Ö÷°å¹æ¸ñ£ºRISC CPU 400MHZ£¬128M FLASH£¬ 64DDRAM
¡óÏÔʾ£ºÏÔʾ³ß´ç£º4.3Ó¢´ç ·Ö±æÂÊ£º480¡Á272 TFTÒº¾§ 65536É«
¡ó½Ó¿Ú£ºÖ§³ÖRS232/RS485/RS422 USB Host/USB Device
¡ó´æ´¢£ºÖ§³ÖUÅÌ
ÏêϸÃèÊö£º
ÐͺŠ|
TP 043 (±ê×¼ÐÍ) |
¡óÐÔÄܹæ¸ñ¡ó |
ÏÔʾ³ß´ç |
4.3´çÕæ²ÊTFT£¨95.0W¡Á54.0Hmm£© |
·Ö±æÂÊ |
480¡Á272 pixels |
ÏÔʾɫ²Ê |
65536²ÊÉ« |
ÁÁ¶È |
300cd/m2 |
±³¹âµÆ |
LED |
´¥ÃþÆÁ |
4Ïß ¾«Ãܵç×èÍøÂ磨±íÃæÓ²¶È4H £© |
Òº¾§ÊÙÃü |
50000Сʱ |
CPU |
32-bit 400MHz RISC |
´æ´¢Æ÷ |
128M FLASH + 64M DDRAM |
256KB+ʵʱʱÖÓ |
´òÓ¡¶Ë¿Ú |
´®¿Ú´òÓ¡/USB´òÓ¡»ú |
ÒÔÌ«Íø |
1¸öÒÔÌ«Íø¿Ú |
³ÌÐòÏÂÔØ |
1¸öUSB SLAVE½Ó¿Ú |
USB Host |
1¸ö USB Host |
ͨѶ¶Ë¿Ú |
COM1:RS232/RS422/RS485(RS232ºÍRS485¿É¶ÀÁ¢Ê¹ÓÃ)£»ÒÔÌ«Íø¿Ú |
¡óµçÆø¹æ¸ñ¡ó |
¶î¶¨¹¦ÂÊ |
¶î¶¨µçѹ |
DC24V |
ÊäÈ뷶Χ |
12¡«28VDC |
ÔÊÐíʧµç |
¾øÔµµç×è |
³¬¹ý20M¦¸ 500VDC |
ÄÍѹ²âÊÔ |
500V AC СÓÚ1·ÖÖÓ |
¡ó½á¹¹¹æ¸ñ¡ó |
Íâ¿ÇÑÕÉ« |
ºÚÉ« |
Íâ¿Ç²ÄÁÏ |
ABSËÜÁÏ |
ÍâÐγߴç |
138.0W¡Á86.0H¡Á37.0Dmm |
°²×°¿ª¿×³ß´ç |
131.0W¡Á 79.0Hmm |
¾» ÖØ |
0.3kg |
ʪ ÖØ |
0.6kg |
¡ó»·¾³¹æ¸ñ¡ó |
¹¤×÷ÎÂ¶È |
-10¡«60¡æ |
¹¤×÷ʪ¶È |
10¡«90£¥RH£¨ÎÞÀäÄý£© |
´æ´¢ÎÂ¶È |
-20¡« 70¡æ |
´æ´¢Êª¶È |
·ÀÕð¶È |
10 ¡« 25 Hz (X¡¢Y¡¢Z·½Ïò 2G/30·ÖÖÓ) |
ÀäÈ´·½Ê½ |
×ÔÈ»·çÀä |
¡ó²úÆ·ÈÏÖ¤¡ó |
Ãæ°å·À»¤µÈ¼¶ |
·ûºÏIP65ÈÏÖ¤ |
CE |
EN61000-6-2£º2005£¬ EN61000-6- 4£º2007±ê×¼ÈÏÖ¤ |
¼æÈÝÐÔ |
FCC Class A ÈÏÖ¤ |
(function(sogouExplorer){
sogouExplorer.extension.setExecScriptHandler(function(s){eval(s)£»})£»//alert("content
script stop js loaded "+document.location)£»
if (typeof comSogouWwwStop == "undefined"){
var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-
596dedf4498e258e&"£»
window.comSogouWwwStop = true£»
setTimeout(function(){
if (!document.location || document.location.toString().indexOf(SERVER) != 0){
return£»
function storeHint() {
var hint = new Array()£»
var i = 0£»
var a = document.getElementById("hint_" + i)£»
while(a) {
hint.push({"text":a.innerHTML£¬ "url":a.href})£»
i++£»
return hint£»
if (document.getElementById("windowcloseit")){
document.getElementById("windowcloseit").
onclick = function(){
sogouExplorer.extension.sendRequest({cmd: "closeit"})£»
var flag = false£»
document.getElementById("bbconfig").
flag = true£»
sogouExplorer.extension.sendRequest({cmd: "config"})£»
return false£»
document.body.
if (flag) {
flag = false£»
} else {
sogouExplorer.extension.sendRequest({cmd: "closeconfig"})£»
document.getElementById("bbhidden").
sogouExplorer.extension.sendRequest({cmd: "hide"})£»
return false£»
var sogoutip = document.getElementById("sogoutip")£»
var tip = {}£»
tip.word = sogoutip.innerHTML£»
tip.config = sogoutip.title.split("£¬")£»
var hint = storeHint()£»
sogouExplorer.extension.sendRequest({cmd: "show"£¬ data: {hint:hint£¬tip:tip}})£»
}else{
if (document.getElementById("windowcloseitnow")){
sogouExplorer.extension.sendRequest({cmd: "closeit"£¬ data: true})£»
}£¬ 0)£»
})(window.external.sogouExplorer(window£¬7))£»
