ABB自动化提升产业效率
高性能工业机器人
产品名称:
高性能工业机器人
型  号:
IRB 6400RF
价  格:
0.00
ABB
高性能工业机器人
IRB 6400R在同类机器人精确度最高、刚度最大,非常适合用于铝铸件的清理及预加工等场合。
  • 可靠性强——正常运行时间长
    采用成熟设计,维护工作量降至最低,正常工作时间长。
  • 安全性佳——安全的投资
    先进运动控制功能和碰撞检测功能可显著减小工具或工件的损坏风险。
  • 速度快——操作周期时间短
    采用ABB独有的控制技术,机器人始终能够根据实际载荷对加速度和减速度进行优化,尽可能缩短操作周期时间。
  • 精度高——零件生产质量稳定
    具有一流的路径跟踪精度和重复定位精度(RP=1.0mm),配套使用ABB TrueMove功能,该机器人不论速度如何,均可保持运行路径始终不变。
  • 坚固耐用——适合恶劣生产环境
    IRB 6400R机器人采用材料强度很高的全钢结构,其手臂经过机械平衡处理并配有双轴承。铸造专家型器人的整个机械臂达到IP67级密闭性,耐高压蒸汽清洗,非常适合应用于恶劣生产环境。
机器人版本, IRB
    到达距离
承重能力
6400R/2.5-200
    2.5 m
200 kg
6400R/2.8-200
    2.8 m
200 kg
工作范围
Validation Ver.
DXF
DWG
2D
SAT SW STEP PARA-
SOLID
VDA IGES STL VRML ROB
CAD
Robot
Studio
IGRIP
300-100   compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
  sim
PDF  REV1
300-100 compl compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
sim sim
280-200   compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl   sim
PDF  REV1
280-200 compl compl
joint
compl
joint
compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
sim sim
280-150   compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
  sim
PDF  REV1
280-150 compl compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
sim sim
250-200   compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
  sim
PDF  REV1
250-200 compl compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
sim sim
250-150   compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
  sim
PDF  REV1
250-150 compl compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
sim sim
250-120   compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
  sim
PDF  REV1
250-120 compl compl
joint
compl
joint
compl
joint
compl
joint
joint compl
joint
compl
joint
compl
joint
sim sim
Note! Revision 2 has a larger counter weight, hence larger circular diameter, than revision 1.
2D models are non-revision dependent, i.e. the version available covers all revisions of the robot.
ABB自动化相关产品:
机器人
ABB ACS150 变频器
水气单元
焊枪服务中心
机器人
外置式电缆包
变位机
IRB 360
IRB 140
焊枪清洁器
IRC5P
旋杯
机器人
ABB AC800F 集成软件(Freelance 100/Protronic控制器)
视觉系统
ABB S800 I/O
变位机
弧焊软件
更多ABB自动化产品...
联系我们
ABB中国服务中心
ABB中国服务中心启动运行,并提供“7*24小时”的支持服务。
我们希望以统一形象和整合的多渠道服务方式为您提供更便捷及高效的服务。
热线(国内): 800-820 9696, 400-820 9696
热线(国际): +86-21-3318 4688
