产品介绍: |
DOC 2000电子盘 DiskOnChip 2000 leverages cost-effective NAND flash technologies while meeting standard, embedded system requirements for reliable, on-target data and code storage in a sturdy, 32-pin DIP. It is successfully implemented in hundreds of applications that use the ISA or local bus, such as Single Board Computers (SBCs), industrial PCs, thin clients, servers and telecom infrastructure equipment. Available in a wide capacity range, from 16MB to 1GB, DiskOnChip 2000 is scalable. It is compatible with every major CPU and supports all major OS environments. Unmatched Data Reliability On-the-fly Error Detection and Correction Code (EDC/ECC) and M-Systems'''''''' TrueFFS® Flash File System, an industry-standard for flash management, guarantee data reliability without any performance penalties.
Rugged & Scalable DiskOnChip 2000 provides rugged storage packed in a standard, 32-pin DIP. All capacities use the same size 8KB memory window for seamless upgrades.
Any CPU, Any OS DiskOnChip 2000 is compatible with every major CPU and supports all major OS environments. A royalty-free SDK enables proprietary CPU and OS support.
Features Interface Support: ISA, local bus Capacity (MB): 16, 32, 48, 64, 96, 128, 192, 256, 384, 576, 768, 1024 Flash Technology: Binary NAND Performance: Sustained Read: ISA: 1.1MB/sec, local bus: 6MB/sec Burst Read/Write: ISA: 1.1MB/sec, local bus: 11.9MB/sec Sustained Write: ISA: 0.65MB/sec, local bus: 2.1MB/sec Voltage: 5V or 3.3V Operating Temp: Commercial: 0°C to +70°C Extended: -40°C to +85°C
