HN500ÐʹŵçʽһÌ廯Õñ¶¯±äËÍÆ÷½«´ÅµçʽÕñ¶¯ËÙ¶È´«¸ÐÆ÷¡¢¾«ÃܲâÁ¿µç·¼¯³ÉÔÚÒ»Æð£¬¹¹³É¸ß¾«¶ÈÕñ¶¯²âÁ¿ÏµÍ³£¬¸Ã±äËÍÆ÷¿ÉÖ±½ÓÁ¬½ÓDCS¡¢PLC»òÆäËüÉ豸£¬ÊDzâÁ¿·ç»ú¡¢µç¶¯»ú¡¢Ë®±ÃµÈ¹¤³§É豸Õñ¶¯µÄÀíÏëÑ¡Ôñ¡£
¼¼Êõ²ÎÊý
ƵÂÊÏìÓ¦£º10 ¡« 1000 Hz»ò5¡« 1000 Hz£¨ÌØÊâ˵Ã÷£©
×ÔÕñƵÂÊ£º10Hz»ò4.5Hz
²âÁ¿·¶Î§£º0-50mm/s£»0-500um £¨Á¿³Ì¿ÉÑ¡£©
ÐźÅÊä³ö£º4¡«20mA£¨±0.05mA£©
Êä³ö×迹£º≤500Ω
¹¤×÷µçѹ£ºDC24V±10%
½ÓÏß·½Ê½£º¶þÏßÖÆ
²âÁ¿·½Ïò£ºË®Æ½£¬´¹Ö±»òͨÓÃ
ʹÓû·¾³£ºÎ ¶È -40¡æ¡«100¡æ Ïà¶Ôʪ¶È ≤90%
ÍâÐγߴ磺φ35×70mm£¨ËÙ¶ÈÐÍ£©£»40×70mm£¨Î»ÒÆÐÍ£©
°²×°ÂÝÎÆ£ºM10×1.5×10mm£¨Éî¶È£©
ÖØ Á¿£ºÔ¼350g
330500/330525/330750/190501/9200/74712/47633/330400/330425/200350/200150/200155/350900/26530ËÙ¶È´«¸ÐÆ÷
PR9266/10 PR9268/11 PR9266/12 PR9268/20/30 PR9268/60/70µç¶¯Ê½¾ø¶ÔÕñ¶¯´«¸ÐÆ÷
PR6418Ïà¶ÔÎ»ÒÆ´«¸ÐÆ÷PR9350µç¸ÐÊ½Î»ÒÆ´«¸ÐÆ÷PR9376תËÙ´«¸ÐÆ÷PR9270¼ÓËÙ¶È´«¸ÐÆ÷
TM0782A-K /TM0783A/TM0793V-K /TM079VDÕñ¶¯´«¸ÐÆ÷
330301/330302/330303/330601/330602/330603/330604/330851/130713µçÎÐÁ÷̽ͷ´«¸ÐÆ÷
330101/330102/330103/330104/330105/330106/330140/330141/330191/330192/330193/330194/330195/330196/330197/330198µçÎÐÁ÷̽ͷ´«¸ÐÆ÷
330701/330702/330703/330704/330705/330706/330707/330708/330709/330710µçÎÐÁ÷̽ͷ
330901/330902/330903/330904/330905/330906/330907/330908/330909/330910µçÎÐÁ÷̽ͷ
330600/330180/330780/330850/330300/330980ǰÖÃÆ÷
330630/330130/330190/330730/330854/330330/132501/330930ÑÓÉìµçÀÂ
PR6422/ PR6423/ PR6424/ PR6425/ PR6426ÎÐÁ÷´«¸ÐÆ÷CON011¡¢CON021¡¢CON031ǰÖÃÆ÷
TM0105/TM0180/TM0110/TM0120ÎÐÁ÷´«¸ÐÆ÷TM0182ǰÖÃÆ÷TM0181ÑÓ³¤µçÀÂ
MMS6110˫ͨµÀÖáÕñ²âÁ¿Ä£¿éMMS6120˫ͨµÀÍßÕñ²âÁ¿Ä£¿éMMS6210˫ͨµÀÖáÎ»ÒÆ²âÁ¿Ä£¿éMMS6220˫ͨµÀÖáÆ«ÐIJâÁ¿Ä£¿éMMS6312˫ͨµÀתËÙ¼üÏàÄ£¿éMMS6410˫ͨµÀ¸×ÕͲâÁ¿Ä£¿éMMS6418¾ø¶ÔÏà¶ÔÕͲî²âÁ¿Ä£¿éMMS6831RS485ͨѶµ¥ÔªMMS6823RS485ת»»Ä£¿éDOPSÈýÈ¡¶þתËÙ²âÁ¿ÏµÍ³
