolution : 0.1 dB Steps
  • Noise Band Width : 0 ~ 10MHz
RF Specifications
  • Output Connector : N Type
  • RF Output Frequency : 50~870 MHz (VHF/UHF)
  • RF Frequency Resolution : 1Hz
  • Frequency Accuracy : 3 x 10-6 / 25 ℃
  • RF Power Level : -110 ~ 0dBm
  • RF Level Resolution : 0.1dB steps
  • RF Level Accuracy : ±0.5dB relative to the level at 18-33 ℃
  • RF Impedance : 50 Ω
General Specifications
  • Power supply : AC 100 to 250V, 50/60Hz
  • Power consumption : Less than 300W
  • Operating temperature : 10 to 40 ℃
  • Operating humidity : 20 to 85% RH (No Condensation)
  • Storage temperature : -40 to +70 ℃ / 20 ~ 85% RH
  • Operating environment : Indoor
  • Operating attitude : Around 2000m
  • Over-voltage category : II
  • Pollution degree : 2
  • Dimensions : 435(W) x 231.8(H) x 519.7(D) mm
  • Weight : Approx.17Kg (Not including options)
OS system
  • Embedded OS
User interface system
  • 10.4 inch TFT color LCD (1024 x 768)
  • Touch Screen
External Interface system
关 键 词:CMG2000, CMMB, CMMB信号源
公司名称: 嘉兆科技(深圳)有限公司
联 系 人: 余卫荣
电  话: 0755 83760007
传  真: 0755-83761816
地  址: (广东省)深圳市深南中路3007号国际科技大厦2001室
邮  编: 518033
主  页: http://www.corad.com.cn/
  • ISADAQ-CIO-DAS1402/12(CIO-DAS1402/12)
  • 嘉兆提供 WiMax基站终端产品(WiMax基带芯片)(WiMax)
  • GPS信号发生器(GPS)
  • 汽车传导抗扰度测试仪(-)
  • netmod - dtmb广播级调制器(DTMB)
  • USB 数字压电加速度传感器
  • dtmb实验室调制器(DTMB)
  • The CAST SIMCOM GPS 信号模拟仪(CAST)
  • Peak 功率计-8500A(8500A)
  • DASYLab-Basic(基本版)(Basic(基本版))
  • AL1301A单通道 高精度 高压光纤隔离放大器(AL1301A)
  • 便携式数字/地面国标信号射频/实时码流分析
    立 即 发 送 询 问 信 息
    深圳固迪 无线数传电台 GPRS数传模块 远端测控单元
    深圳友讯达 无线数传电台车载电台 对讲机 电力抄表系统
    深圳泰达鑫 无线数传电台 GPRS数传终端 数传模块
    深圳宏电 GPRS CDMA 无线DTU GPRS MODEM支持双频
    江阴宏信 无线DTU 短信产品 CDMA DTU GPRS DTU
    北京捷麦 无线数传电台 计数测频模块 GSM短信模块 模拟量测量模块 模拟量输出模块
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
