特点 Dual 10/100Mbps or Gigabit LAN on board Third RJ45 supported by LAN on ETX module Ti2150 PCI to PCI bridge LSI 53C1000 Ultra160 SCSI controller (optional) LVDS Panel and VGA CRT support CF card socket on board Two serial ports, 2 IDE channels PS/2 keyboard one parallel port IP350 产品规格 LAN First Ethernet: supported from the ETX module Second and Third Ethernet: two 10/100Mbps LAN (Intel® 82551) or two Gigabit LAN (Intel® 82540) Three RJ45 connectors on board PCI to PCI Bridge TI Ti2150 PCI to PCI bridge controller SCSI (Option) Ultra160 SCSI LSI 53C1000 controller 68-pin SCSI connector on board IDE Primary IDE connector on rear side Secondary IDE connector on board (44-pin) Keyboard and Mouse PS/2 connector for keyboard and mouse Y-cable bundled with board Signals also on J2 rear side CPCI connector VGA DB15 VGA CRT connector on front side LVDS panel signals on J2 rear side CPCI connector Compact Flash Socket Compact Flash socket for Type I cards USB Two USB ports on front side Two USB ports supported by pin headers on IP350R daughter board USB 1.1 compliant Serial Ports DB9 connector (on IP350R) for COM1 RS232 serial port, with signal also on J2 rear side CPCI connector Pin header (on IP350R) for COM2 RS232 serial port Printer Port Pin header on IP350R daughter board IP350R Daughter Board The IP350R daughter board supports the following connectors: Printer port pin header 3rd and 4th USB ports pin header COM1 D-sub connector COM2 serial port pin header RJ45 connector Form Factor 3U CompactPCI Board Dimensions 160mm x 100mm Operating Temperature 0°C~60°C (32°F~140°F) Storage Temperature -20°C~80°C (-68°F~176°F) Relative Humidity 10%~90% (non-condensing) 订购信息 IP350 3U CompactPCI ETX Baseboard with two 10/100 Mbps LAN on board IP350G 3U CompactPCI ETX Baseboard with two gigabit LAN on board IP350S 3U CompactPCI ETX Baseboard with two 10/100 Mbps LAN and Ultra160 SCSI
