Main Features 15″TFT XGA LCD 集成 Intel ULV Celeron M 600 MHz / Pentium M 1.1-1.8Ghz处理器 最高支持 2 GB DDR 内存 自动 RS-485 数据流控制 一个Mini-PCI 插槽,一个CF 卡插槽,一个 32-bit PCI 插槽 (可选) 双10/100Base-T 或千兆以太网,带 LAN 启动 无风扇,低功耗 带 UPS 功能的智能电池模块(可选) 无线天线(可选) 内置 1 W x 2 扬声器 符合 ROHS 标准
产品介绍 IPPC-1580T 是一款无风扇设计平板电脑,主要用于无噪声工作环境和无尘室应用。IPPC-1580T 带有两套电源,一套为可选电池组,另外一套为交流电源。当IPPC-1580T 连接到交流电源时,系统会对内部的电池进行充电。可选的充电电池组能够提供超过 60 分钟的电池寿命,还可以在交流电源出现故障时起到 UPS 的功能。IPPC-1580T 安装孔符合 VESA 标准,可采用多种方式进行安装。 产品规格 CPU Embedded Intel ULV Celeron 1.0 GHz/ Embedded Intel Pentium M 1.1 GHz Chipset Intel 852GM/ICH4 /Intel 855GME/ICH Memory 2x200-pin SO-DIMM sockets, supporting DDR200/266 modules for up to 2 GB BIOS AWARD® 4 Mbit Flash BIOS SSD Supports Compact Flash card type I/II LCD Display 15" TFT 1024*768 XGA LCD
Touch screen (Optional) Standard is built-in vandal proof infrared HDD 1 x internal 2.5" IDE interface I/O Ports -3 x serial: 2 x RS-232, 1 x RS-232/422/485 (COM2) -4 x USB 2.0 ports: 2 x external, 2 x internal -1 x PS/2 mouse and keyboard port -1 x VGA port, 1 x Parallel port -2 x built-in speakers (1 W each) -2 x type II PCMCIA ports -Line-in, Line-out & Mic-inport -Bus Expansion 1 x Mini PCI socket and 1 x 32-bit PCI expansion kit (optional) COMBO Drive Optional DVD/CD-RW 8D/24W/24E/24R or above Ethernet Speed 10/100 Mbps; 10/100/1000 Mbps (optional) Power Support DC to DC Converter Input voltage: 18 ~ 25 VDC AC to DC Converter -Input Voltage: 100 ~ 240 VAC @ 50 ~ 60 Hz -Output Voltage:19V@4.73A Operating Temperature 0 ~ 45° C (32 ~ 113° F) Weight 7.2 kg Environmental Specifications Operating Temperature 0 ~ 45° C (32 ~ 113° F) Relative Humidity 10 ~ 95% @ 40° C, non-condensing Shock 10 G peak acceleration (11 ms duration) Dimensions (W x H x D) 415 x 333 x 76.5mm Non PCI expansion kit
