ÎÒ¹«Ë¾´úÀíZ-COMM.Ö÷Óª£ºMini-Circuits£»HP; FUJITSU£»M/A-COM£»Hittite£» RFMD£»Weinschel¡£MECA RLC DITOM Marki MITEQ KMW CTT Narda HRS tdc.ARRA.Dow-Key CERNEX ... µÈÆ·ÅÆµÄRF/΢²¨ÅäÌׯµÂÊÔª¼þÂðÓÐÐèÒªÁªÏµÎÒ13798503887ÕÅÔ¾£¬Ö±Ïß0755-82568597 QQ742796503
ÐͺŠ|
±¾Õñ/É䯵 |
ÖÐÆµ |
¹¦ÂÊ£¨dBm) |
Æ·ÅÆ |
RKS-7LW3399-001 |
12.7GHz |
DC-2.5GHz |
9.5dBm |
AVANTEK |
DBX-72L |
12.7GHz |
DC-365MHz |
10dBm |
AVANTEK |
DBX-72L-1 |
AVANTEK |
SX84-3024 |
AVANTEK |
DBX-1824M |
AVANTEK |
DBX-72H |
AVANTEK |
DBX-1.58L |
12.7GHz |
DC-3GHz |
8dBm |
AVANTEK |
DBX-824M |
12.7GHz |
DC-5.5GHz |
10dBm |
AVANTEK |
DBX-1221L |
12.7GHz |
DC-2GHz |
10dBm |
AVANTEK |
DBX-158H |
12.7GHz |
DC-2GHz |
8dBm |
AVANTEK |
7A212B |
8.9-9.4GHz |
ANAREN |
7D0117 |
ANAREN |
7N0118 |
10.7-11.7GHz |
ANAREN |
70340 |
2.6-5.2GHz |
ANAREN |
70580 |
2.2-2.3GHz |
ANAREN |
230224/70670 |
ANAREN |
M2BC |
WJ |
M79HC-1 |
12.7GHz |
DC-3.5GHz |
10dBm |
WJ |
M8YHC |
WJ |
M79C-9 |
WJ |
M1K |
WJ |
M1P-2 |
WJ |
S1 |
WJ |
M1J |
WJ |
M1K-8 |
WJ |
M1 |
WJ |
M63C-1 |
WJ |
M88CB |
WJ |
M79HC |
WJ |
MK50170-1006015 |
WJ |
MZ7410 |
WJ |
M52DC-1 |
12.7GHz |
DC-3GHz |
10dBm |
WJ |
M52C-5 |
12.7GHz |
DC-3.5GHz |
8dBm |
WJ |
M12A-11 |
12.7GHz |
DC-3.5GHz |
8dBm |
WJ |
M76C |
12.7GHz |
DC-3GHz |
10dBm |
WJ |
M876C |
DC-1.9GHz |
12dBm |
WJ |
M67C |
12.7GHz |
DC-3GHz |
9dBm |
WJ |
MC54PL-5 |
12.7GHz |
DC-4GHz |
10dBm |
MAGNUM |
MC97PG-3 |
12.7GHz |
DC-2.5GHz |
10dBm |
MAGNUM |
M044P |
MAGNUM |
M097PG-3 |
MAGNUM |
MC17P-2/094-020081-035 |
MAGNUM |
M20020K |
MARKI |
M94162 |
MARKI |
M94163 |
MARKI |
M94161 |
MARKI |
M97220 |
12.7GHz |
DC-2GHz |
10dBm |
MARKI |
MX8141 |
12.7GHz |
DC-6GHz |
10dBm |
AEITECH |
8141 |
DC-1.5GHz |
15dBm |
AEITECH |
TBO226HA1 |
MITEQ |
M20 |
12.7GHz |
DC-4.2GHz |
10dBm |
MITEQ |
1R15 |
MARK |
M2AC |
STELLEK |
M8TC |
STELLEK |
M2EC |
STELLEK |
ZEM-4300-1 |
MINI |
ZEM-M2TMH |
MINI |
ZAM-42 |
MINI |
ZMX-8CLH |
MINI |
ZFM-3A |
MINI |
OMM-4A-1000 |
MERRIMAC |
PCM-3-30 |
MERRIMAC |
MM48PG-1 |
REMEC MAGNUM |
MM96PN |
12.7GHz |
DC-4.5GHz |
10dBm |
REMEC MAGNUM |
M-9329 |
12.4GHz |
DC-4GHz |
10dBm |
WM |
M-10060 |
12.7GHz |
DC-3.5GHz |
9dBm |
WM |
5086-6177 |
HP |
5086-7034 |
HP |
M027S |
076-108759-004 |
23GHz |
076-107675 |
18GHz |
IRM |
076-108759-002 |
23GHz |
C&S Hybrid |
076-107675-002 |
076-107675-003 |
CELERITEK |
4428C |
ARRA |
076-108745-001 |
5.9-7.0GHz |
HARRIS |
90405A |
12GHz |
NEC |
DBM-400 |
DOUBLY BALANCD |
244-419540-000 |
S94-6990 |
5.85-14.50GHz |
MILLIWAVE |
8392 |
91252 |
ROYAL |
MD-525230567-2 |
ANZAC |
PN31260-42043 |
MX7514 |
FEIMICROWAVE |
DMS1-2615-192-80 |
RHG |
057169-01 |
076-108152 |
18GHz |
MFR-12457/DML-6B-10G |
12.7GHz |
DC-4GHz |
10dBm |
MERRIMAC |
8392 |
12.7GHz |
DC-1GHz |
10dBm |
12.7GHz |
DC-5.5GHz |
10dBm |
076-106835-001 |
DC-1.8GHz |
20dBm |
DXM511-2 |
12.7GHz |
DC-604MHz |
90dBm |
TIME |
DXM621 |
12.7GHz |
DC-2GHz |
9dBm |
8392/531A |
12.7GHz |
DC-2GHz |
10dBm |
12.7GHz |
DC-1GHz |
9dBm |
MAP-6504-81 |
UA |
CTR960459102R01 |
S94-5124-1 |
38.85-39.48GHz |
DMC-111595-004 |
7GHz |
DMC-111598-102 |
7GHz |
DMC-110046 |
1870MHz |
DMC-110045 |
310MHz |
DMC-110185 |
310MHz |
DMC-110186 |
650MHz |
