Model Name: HEC-300ER Temperature Range: 10~50 °C Operating, -40~70 °C Non-Operating Hold-up Time: < 16.6 ms at Full Load & Normal Input Voltage Dielectric Protection: 1800 VAC for 1 sec. Humidity: 5~95% RH Efficiency: 70% min, 72% typical @ Full Load Power Good Signal: On Delay 100~500 ms, Off Delay 1 ms Overload Protection: 100~150% Load Over Voltage Protection: +5 V max 7 V, +12 V max 15.6 V, +3.3 V max 4.3 V Inrush Current: 60A (RMS) max for 115 VAC, 120A (RMS) max for 230 VAC Remote Sensing: +3.3 V Cooling Fans: 8 cm DC Fan Dimensions W: 150 mm H: 86 mm D: 140 mm INPUT CHARACTERISTICS Voltage: 90 ~ 132 VAC or 180 ~ 264 VAC (HEC-460DR) 180 ~ 264 VAC (HEC-460DR-A) Frequency: 47 ~ 63 HZ (ALL MODELS) OUTPUT CHARACTERISTICS Model \ Output +3.3 V +5 V +12 V -5 V -12 V +5 VSB Combined Power HEC-460DR 27 A 29 A 29.5 A 0.8 A 2 A 200 W HEC-460DR-A 27 A 29 A 29.5 A 0.8 A 2 A 200 W Regulation ± 5% ± 5% ± 5% ± 10% ± 10% ± 5%
