规格尺寸 高 度 8.75" (22.23 cm) 宽 度 4.35" (11.05 cm) 深 度 16.91" (42.95 cm) 重 量 10.65 lbs. (4.83 kg) 配置 类型、速度 CPU:Pentium 4 up to 2.8GHz 内存:512MB 硬盘:80G I/O 按钮指示灯: 电源开关, reset开关, 系统指示灯 I/O接口: 5个全长扩展槽,1个DB-25并口,1个DB-9 RS232接口,一个 PS/2 Expansion Slots Option 1: Four 32-bit / 33 MHz PCI (5V) Option 2: One ISA, three 32-bit / 33 MHz PCI (5V) Option 3: Two ISA, two 32-bit / 33 MHz PCI (5V) Option 4: Two ISA, two 64/32-bit / 66/33 MHz PCI (3.3V) Option 5: Three ISA, one 32-bit / 33 MHz PCI (5V) 散热系统 风扇 1个17CFM风扇(0.5m3/min), 1个25CFM风扇 (0.7 m3/min) 安装方式 Option 1: 正面固定安装 Option 2: 中部固定安装 Option 3: 底部固定安装 Option 4: 壁挂式固定安装 电源输入 Option 2: 130W or 180W 120/240 VAC 50/60 Hz PFC Option 3: 100W, 150W or 180W -48 VDC 工作环境 工作温度: 0 to 50 C (32 to 122 F) 存储温度: -40 to 70 C (-40 to 158 F) 工作湿度: 5% to 95% (non-condensing) Storage Altitude: Up to 10,600 m (34,777 ft) MSL Operating Altitude: Up to 4,000 m (13,123 ft) MSL 50 C for 6 hrs Storage Shock: 20 G Storage Vibration: 0.5 G @ 5-50 Hz for 30 min, 3.0 G @ 50-500 Hz for 12 min (in shipping carton) Operating Vibration: Per Bellcore GR-63-CORE standards: Earthquake - VERTIQll 1.6 G @ 1-50 Hz for 30 sec, Office - 0.1 G @ 1-100 Hz back to 5 Hz for 90 min Regulations Safety: UL 60950 / CSA C22.2-950 / IEC 60950 Emissions :FCC Part 15, Subpart B, ICES-003 (Canada), EN 55022 / CISPR 22, IEC 61000-3-2 - Harmonics, IEC 61000-3-3 - Flicker Immunity: EN 55024 / CISPR 24, IEC 61000-4-2 - ESD, IEC -61000-4-3 Radiated RF, IEC 61000-4-4 - EFT, IEC 61000-4-5 - Surge, IEC 61000-4-6 - RF Conducted, IEC 61000-4-11 - Voltage dips, interrupts & varations Certifications: UL, C-UL, CE (100 & 150 WAC PS is not CE), FCC, ICES-003 (Canada) Additional Regulations NEBS: Specific configurations of this chassis have been NEBS Level 3 certified. Military Standards MIL-STD Testing: Specific configurations of this chassis have been through MIL-STD testing. MIL-STD-810F: Method 500.4 Low Pressure (altitude) 15000 ft, Method 501.4 High Temperature-Operating 50 C, Method 502.4 Low Temperature-Operating 0 C, Method 507.4 Humidity-Operating 75%, Method 514.5 Random Vibrating Fig. 514.5C-15 Random, Vibration for shipboard use-Operating, Sinusoidal Vibration for surface ship environment-Operating MIL-STD-167-1: Sinusoidal Vibration for surface ship environment