PT2010/11˫ͨµÀ»ú¿ÇÕñ¶¯(¼ÓËÙ¶È/ËÙ¶È/Î»ÒÆ)¼à²â±íPT2010/21˫ͨµÀÕñ¶¯¼à²â±íPT2010/22˫ͨµÀÖáÏòλÖüà²â±íPT2010/25˫ͨµÀ°Ú¶È/Æ«Ðļà²â±íPT2010/26˫ͨµÀÕͲî¼à²â±íPT2010/51˫ͨµÀתËÙ¼à²â±íPT2010/51D ˫ͨµÀתËÙ¼à²â±íPT2010/53 ÈýÈßÓ೬ËÙ±£»¤±íPT2010/62˫ͨµÀ»ú¿ÇÅòÕͼà²â±í
MMS3110˫ͨµÀÖáÕñ±äËÍÆ÷MMS3120˫ͨµÀÍßÕñ±äËÍÆ÷MMS3210˫ͨµÀÖáÎ»ÒÆ±äËÍÆ÷MMS3311˫ͨµÀתËÙ¼üÏà±äËÍÆ÷MMS3410˫ͨµÀ¸×ÕͱäËÍÆ÷
DTM10 ÎÐÁ÷´«¸ÐÆ÷¼à²âÄ£¿éDTM10-201¾¶ÏòÕñ¶¯¼à²â±íDTM10-202ÖáÏòÎ»ÒÆ¼à²â±í
DTM10-301¾¶ÏòÕñ¶¯¼à²â±íDTM10-302ÖáÏòÎ»ÒÆ¼à²â±íDTM10-501תËÙ/¼üÏà¼à²â±í
DTM10-502תËÙ/¼üÏà¼à²â±íDTM20ÖÇÄÜÊý×Ö»ú¿ÇÕñ¶¯¼à²â±íDTM20-101»ú¿ÇÕñ¶¯¼à²â±í
TM900µçԴת»»Æ÷TM101 ¼ÓËÙ¶È¡¢ËÙ¶È¡¢Î»ÒÆÕñ¶¯±£»¤±íTM201ÖáÕñ¶¯±äËͱ£»¤±í
TM202ÖáλÖÃÕͲî±äËͱ£»¤±íTM301ÖáÕñ¶¯±äËͱ£»¤±íTM302ÖáλÖñäËͱ£»¤±í
TM501תËÙ¼üÏà¼à²â±íTM502תËÙ¼üÏà¼à²â±í
CZJ-B2/CZJ-B3/CZJ-B3G/CZJ-B4/CZJ-B4G/CZ-6/CJZ-D/CJZ-D2/MLI-2001/WB-9902/WB-8112B/ZJ2/ZJ2-A/ÖáÍßÕñ¶¯¼àÊÓ±£»¤ÒÇ
8500/85100XY/85564/85200/85850BCD-21A/VIBROCONTROL110/ EN900/EN2000A1/Õñ¶¯¼à¿ØÒDZí
ZXP-F3200/ZXP-J116/ZXP-J200/ZXP-J210/ZXP—J220/DZX-400/PDM1201/WLI-2004/WLI-2003/W PDM1201/LI-2001/S2662/ VRS2000A11/ WLI-2011/PT2010/11˫ͨµÀÖá³ÐÕñ¶¯¼à²âÒÇ
ZXP-J400/ZXP—J510/ZXP—J520/XD-2/XZK-1/OD-9008S/˫ͨµÀÍ߸ÇÕñ¶¯²âÁ¿ÒÇ
OD9004/S2162/S2112/VB-Z420/VB-Z430/VRS2000A11/VRS2000A1Õñ¶¯¼à²âÒÇ
VRS2000A3/VRS2000A4ST-101/EMT226/VIB-10b/VIB-5/ZDY/PT908/SJ-2011Öá³ÐÕñ¶¯¼à²âÒDZí
SJ-2012/SJ-2031/SJ-2021/SJ-2022/SJ-2051/SJ-2052/ TK77/ TK81Õñ¶¯¼ì²â±£»¤ÒÇ
SZ-5/SZ-6/SZ-6B/TRLV/TM0793V/TM079VD/9200/74712/47633´ÅµçʽÕñ¶¯ËÙ¶È´«¸ÐÆ÷
CD-1/CD-2/CD-4/CD-4A/CD-6/CD-6A/CD-7-C/CD-7-S/CD-8/Í߸ÇÕñ¶¯´«¸ÐÆ÷
