Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¹¦·ÖÆ÷
²úÆ·Ãû³Æ£º ¹¦·ÖÆ÷
ÐÍ ºÅ£º 2X10-2-12
ÎÒ¹«Ë¾´úÀíZ-COMM.Mini-Circuits Agilent  FUJITSU M/A-COM Hittite RFMD Weinschel MECA  RLC  DITOM  Marki  MITEQ KMW CTT Narda HRS tdc ARRA Dow-Key Huber+Suhner RADIALL K&L SPECTRUM MCLI HEROTEK broadwave TRM CMC PMI ... µÈÆ·ÅÆ.¹¦·ÖÆ÷ Ë¥¼õÆ÷ µÍÔëÉù·Å´óÆ÷ »ìƵÆ÷ Â˲¨Æ÷ É䯵¿ª¹Ø ¹¦·Å¹Ü ¿Éµ÷Ë¥¼õÆ÷ µç¿ØË¥¼õÆ÷ Æ«ÖÃÆ÷ ¸ôÖ±Æ÷ »·ÐÎÆ÷ ¼ì²¨Æ÷ ±¶ÆµÆ÷ ñîºÏÆ÷ ¸ºÔØRF/΢²¨ÅäÌׯµÂÊÔª¼þ£¬ÓÐÐèÒªÁªÏµÎÒ 13798503887 ÕÅÔ¾£¬QQ742796503
ÐͺŠƵÂÊ Way Æ·ÅÆ ½ÓÍ·
ZMSC4-1-2B 4-Way MINI SMA
ZMSC3-2-1B 3-Way MINI SMA
2X10-2-12 2-1200MHz 2-Way MINI SMA
2ZN2PD-2000-1 2-Way MINI SMA
ZB2C4S-2-1 2-4Way MINI SMA
ZN2PD-920 2-Way MINI SMA
ZCSC-8-1 8-Way MINI SMA
ZN3PD-900-7 3-Way MINI SMA
ZMSC-2-1W 2-Way MINI SMA
ZFDC-20-3 2-Way MINI SMA
ZMSC-2-1 2-Way MINI SMA
ZFSC-2-1 5-500MHz 2-Way MINI SMA
BX00-0541-00 1.0-2.0GHz 3-Way M/A-COM SMA
BX00-0542-00 1.0-2.0GHz 2-Way M/A-COM SMA
2089-4265-00 20-1300MHz 2-Way M/A-COM SMA
2089-6204-00 8.0-12.4GHz 2-Way M/A-COM SMA
2089-6202-00 2.0-4.0GHz 2-Way M/A-COM SMA
2089-6404-00-20 8-12.4GHz 4-Way M/A-COM SMA
2089-6419-00 1.7-2.0GHz 4-Way M/A-COM SMA
4456-2 2.0-18.0GHz 2-Way NARDA SMA
4313C-4 2-4GHz 4-Way NARDA SMA
4313-4 2-4GHz 4-Way NARDA SMA
4311-4 0.5-1GHz 4-Way NARDA SMA
4321B-2 0.5-2.0GHz 2-Way NARDA SMA
4313B-2 2.4-GHz 2-Way NARDA SMA
27287 5-14GHz 2-Way NARDA SMA
26819 2-Way NARDA SMA
27253 8.0-18.5GHz 2-Way NARDA SMA
4317-2 18-26.5GHz 2-Way NARDA SMA
4316-2 12.0-18.0GHz 2-Way NARDA SMA
4312-2 1-2GHz 2-Way NARDA SMA
4313-2 2.0-4.0GHz 2-Way NARDA SMA
4315-2 8.0-12.4GHz 2-Way NARDA SMA
18043 0.7-3.4GHz 4-Way NORSAL IND.INC SMA
18059 2-Way NORSAL IND.INC SMA
18108-2 5.5-13GHz 2-Way NORSAL IND.INC SMA
18108-3 5.5-13GHz 2-Way NORSAL IND.INC SMA
18108-4 4.1-12GHz 2-Way NORSAL IND.INC SMA
5409 DC-18GHz 2-Way WEINSCHEL N
WA1515 2-Way WEINSCHEL SMA
435-30954 4-Way WEINSCHEL SMA
PDM-20-1100 DC-2GHz 2-Way MERRIMAC SMA
PDM-20-50 2-Way MERRIMAC SMA
PDM-30-50 DC-200MHz 3-Way MERRIMAC SMA
PDM-30-250 DC-200MHz 3-Way MERRIMAC SMA
PDM-23-12G 6.5-13.7GHz 2-Way MERRIMAC SMA
KPS21P140008 1.5-2GHz 2-Way KMW SMA
KPDSR4W 1.5-2.3GHz 4-Way KMW SMA
KPDSU2W 2-Way KMW SMA
KPDSR3W 1.4-2.1GHz 3-Way KMW SMA
