KUKA机器人公司推出新型六轴机器人家族
http://www.gkong.com 2006-07-25 16:44 《中华工控网》翻译
KUKA Robotics introduces family of six-axis robots
KUKA机器人公司推出六轴机器人家族
New Compact Six Axis Robots Combined with KUKA User Friendly Controls Enables Easy to Implement Automation Solutions
新式紧凑型六轴机器人结合了KUKA的友好用户控制平台,实现容易执行自动化解决方案
Clinton Township, Michigan - July 24, 2006 - The KR5 Sixx robot family is designed for customers with applications requiring 6-axis functionality for long reach tasks. The new robots, when combined with KUKA Robotics’ user friendly PC-based control platform, gives customers an extremely easy to use and easy to learn pick and place automation solution. The new robots broaden the KUKA product line to include compact space-saving robots that are among the fastest and most reliable robots in their class.
密歇根州克林顿镇7月24日消息—KR5 Sixx机器人家族用于客户需要六个机械轴承担远伸程任务的应用。当与KUKA机器人公司基于PC的用户界面友好的控制平台结合的时候,该家族机器人可以让用户非常容易地使用和学习拣放自动化解决方案。这些新型机器人拓宽了KUKA的产品线,使其含括了在该最快和最可靠级别机器人中拥有了节省空间的紧凑型机器人。
"Customers with pick and place, assembly or material handling applications that require the flexibility of 6 axis will find the KUKA KR5 Sixx ideal," said Kevin Kozuszek, director of marketing for KUKA Robotics Corporation. "This compact robot and the user-friendly KUKA PC-based controller combine short cycle times and high accuracy with the dependability of KUKA controls."
KUKA机器人公司营销经理Kevin Kozuszek表示:“拣放、装配和材料处理等需要六轴灵活性应用的客户将会发现KUKA的KR5 Sixx 机器人是其理想选择。这款紧凑的机器人,以及KUKA用户友好的基于PC的控制器,通过KUKA控制的可靠性,结合了较短的周期时间和较高的精确度。”
The KUKA KR5 Sixx robot family includes 650mm and 850mm reach models and are capable of handling payloads up to 5kg. The 6 axis robots’ light weight gives the robot optimum acceleration and maximum working velocities.
KUKA的KR5 Sixx机器人家族包括臂程为650毫米和850毫米两种型号,最大有效负载均可达5千克。这些六轴机器人的较轻重量使得它们获得最合适的加速度和最大的工作速率。
KUKA Robotics Corporation, with its parent company KUKA Roboter GmbH, Augsburg, Germany, is one of the world's leading manufacturers of industrial robots, with an annual production volume approaching 10,000 units, and an installed base of over 75,000 units. The company’s 5 and 6 axis robots range from 3kg to 570kg payloads, and 635mm to 3700mm reach, all controlled from a common PC based controller platform. KUKA robots are utilized in a diverse range of industries including the appliance, automotive, aerospace, consumer goods, logistics, food, pharmaceutical, medical, foundry and plastics industries and in multiple applications including material handling, machine loading, assembly, packaging, palletizing, welding, bending, joining, and surface finishing.
美国KUKA机器人公司是位于德国奥格斯堡市KUKA Roboter 有限公司的子公司,是世界几家顶级工业机器人制造商之一。该公司工业机器人年产量接近1万台,至今已在全球安装了6万台工业机器人。该公司的5轴和6轴机器人负载量从3千克至570千克,机械臂伸程从635毫米到3700毫米,全部由一个普通的基于PC控制器平台控制。KUKA机器人广泛应用在仪器、汽车、航天、消费产品、物流、食品、制药、医学、铸造、塑料等工业上。主要应用于材料处理、机床装料、装配、包装、堆垛、焊接、表面修整等领域。
(本文由中华工控网翻译,转载请注明出处,更多中英对照资料请进异域来风http://world.gkong.com)