CD-21-2-C/CD-21-2-S/CD-21-T/CD-21C/S/BCD-21A/CD721/WINDÕñ¶¯ËÙ¶È´«¸ÐÆ÷
MLS-9/MLV-6/MLV-7/MLV-8/MLV-9200/MLV-9268/MLV-27/MT1/MT2T/MT3T/MT3M/Õñ¶¯´«¸ÐÆ÷
CS-CD-001/CS-CD-010/OD9200/OD9300/S6000/PR9266/PR9268/20/30/60/70/ÖáÍßÕñ¶¯´«¸ÐÆ÷
MLV-9200£¨16699/900£©/ 9200/74712/47633/HT-2ZD-24/ZD25/ZDFÖáÍßÕñ¶¯ËÙ¶È´«¸ÐÆ÷
VB-Z9500/VB-Z9600/SJ1061/SJ1062´ÅµçʽÕñ¶¯ËÙ¶È´«¸ÐÆ÷
TM0782A/TM0783A/CA-YD/YD/KD/TM0782A/WINH/MTA/PR9270/SHQ-25X/200150/200155/200157/200350/200355/ CA-GT¼ÓËÙ¶È´«¸ÐÆ÷
LVDTÎ»ÒÆ´«¸ÐÆ÷ 1000TD 2000TD 3000TD 4000TD 5000TD 6000TD
TR81/DWQZ/TRIN/7200/3300/PR6422/PR6423/PR6424/PR6425/PR6426/µçÎÐÁ÷Î»ÒÆ´«¸ÐÆ÷ǰÖÃÆ÷
SD081082/85811/TM0180/TM0105/TM0182/WINW/QH8500/SE/CWY-DO/ÖáÏòÎ»ÒÆ´«¸ÐÆ÷ǰÖÃÆ÷
KY8500/OD9000/9000XL/S2100/S2200/VB-Z9100/MLW3300/ WD220·Ç½Ó´¥Î»ÒÆ´«¸ÐÆ÷ǰÖÃÆ÷
RDZW-2Na/CZQZ/RDZW-2/RDZW-2N/WB-8501C/8521C/8531C/85300-DW/ÖáÏòÎ»ÒÆ¼àÊÓ±£»¤ÒÇ
85350/85710/EN2000A2/HY-01/TPM/DTPM/OD9006/S2102/ VRS2000A2/ÖáÏòÎ»ÒÆ¼ì²â¼à²âÒÇ
RDZW-2Na/CZQX/RDCZ/RDCZ-2/85710/HY-02/DEM/DDEM/S2161A/VRS2000A5/ HZWY-20AÕͲî¼àÊÓ±£»¤ÒÇ
SZCB-01/PR9376/SM-10/12/14/16/T-03/SZMB-5/9/SZMB-01´Å×èʽתËÙ´«¸ÐÆ÷
SMCB-01/S16/SMS-12/16/E12-E12S-E58A-E58S/D12-D12P/F12A-F12S-F58A-F58S/Y12AD/DSD/DSF/DSE/DSH´ÅÃôʽ²âËÙ´«¸ÐÆ÷
TD-02/TD-03/ZS-01/ZS-03/ZS-02/ZS-04/HK-16/CM16/S16/HB2032/SC12-20K/GVS³ÝÂÖתËÙ´«¸ÐÆ÷
DZC£02/DZC£02A/37506A/ HZQS-02A/HZQW-03A/HZC-12תËÙ±í
DM504/HY-ZS3/SZC-04F1/WZ-7A·´×ªËÙ¼ì²â¼à²â±£»¤±í
HY-ZS3F·´×ªËÙ´«¸ÐÆ÷
SZC-04/SZC-04B/SZC-04F/85700/85790/JMS/HY-01/XSM/DF9011ÖÇÄÜתËÙ±í¼àÊÓ±£»¤ÒÇ
XJP-10B/02A/42A/XSV-01/SQY01T/MFT/SQY11-04/RAS/SKY/SZC/SQYC/CS-1/SQY01/QYDPM/SQY08TDÖÇÄÜתËÙÊý×ÖÏÔʾÒÇ
