主要特点:
全球通用全范围交流输入电压,
功率因素校正:0.98at115VAC;0.94at230VAC,
有短路、过载保护和过电压保护,
国际安规认证:UL/CUL/TUV/CB/CE,
自然风冷(100W),
直流风扇强制风冷(150W),
100%满载老化测试,
3年免费质保
主要指标:
交流输入电压范围:90~264VAC/127~370VDC
交流冲击电流: 45A/230V
直流调整范围:通道1:额定输出电压的-5~+10%
过载保护:过电流限制105%~150%,自动侦测,自动复原
过电压保护:通道1:5.75~6.75额定输出电压
初始化、上升、保持时间:230VAC满载时800ms,60ms,20ms
绝缘特性:输入端与输出端间:3KVAC,输入端与外壳间:1.5KVAC1分钟
工作温度:-10~60℃(参考输出曲线)
安全标准:通过UL1950,TUV,EN60950认证
EMC标准:EN550022 class B,EN61000-3-2,3 EN61000-4-2,3,4,5,6,11,ENV50204
接线方式:7.5mm带盖端子排
外形尺寸:199×99×50mm
型号 输出 容差 纹波 效率 最大功率
QP-100B 5V,2.0~10A ±3% 120mV 77% 100W
12V,0.3~4.0A ±8% 150mV
-5V,0.0~1.0A ±5% 200mV
-12V,0.0~1.0A ±8% 150mV
QP-100C 5V,2.0~10A ±3% 120mV 77% 103W
15V,3.0~3.0A ±8% 180mV
-15V,0.0~1.5A ±8% 200mV
-5V,0.0~1.0A ±5% 150mV
QP-100D 5V,2.0~10A ±3% 100mV 78% 101W
12V,0.3~3.0A ±3% 150mV
24V,0.3~2.0A ±6% 150mV
-12V,0.0~1.0A ±5% 150mV
QP-100F 5V,2.0~10A ±3% 100mV 78% 101W
15V,3.0~3.0A ±3% 150mV
-15V,0.0~1.0A ±5% 100mV
QP-100-3A 5V,2.0~10A ±3% 100mV 74% 99W
3.3V,0.0~10A ±3% 150mV
+12V,0.3~3.0A ±6% 150mV
-5V,0.0~1.0A ±5% 100mV
QP-100-3B 5V,0.0~10A ±3% 120mV 74% 100W
+3.3V,0.0~10A ±3% 150mV
+12V,0.3~3.0A ±6% 200mV
QP-100-3C 5V,2.0~10A ±3% 120mV 75% 100W
+3.3V,0.0~10A ±3% 180mV
+15V,0.3~2.0A +8,-6% 200mV
-15V,0.0~1.0A ±5% 150mV
QP-100-3D 5V,2.0~10A ±3% 120mV 75% 100W
+3.3V,0~10A ±3% 180mV
+24V,0.3~2.0A ±6% 200mV
更详细资料请查本公司网站或电话咨询
