TDF底座式 Wide working range with low ceilings: Low Floor –standing Type 即使棚顶低,也可在广范围内操作:低座式 Features /特征 Can be installed under a low ceiling ,yet wide working range is ensured With double link type,flange for connecting attachments is kept level for excellent workability Series of five models for suspended loads of 30 kg ,38kg,50kg,75kg,and 150kg. With Types 75 and 150,suspended load/working range can be varied by changing the arm ratio Note: A single link model is also available in the 38kg type 即使现场棚顶底,也可安装,可确保广泛的工作范围。 利用双重连接方式,可保持工作头的连接部(法兰西)的水平,发挥灵活的操作性。 起吊重量为30kg、38kg、 50kg 、75kg 及150kg 的五个机种的系列化。 75及150型的起重臂的比例改变起吊重量及作业范围。 注:38kg型有单一连接方式。