AI-TEK(AIRPAX)/Tach-pak1Tach-pak3Tachtrol2Tachtrol3/MV-VI/TACHPAK 1/TACHPAK 3/TACHTROL 3ÖÇÄÜתËÙ¼à²âÒÇ
WZ-3C/WZ-1D/WZ-6A/AI-TEK(AIRPAX)/EN2000A3/ÖÇÄÜתËÙ²âÁ¿ÒÇ
HY-ZS1/HY-ZS2A/HY-BT1/HY-ZS2/HY-ZS3/HY-CS1/OD9001/S2183/S2181/ÖÇÄÜתËÙ±í
VB-Z410/VB-Z440/VB-Z470/ VRS2000A7/ XHF-201/WB-8581ÖÇÄܲâËÙÒÇ
DF9032ÈÈÅòÕͼàÊÓÒÇSW-2/TD-2ÐÍÎ»ÒÆ¼àÊÓÒÇ24765»ú¿ÇÅòÕÍ´«¸ÐÆ÷
3500/3300/7200/PT2060/PT2010/RMS700/MMS3000/MMS6000/VB4000/TN8000/WIN2000/VM600/EN8000/EN9000/MV2000/MV3000/S8100/8500/9000/ZXP—JK6600/S32000/S36000/8000BϵÁÐÐýת»úе¼àÊÓ±£»¤×°ÖÃ
SLMCD-21T/ WINYV/ ZD8133/ OD9200T/MLS/V-9/ FZB/YMLV/JX73/JX73ST/BJ230Ò»ÌåʽÕñ¶¯±äËÙÆ÷
TR2001/TR2011/TR2031/TR2061/TR2081/TRZF/TR95±äËÍÆ÷
DTM/TM101/TM201/TM202/TM301/TM302/TM501/TM502/±äËÍÆ÷
SLM/WINV/EN2000A4/EN2000A5/EN2000A6/±äËÍÆ÷
ZXP-T100/ZXP-T110/ZXP-T120/WZ£5A/WZ£5B/ZD24-ZF-1/ZD24-ZF-2±äËÍÆ÷
OD9200-B/S9210/S9220/S9260/S9860/02/S9820/02/S9881/01/JX5151/JX5121±äËÍÆ÷
VB-Z330/VB-Z310/VB-Z320/MMS3110/MMS3120/MMS3210/MMS3311/MMS3410/VRS20/MLV/D±äËÍÆ÷VIB-15a/HR-2000/TR4101/ SJ6011/SJ6021/SJ6031±äËÍÆ÷
TM0540/3300XL/WIN-400/HY-XY1/OD—9003(A/B)/S21310/VRS4000/XQ-15/DZ-30µçÎÐÁ÷̽ͷ¾²Ì¬Ð£ÑéÒÇ
VS-068/VS-069/VS-077/VS-079/VS-080/VS-168/VS-169/VS-177/VS-277/VS-288/VS-289Õñ¶¯ËÙ¶È´«¸ÐÆ÷ PR9266/10 PR9268/11 PR9266/12 PR9268/20/30 PR9268/60/70µç¶¯Ê½¾ø¶ÔÕñ¶¯´«¸ÐÆ÷ PR6418Ïà¶ÔÎ»ÒÆ´«¸ÐÆ÷PR9350µç¸ÐÊ½Î»ÒÆ´«¸ÐÆ÷PR9376תËÙ´«¸ÐÆ÷PR9270¼ÓËÙ¶È´«¸ÐÆ÷ TM0782A-K/TM0783A/TM0793V-K/TM079VDÕñ¶¯´«¸ÐÆ÷ SD-051/IN-081/IN-083/IN-084/IN-085/INA-081/INA-083/INA-085/DS-1051/DS-1052/DS-1053/DS-1054/SD-052/SD-053/SD-054/SD-081/SD-083/SD-084/SD-087/SD-088/SD-089/SDH-151/SDH-154/SD-161/ SD-164/WT-010/WT-025µçÎÐÁ÷´«¸ÐÆ÷»ù±¾ÔÀí£º¿ØÒDZí
