LabMod-DTMB is fully DTMB Chinese standard compliant (GB20600-2006), and offers several kinds of inputs (ASI or USB). It generates high quality RF or IF signals that will fit any test situation that may occur in a lab, research and development, or manufacturing site.
Remotely manageable thanks to an embedded HTTP web server, LabMod-DTMB modulator has a high set of features for RF or IF corner testing such as carriers cancellation, interleaver bypass, very large output level range, etc...
- FPGA based HW for robustness and reliability
- Over 40dB MER
- ASI and USB inputs
- RF output (VHF-UHF band) with very large output level range (-60 dBm to +2dBm)
- IF output (5 to 80MHz)
- MFN transmission capable(bit rate adaptation, PCR restamping capable)
- Special test modes(PRBS insertion, carriers removal, test tone, guard interval setup, white noise generation and C/N mastering)
- 10MHz input and output
- Modulation settings can be saved as Profile
- HTTP remote control
- Robust, forced cooling
- 19'''''''''''''''''''''''''''''''' rack mountable (1RU width)
