罗克韦尔为扩大的功率范围提供伺服驱动技术
http://www.gkong.com 2006-03-24 16:29 《中华工控网》翻译
Rockwell Automation Offers Servo Drive Technology in Expanded Power Ranges
New high performance servo drives are designed for machinery applications requiring 22 to 150 kilowatt power.
新型高性能伺服驱动适用于22至150千瓦功率的机器应用
MILWAUKEE, March 23, 2006 — To support applications with the highest power requirements, such as Web handling, printing and converting, Rockwell Automation has expanded its family of servo drives with the new Allen-Bradley Kinetix 7000 drive. With continuous output power of 22 to 150 kilowatts, this new high-power servo drive seamlessly integrates with Allen-Bradley Logix controllers, servo motors and actuators to bring unmatched flexibility to machine design and unprecedented efficiency to the manufacturing floor.
密尔沃基3月23日消息—为了支持最高功率的需求,例如网站处理,印刷和炼钢,罗克韦尔增加了新型A-B Kinetix 7000驱动到其伺服驱动系列中。通过连续的22至150千瓦的输出功率,这个新型高功率伺服驱动与A-B的Logix控制器、伺服电机和传动器无缝的集成在一起,为生产厂家的机器设计带来无比的灵活性和空前的高效率。
"As part of Kinetix Integrated Motion, the Kinetix 7000 servo drives are part of a total, seamless motion control solution," said Patrick Liebsch, Kinetix 7000 product manager, Rockwell Automation. "With these drives, the benefits of Kinetix are extended to an even greater range of applications."
罗克韦尔Kinetix 7000产品经理Patrick Liebsch指出:“作为Kinetix集成运动的一部分,Kinetix 7000伺服驱动是一整个无缝运动控制解决方案的一部分。利用这些驱动,Kinetix的价值可以扩展到更大的应用范围。”
The Kinetix 7000 servo drives go beyond supporting synchronous permanent magnet motors, with asynchronous induction motor support as well. This gives customers a cost-effective alternative for motion control applications where higher power is needed.
Kinetix 7000不但支持同步永久磁性电机,同时也支持异步感应电机。这就使得顾客可以在需要高功率的运动控制应用中有了高性价比的选择。
In addition, the new TUV-certified Kinetix safe-off capability integrated in these drives can increase productivity by providing manufacturers and machine builders maximum machine availability. Maintenance tasks that previously required power down conditions can now be accomplished without removing power from the entire machine. As a result, customers enjoy faster machine restart and shorter machine downtime.
此外,TUV认证的新型Kinetix集成到这些驱动中的容量通过想生产商和机器制造者提供最大的机器实用性从而提高生产力。以前只能在关机的情况下才能实施的维护任务现在可以不需要把整机都关闭就可以完成了。这样,客户就可以更快地重起机器,缩短机器的停工时间。
The Kinetix 7000 servo drives are based on two high-quality foundations that have already been well-received in the marketplace – the Kinetix 6000 drives and the PowerFlex power structure. With the same I/O connections, wiring, fault code displays, and SERCOS interface communication, the Kinetix 6000 and 7000 servo drives provide customers with maximum commonality across machines and power ranges. This allows for easy configuration and deployment, leading to lower design, engineering and maintenance costs.
Kinetix 7000伺服驱动是在已经在市场收到欢迎的两款高质量机器—Kinetix 6000 驱动和PowerFlex的功率构造基础之上的。通过相同的I/O连接、配线、故障代码显示和SERCOS界面通讯,Kinetix 6000 和 7000 伺服驱动给客户提供最大的交叉式共性机器和功率范围。这就实现了简单配置和调度,从而降低了设计、工程和维护成本。
The advantages of the Kinetix 7000 drives are fully realized when they are paired with Allen-Bradley HPK-Series High Power Induction motors. The HPK-Series Motors were specifically engineered for optimized performance when used with the Kinetix 7000, allowing machine builders to extend the range of applications that use Kinetix Integrated Motion solutions. Rockwell Automation (NYSE: ROK), is a leading global provider of automation, power, control, and information solutions that help manufacturers achieve a competitive advantage in their businesses. Headquartered in Milwaukee, Wis., U.S.A., the company employs about 21,000 people serving customers in more than 80 countries
与A-B的HPK系列高功率感应电机配合使用将可以完全体现Kinetix 7000驱动的优势。当配合Kinetix 7000使用时,HPK系列电机作了特别的优化性能设置,允许机器制造者利用Kinetix集成运动解决方案扩大应用范围。罗克韦尔自动化是全球领先的自动化、动力、控制和信息解决方案供应商,致力于帮助生产商提升其业务竞争优势。公司总部位于美国威斯康星州密尔沃基市,公司雇员大约2万1千人,业务遍及全球80余个国家。
(本文由中华工控网翻译,转载请注明出处,更多中英对照资料请进异域来风http://world.gkong.com)
