点击看大图
产品名称: IB865
型  号: IB865
品  牌: IBASE (广积科技)
产品介绍: IB865 产品规格
CPU Socket
LGA775
CPU
Intel® Pentium® 4, Celeron® D processor
2.53 GHz ~ 3.80GHz+
CPU Front Side Bus ( FSB )
800MHz / 533MHz
Chipset
Intel® 865G chipset
L2 Cache
256K/1M, CPU integrated
BIOS
Award BIOS, ACPI supported
System Memory
Two DDR sockets support up to 2GB DDR SDRAM
PC333/400 DDR SDRAM, without ECC
Integrated VGA
Integrated 82865G AGP4X VGA for CRT interface
Optional MicroAGP VGA
1. ATI Mobility M9 VGA, 64MB frame buffer (DDR) via IBA110-64, supports CRT, LVDS, TV-out, 2nd CRT
2. ATI Mobility M10 VGA, AGP8X, 64MB frame buffer (DDR) via IBA110-64A, supports CRT, LVDS, TV-out, 2nd CRT
3. LVDS / TV-out MicroAGP card - IBA120
Primary LAN
Intel® 82551 10/100Mb Ethernet controller
Secondary LAN (optional)
Intel® 82547GI Gigabit Ethernet controller
Audio
ICH5 integrated audio with AC97; 5.1 channel support
LPC I/O
W83627HF chipset supports IrDA x 1, Parallel x 1, COM1 (RS232), COM2 (RS232/422/485), FDC up to 2.88MB (3 Mode support), Hardware Monitor (3 thermal inputs, 6 voltage monitor inputs, VID0-4, 3 fan headers)
IDE Interface
Built in ICH5; Two enhanced IDE supports 4 IDE devices including UDMA33/66/100, PIO mode 4 and bus master
FDD Interface
Supports up to two floppy disk drives: 3.5" and/or 5.25" drives; 3 Mode support
Parallel Port
One parallel port supports SPP/EPP/ECP
Serial Ports
One RS-232/422/485 and one RS-232 port
Serial ATA
Supports 2 ports
Watchdog Timer
Generates system reset; 256 levels
Solid State Disk Interface
Supports up to 512MB M-Systems DiskOnChip flash disk
Hardware Monitoring
Built in W83627HF; monitors system/CPU temperature and voltage status
USB
Supports 4 USB ports, USB 2.0 compliant
IrDA
Pin header
Keyboard and Mouse Connector
PS/2 type
Extra Features
ISA High Drive
PCI to ISA Bridge (ITE 8888)
One MicroAGP socket
ATX 12V power connector
Form Factor
Full Size CPU Card
Dimensions
338mm x 122mm (13.3" x 4.8")
Power Consumption
Intel® Pentium® LGA775 processor 3.6GHz with 2 x 512MB DDR memory
+3.3V: 3.35A; +5V: 3.76A; +12V: 9.62A
Intel® Celeron® D LGA775 processor 2.8GHz with 2 x 512MB DDR memory
+3.3V: 3.06A; +5V: 3.49A; +12V: 5.16A
环境条件
Operating Temperature:
0°C~60°C (32°F~140°F)
Storage Temperature:
-20°C~80°C (-68°F~176°F)
Relative Humidity:
10%~90% (non-condensing)
订购信息
IB865 LGA775 Intel® 865G PICMG Full Size CPU Card, FSB 800MHz, support DDR, 82551 LAN x1, VGA, MicroAGP for optional VGA expansion
IB865F LGA775 Intel® 865G PICMG Full Size CPU Card, FSB 800MHz, support DDR, 82551 LAN x1, 82547 Gigabit LAN x1, VGA, MicroAGP for optional VGA expansion
IP380 Backplane for PICMG 1.3 CPU card with 3x PCI-E (x1), 1x PCI-E (x16), 4x PCI slots
IBA110-64 MicroAGP VGA card with ATI M9 VGA, 64MB memory, supports CRT, TMDS, LVDS, TV-out, 2nd CRT
IBA110-64A MicroAGP VGA card with ATI M10 VGA, AGP8X, 64MB, supports CRT, TMDS, LVDS, TV-out, 2nd CRT
IBA120 MicroAGP card with Chrontel CH7017 LVDS chipset for LVDS or TV-out support
IBA130 MicroAGP card with Chrontel CH7009 chipset for DVI and TV-out support
IB865 Versions Chipset 10/100 LAN Gigabit LAN
IB865 865G Yes No
IB865F 865G Yes Yes
公司名称: 广积科技(中国分公司)
联 系 人: 吴玉成
电  话: 021 021-51501588
传  真: 021-51501566
地  址: (上海市)上海市武定路1088号16A
邮  编: 200040
主  页: http://www.ibase-china.com
  • 广积科技推出基于Intel GM45处理器的Mini-ITX工业用主板-MI945(MI945)
  • 广积科技推出第一款支持Intel Q45处理器ATX工业级主板-MB945(MB945)
  • 广积科技推出支持Intel® GME965处理器的3.5寸工业用主板-IB886(IB886)
  • 广积科技推出基于Intel 凌动系列处理器的工业用Mini-ITX主板-MI810(MI810)
  • 广积科技推出支持AMD M690E处理器的Mini-ITX 工业用主板-MI933(MI933)
  • 广积科技推出支持英特尔@945GC芯片组的工业级Mini-ITX主板-MI940(MI940)
  • 广积科技推出基于AMD 闪龙系列芯片的工业级3.5寸主板-IB885(IB885)
  • 广积科技推出基于Intel® 凌动™系列芯片组的3.5寸工业级主板- IB883(IB883)
  • 广积科技推出支持Intel® 945GC芯片组Mini-ITX工业级主板-MI800(mi800)
  • 广积科技推出支持英特尔EP80579 SoC(片上系统)x86处理器--ECX810(ecx810)
  • 广积科技推出Intel(R)CoreTM2四核芯片 网络服务专用工业主板--MB935(MB935)
  • 广积科技推出支持英特尔®迅驰凌动芯片组的3.5寸嵌入式用业用主板—IB882(IB882)
  • 广积推出ETX模块-ET500(ET500)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
