荷兰 PRECIA-MOLEN称重传感器
柱式称重传感器: CSP-M :10t,25t,40t,60t,100t SCL 35 t : 3 500 d (C3.5) and 2 x 3 500 d (C3.5MB) SCL 35 t Ex : 3 500 d - C3.5 SCL 55 t : 3 500 d (C3.5) and 2 x 3 500 d (C3.5MB) SCL 55 t Ex : 3 500 d - C3.5 ASL 30t: 3500 d (C3.5) ASL 30 t Ex :3500 d C3.5 ASL 50 t :3000 d (C3) ASL 30 t Ex :3000 d C3 波纹式称重传感器 FA3000 i 系列: Accuracy class: D1、C3、C6 Capacities: 10-20-50-100-200-500 kg 剪切梁式: CMA load cell: CMA300、CMA500、CMA1000 CMI Load cell: CMI500、CMI1000、CMI2000、CMI5000
S型称重传感器 TA-I 500、TA-I 100、TA-I 2000、TA-I 5000
Indicator: I100、I100-S I200B、I200M、I200B-S、I200M-S、I200B/I200M(-S)-D I200EX I300-S、I300
Controllers: I400D-M、 I400D-MS 、I400TB 、I400TB-S、I400SDU 、I400WLC; Process 12、Process13c/14c/T1c、Process 15、Process Satellite Dosing application、Process NUM SI : AFNSI、ISIA、ISIC; Mascon-3 ABS ; Siwarex FTA;
Printers: Alpha II、 TM 295、IBE 94 、LQ300 、P100 、P950 ;
(remote) Displays: D200 、ABC57 、ABC100/160/250 、RVO remote display (-0+ indicator) ;
Interfaces / adaptors: Profibus-DP 、Interbus-S 、 DeviceNet ;
固定称重: Vehicle weighbridges fixed position : VS-110 C/P 40 to 100t VS-120 C/P 40 to 80t VS-125 C/P 40 to 70t VS-200 C(/P) 30 to 100t VS-200 CS(/P) 30 to 100t VS-200 S(/P) 30 to 100t VS-300 CS 30 to 60t VS-300 S 30 to 60t ;
Vehicle weighbridges Mobile versions : VS-950 S/R 30 tot 60t VS-920 S/R 30 tot 70t ROC (pdf) 7ELEM (pdf)
Railway weighbridges WS-110; Truck dumpers Weighing and non-weighing: EVS-T weighing truck dumper VS-T non-weighing truck dumper ;
Traffic controlFor weighbridges;
Weighbridge self-service units and terminals For weighbridges and various other applications : BI300 self service unit ;
Standard scales: C 100 、C 200 B / C 200 M 、CK 100 、CR 100 、CR 100-S CK 200 、CR 200 、CR 200-S ;
Mobile weighining instruments Multiple applications: MCW Crane hook weigher TPW Weighing pallet trucks LTF / LTW Weighing forks / fork unit for lift trucks WWS Axle weighers ;
Platform scales For every industrial weighing need the right solution : K range platform scales industrial use R1 GM platform scales table top / floor use Jet''FP P Pallet scale R1 DL range platform scale table top use R4 SB-S range Low profile platform scales R4 range Industrial platform scale ;
Dynamic weighing : ABS hopper scales Bulk scales for weighing of bulk goods : ABS-XL hopper scales, standard and ATEX ABS-XL-SCS hopper scales, standard and ATEX ABS-XT throughput weigher Hopper scale automation / Process Control Software;
Check weighers TLV dynamic check weighers ; Bagging scales: BMG / DPG + BMB 、BMC 、BMX 、BMN ;
Bagging lines
Robot Palletizers
Auxiliary equipment ;
Dynamic bulk weighing: Dynamic bulk weighing Belt weighers: Weighing frames and weighing controllers Back to index belt weighers
Weighing frames SINGLE FX TAB BT VP MP ; Weighing controllers: ROL 470 (single scale) ROL 460 (single scale) ROL 400 (multiple scale ;
Dynamic bulk dosing Belt weighers: Dosing frames en dosing controllers: Dosing frames SB XK SBF MD PEP Dosing controllers REG 460 (single scale) REG 400 (multiple scale) PEP 400 (multiple scale)
