主要特点:
全球通用全范围交流输入电压,
功率因素校正:0.98at115VAC;0.95at230VAC,
有短路、过载保护和过电压保护,
国际安规认证:UL/CUL/TUV/CB/CE,
自然风冷,,
134KHz固定开关频率,
电源工作正常/失效信号输出(选件),,
100%满载老化测试,
3年免费质保
主要指标:
交流输入电压范围:90~264VAC/120~370VDC
交流冲击电流:冷启动,20A/115V,40A/230V
直流调整范围:通道1:额定输出电压的-5~+10%
过载保护:73~105W,自动侦测,自动复原
过电压保护:3.3V为3.6V~4.3V; 5V为5.75V~6.75V
漏电流:240VAC时小于1mA
初始化、上升、保持时间:230VAC满载时800ms,50ms,16ms
绝缘特性:输入端与输出端间:3KVAC,输入端与外壳间:1.5KVAC1分钟
工作温度:-10~40℃at70%,60℃at50%负载(无风扇);
-10~50℃at100%,60℃at80%负载(带17CFM风扇);
安全标准:通过UL1950,TUV, EN60950认证
EMC标准:EN550022 class B,EN61000-3-2,3 EN61000-4-2,3,4,5,6,8,11;ENV50204
接线方式:8+5P/3.96mm插脚, P/N:B5/8P-VH
外形尺寸:177.8×107.95×40.64mm
重量及包装:0.5公斤/只;每箱24只/13公斤/0.0376立方米
* 四组输出
型号 输出 容差 纹波 效率 最大功率
PPQ-1003A +3.3V,0.0~15A ±3% 100mV 72% 108W
+5V,2.0~15A ±3% 100mV
+12V,0.2~3.0A ±6% 150mV
-5V,0.0~1.0A ±6% 100mV
PPQ-1003B +3.3V,0.0~15A ±3% 100mV 72% 110W
-12V,0.0~1.0A ±6% 120mV
PPQ-1003C +3.3V,0.0~15A ±3% 100mV 72% 110W
+15V,0.2~3.0A +10,-5% 180mV
-15V,0.0~1.0A ±6% 150mV
PPQ-1003D +3.3V,0.0~15A ±3% 100mV 72% 114W
+24V,0.0~1.0A ±6% 150mV
PPQ-100B +5V,0.0~15A ±3% 100mV 75% 101W
+12V,0.3~4.0A ±8% 150mV
-5V,0.0~1.0A ±5% 100mV
-12V,0.0~1.0A ±5% 100mV
PPQ-100C +5V,2.0~15A ±3% 100mV 76% 101W
+15V,0.3~4.0A -6,+10% 150mV
-15V,0.0~1.0A ±5% 100mV
PPQ-100D +5V,2.0~10A ±3% 100mV 78% 102W
+12V,0.3~1.0A ±5% 100mV
+24V,0.0~4.0A ±8% 200mV
更详细资料请查本公司网站或电话咨询