SZ-4/SZ-5/SZ-6/SZ-6B/SZ-6C/SZ-6I/TRLV/TM0793V/TM079VD´ÅµçʽÕñ¶¯ËÙ¶È´«¸ÐÆ÷ CD-1/CD-2/CD-4/CD-4A/CD-6/CD-6A/CD-7-C/CD-7-S/CD-8/Í߸ÇÕñ¶¯´«¸ÐÆ÷ CD-21-2-C/CD-21-2-S/CD-21-T/CD-21C/S/BCD-21A/CD721/WINDÕñ¶¯ËÙ¶È´«¸ÐÆ÷ MLS-9W/MLV-9W/MLV-6/MLV-7/MLV-8/MLV-9200/MLV-9268/MLV-27/MT1/MT2T/MT3T/MT3MÕñ¶¯´«¸ÐÆ÷ CS-CD-001/CS-CD-010/OD9200/OD9300/S6000/PR9266/PR9268/20/30/60/70/ÖáÍßÕñ¶¯´«¸ÐÆ÷ MLV-9200£¨16699/900£©/9200/74712/47633/HT-2ZD-24/ZD25/ZDFÖáÍßÕñ¶¯ËÙ¶È´«¸ÐÆ÷ VB-Z9500/VB-Z9600/SJ1061/SJ1062´ÅµçʽÕñ¶¯ËÙ¶È´«¸ÐÆ÷ TM0782A/TM0783A/CA-YD/YD/KD/TM0782A/WINH/MTA/PR9270/SHQ-25X/200150/200155/200157/200350/200355/CA-GT¼ÓËÙ¶È´«¸ÐÆ÷ LVDTÎ»ÒÆ´«¸ÐÆ÷ 1000TD 2000TD 3000TD 4000TD 5000TD 6000TD RDZW-2Na/CZQZ/RDZW-2/RDZW-2N/WB-8501C/8521C/8531C/85300-DW/ÖáÏòÎ»ÒÆ¼àÊÓ±£»¤ÒÇ 85350/85710/EN2000A2/HY-01/TPM/DTPM/OD9006/S2102/VRS2000A2/ÖáÏòÎ»ÒÆ¼ì²â¼à²âÒÇ RDZW-2Na/CZQX/RDCZ/RDCZ-2/85710/HY-02/DEM/DDEM/S2161A/VRS2000A5/HZWY-20AÕͲî¼àÊÓ±£»¤ÒÇ SZCB-01/PR9376/SM-10/12/14/16/T-03/SZMB-5/9/SZMB-01´Å×èʽתËÙ´«¸ÐÆ÷ SMCB-01/S16/SMS-12/16/E12-E12S-E58A-E58S/D12-D12P/F12A-F12S-F58A-F58S/Y12AD/DSD/DSF/DSE/DSH/km115-1/km115-2/km115-3/km115-4/´ÅÃôʽ²âËÙ´«¸ÐÆ÷ TD-02/TD-03/ZS-01/ZS-03/ZS-02/ZS-04/HK-16/CM16/S16/HB2032/SC12-20K/GVS³ÝÂÖתËÙ´«¸ÐÆ÷ DZC£02/DZC£02A/37506A/HZQS-02A/HZQW-03A/HZC-12תËÙ±í DM504/HY-ZS3/SZC-04F1/WZ-7A·´×ªËÙ¼ì²â¼à²â±£»¤±í HY-ZS3F·´×ªËÙ´«¸ÐÆ÷ SZC-04/SZC-04B/SZC-04F/85700/85790/JMS/HY-01/XSM/DF9011ÖÇÄÜתËÙ±í¼àÊÓ±£»¤ÒÇ XJP-10B/02A/42A/XSV-01/SQY01T/MFT/SQY11-04/RAS/SKY/SZC/SQYC/CS-1/SQY01/QYDPM/SQY08TDÖÇÄÜתËÙÊý×ÖÏÔʾÒÇ AI-TEK(AIRPAX)/Tach-pak1/Tach-pak2/Tach-pak3/Tachtrol1/Tachtrol2/Tachtrol3/MV-VI/TACHPAK1/TACHPAK1/TACHPAK2/TACHPAK3ÖÇÄÜתËÙ¼à²âÒÇ WZ-3C/WZ-1D/WZ-6A/AI-TEK(AIRPAX)/EN2000A3/ÖÇÄÜתËÙ²âÁ¿ÒÇ HY-ZS1/HY-ZS2A/HY-BT1/HY-ZS2/HY-ZS3/HY-CS1/OD9001/S2183/S2181ÖÇÄÜתËÙ±í VB-Z410/VB-Z440/VB-Z470/VRS2000A7/XHF-201/WB-8581ÖÇÄܲâËÙÒÇ DF9032ÈÈÅòÕͼàÊÓÒÇSW-2/TD-2ÐÍÎ»ÒÆ¼àÊÓÒÇ24765»ú¿ÇÅòÕÍ´«¸ÐÆ÷ 3500/3300/7200/PT2060/PT2010/RMS700/MMS3000/MMS6000/VB4000/TN8000/WIN2000/VM600/EN8000/EN9000/MV2000/MV3000/S8100/8500/9000/ZXP—JK6600/S32000/S36000/8000BϵÁÐÐýת»úе¼àÊÓ±£»¤×°Öà ZHS-9/ZHV-9/SLMCD-21T/WINYV/ZD8133/OD9200T/MLS/V-9/FZB/YMLV/JX73/JX73ST/BJ230Ò»ÌåʽÕñ¶¯±äËÙÆ÷ TR2001/TR2011/TR2031/TR2061/TR2081/TRZF/TR95±äËÍÆ÷ DTM/TM101/TM201/TM202/TM301/TM302/TM501/TM502/±äËÍÆ÷ SLM/WINV/EN2000A4/EN2000A5/EN2000A6/±äËÍÆ÷ ZXP-T100/ZXP-T110/ZXP-T120/WZ£5A/WZ£5B/ZD24-ZF-1/ZD24-ZF-2±äËÍÆ÷ OD9200-B/S9210/S9220/S9260/S9860/02/S9820/02/S9881/01/JX5151/JX5121±äËÍÆ÷ VB-Z330/VB-Z310/VB-Z320/MMS3110/MMS3120/MMS3210/MMS3311/MMS3410/VRS20/±äËÍÆ÷ MLV/DVIB-15a/HR-2000/TR4101/SJ6011/SJ6021/SJ6031±äËÍÆ÷ TK3-2/TM0520-K/WX-9292/JX-3B/S21330/S21320/OD9002/V503/V505/CIJ-J30/CIJ-J20/HV-520/VB-Z8901/DX-02/VRS5000/SE-11/SE-41/PJD/VRS2000Õñ¶¯Ð£Ñę́µçÎÐÁ÷̽ͷУ׼ÒÇ TM0540/3300XL/WIN-400/HY-XY1/OD—9003(A/B)/S21310/VRS4000/XQ-15/DZ-30µçÎÐÁ÷̽ͷ¾²Ì¬Ð£ÑéÒÇTM0182-A50-B00-C00µçÎÐÁ÷ÖáÎ»ÒÆ´«¸ÐÆ÷ÖáÆûÂÖ»ú/·ç»úÕñ¶¯Ì½Í·Ç°ÖÃÆ÷SZCB£01
SG-2Õñ¶¯´«¸ÐÆ÷CZJ-B2£¬Õñ¶¯¼àÊÓÒÇCZJ-B3,CZJ-B4,CZJ-B4G, CZJ-B3G Ë®ÂÖ·¢µç»ú×é״̬¼àZHJ-2 CS-1VB-Z9500TR2081תËÙ±äËÍÆ÷ HHT11-TR2081 תËÙ±äËÍÆ÷
VB-Z980008-01-01-10-80µçÎÐÁ÷Î»ÒÆ´«¸ÐÆ÷ ´ÅµçʽÕñ¶¯ËÙ¶È´«¸ÐÆ÷£¬SZ-6£¬SZ-4£¬ST-2£¬ST-3£¬VS-2£¬ZHJ-2
