常规型插头 Color-Coded for ISA and IEC Captive Cover Screws Accepts Stranded or Solid Wire up to Size 20 AWG Quick Connect Contact Washers Internal Wire Divider SMP & SMPW Series Rated to 220°C (425°F) SMP--- Glass filled Nylon Construction SMPW ---Glass filled Nylon Construction with Write-On Window SMP-K-M(长柄式K型母插头),SMP-K-F (长柄式K型公插头) SMP-J-M(长柄式J型母插头),SMP-J-F (长柄式J型公插头) SMPW-K-M(书写式K型母插头),SMPW-K-F(书写式K型公插头) SMPW-J-M(书写式J型母插头),SMPW-J-F(书写式J型公插头)