KPDSR2W 1.6-2.1GHz 2-Way KMW SMA
PDM-22-3G 2-4GHz 2-Way MERRIMAC SMA
PDM-22-1.5G 1.0-2.0GHz 2-Way MERRIMAC SMA
PDML-40A-500 4-Way MERRIMAC SMA
CRM-10-500 2-Way MERRIMAC SMA
PDM-42-1.5GA 4-Way MERRIMAC SMA
LTM50-W2S-00 70-800MHz 2-Way SEOHWA TELECOMCO LTD/SJM SMA
LTM50-C2S-00 800-900MHz 2-Way SEOHWA TELECOMCO LTD/SJM SMA
D321MS 0.75-2GHz 2-4Way KDI SMA
KIC-B59S 3-Way KDI SMA-N
MW-12900 15-500MHz 2-Way KTEIFK SMA
MW12970M1 20-500MHz 2-Way KTEIFK SMA
MW12140 100-200MHz 2-Way KTEIFK SMA
27302C 0.5-26.5GHz 2-Way HP SMA
58517A 8-Way HP N
D-1545 2-Way RLC SMA
D-1491 2-Way RLC SMA
YL-23 500-2000MHz 2-Way TRIANGLE MICROWAVE INC SMA
YL-33 2-Way TRIANGLE MICROWAVE INC SMA
DMS206 2.0-4.0GHz 2-Way TRM SMA
DMS212 4.8-18GHz 2-Way TRM SMA
DMS205 1.0-2.0GHz 2-Way TRM SMA
DMS210 8.0-12.4GHz 2-Way TRM SMA
DL206 5-680MHz 2-Way TRM SMA
HC-0809-4PS 4-Way LGIC SMA
HC-0809-2PD 2-Way LGIC SMA
HC-0420-4PD 4-Way LGIC SMA
150730 1800-2000MHz 4-Way MIKOM SMA
150728 800-1000MHz 4-Way MIKOM SMA
ANTP48 4-Way TELEWAVE INC N
3760 3.1-5GHz 4-Way TELEDYNE SMA
PD-182-PS 1.7-2.4GHz 2-Way ACE SMA
D434M 3.7-4.2GH 4-Wa, y EMCO SMA
800-900MHz 2-Way HST SMA
2PD8S 824-894MHz 2-Way SUNWAVE SMA
HPS-2H£¨10£© 2-Way HRS SMA
PS2-1 2-Way MCLI SMA
ZA3PD-1.5 3-Way MCL SMA
50PD-017 3-Way JFW SMA
6005-02 2-Way INMET SMA
0-HJ-302G DC-1.3GHz 2-Way ST OLEKTRON SMA
C7580A 5-7GHz 2-Way NEC SMA
PD-8/26 2-Way MNI SMA
SD-105117-001 900-2700MHz 2-Way HYBRID SMA
306180C/MW1209 5-Way D.COUP/SPLIT N-SMA
MW-12990 20-500MHz 8-Way ELISTA SMA-N
0.5-2GHz 4-Way SMA
600-2000MHz 4-Way SMA
YT-23 1.7-2.4GHz 3-Way SMA
2-4.5GHz 3-Way SMA
0.5-2GHz 4-Way SMA
0.65-3.2GHz 4-Way SMA
1.6-4.2GHz 4-Way SMA
YL-2117 8-12.4GHz 2-Way SMA
7.8-14GHz 2-Way SMA
3-13GHz 2-Way SMA
2PD-LB 2-Way SMA
SCP-4-1 1-400MHz 4-Way SMA
LRPS-2-11 20-2000MHz 4-Way SMA
3.2-5.5GHz 2-Way SMA
RB-IN£¨M£© 2-Way SMA
RB-IN£¨S£© 2-Way SMA
5-Way N
4-Way N
RD-52S/SN-C2 2-Way SMA
¹«Ë¾Ãû³Æ£º ÉîÛÚÊд´·É½Ü¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 13798503887 / ÑîÕð
ÊÖ»ú£º 13798503887
µØ Ö·£º ÉîÛÚÊÐÁú»ªÐÂÇøÃñÖνֵÀÕÁ¿Ó1Çø166¶°1403ÊÒ
ÓÊ ±à£º 518110
Ö÷ Ò³£º http://www.cfjkj.com
  • µÍ¹¦ÂÊË¥¼õÆ÷
  • ÊÖµ÷²½½ø¿É±äË¥¼õÆ÷
  • Ë¥¼õÆ÷
  • ¸ºÔØ
  • ¹¦·ÖÆ÷
  • ñîºÏÆ÷
  • É䯵¿ª¹Ø
  • Â˲¨Æ÷
  • ¼ì²¨Æ÷
  • Õñµ´Æ÷
