isee-
西门子与高通合作在工业环境中部署私有5G独立(SA)网络
http://www.gkong.com 2019-11-28 21:54 来源:
Siemens and Qualcomm collaborate to implement private 5G standalone (SA) network in industrial environment
November 27, 2019 - Siemens and Qualcomm Technologies have implemented the first private 5G standalone (SA) network in a real industrial environment using the 3.7-3.8GHz band. Both companies have joined forces in this project: Siemens is providing the actual industrial test conditions and end devices such as Simatic control systems and IO devices and Qualcomm is supplying the 5G test network and the relevant test equipment. The 5G network was installed in Siemens’ Automotive Showroom and Test Center in Nuremberg. Automated guided vehicles are (AGV) displayed here which are primarily used in the automotive industry. New manufacturing options and methods are also developed, tested and presented before they are put into action  on customer sites. This allows Siemens’ customers, such as automated guided vehicle manufacturers, to see the products interact live.
2019年11月27日——西门子和高通技术公司在真实工业环境中基于3.7-3.8GHz频段部署了首个私有5G独立组网(SA)网络。两家公司共同参与了该项目:西门子提供真实的工业测试条件和终端设备,例如Simatic控制系统和IO设备,而高通则提供5G测试网络和相关的测试设备。该5G网络已部署在纽伦堡的西门子汽车行业展厅和测试中心。这里展示主要是用于汽车行业的自动引导车(AGV)。在将其应用于客户现场之前,还将开发、测试和展示新的制造方式和方法。这样,西门子的客户(比如自动引导车制造商)就能够实时看到产品之间的交互。
The Automotive Showroom and Test Center enables Siemens and Qualcomm to test all the different technologies in a standalone 5G network under actual operating conditions and to come up with solutions for the industrial applications of the future. Qualcomm Technologies installed the 5G test system comprising infrastructure and end devices in less than three weeks. Siemens provided the actual industrial setup including Simatic control systems and IO devices.
通过行业汽车展厅和测试中心,西门子和高通可以在独立的5G网络中,在实际运行条件下测试所有不同的技术,并为未来的工业应用提供解决方案。高通在不到三周的时间内安装了包括基础设施和终端设备的5G测试系统。西门子提供了包括Simatic控制系统和IO设备在内的实际工业设备。
The German Federal Network Agency has reserved a total bandwidth of 100 MHz from 3.7 GHz to 3.8 GHz for use on local industrial sites. German companies are thus able to rent part of this bandwidth on an annual basis and to make exclusive use of it on their own operating sites in a private 5G network whilst also providing data protection. Siemens is using this principle to evaluate and test industrial protocols such as OPC UA and Profinet in its Automotive Showroom and Test Center together with wireless communication via 5G.
德国联邦网络管理局已保留从3.7 GHz到3.8 GHz的100 MHz总带宽供本地工业企业使用。因此,德国公司能够每年租用其中带宽,并在私有5G网络中在自己的运营站点上独家使用这部分带宽,从而获得数据保护。西门子正是利用这一原则在其汽车展厅和测试中心评估和测试5G无线通信环境下OPC UA和Profinet等工业协议的表现。
Siemens and Qualcomm Technologies have a collaboration focused on technological cooperation in wireless communication technologies. Amongst other things, this has resulted in the development of the Siemens Scalance portfolio for industrial wireless communication. With Qualcomm Technologies’ expertise in 5G technology, this collaboration continues to evolve seamlessly, leading to the standalone private 5G network in an industrial environment. This allows solutions to be tested and developed which industry will be able to use with the up-and-coming Release 16 of the 5G standard.
西门子和高通在无线通信技术中保持着技术合作。此外,该合作也促进了西门子工业无线通信产品组合Scalance的发展。借助高通在5G技术方面的专业知识,双方的合作将继续深入,从而打造工业环境中的独立专用5G网络。这使得对解决方案进行测试和开发之后,企业能够在即将推出的5G标准第16版发布后快速进行部署。
