西门子为俄罗斯超高压电力系统提供价值8千万欧元电力系统控制
http://www.gkong.com 2006-08-04 17:19 《中华工控网》翻译
Siemens to deliver power system control for Russian extra-high voltage power system - order valued at 80 million euros
Siemens Power Transmission and Distribution (PTD) is to supply state-of-the-art power system control to equip Russia’s extra-high voltage power system. In this way the System Operator-Central Dispatching Office for Unified Energy System of Russia (SO-CDU UES) is responding to the requirements of the deregulated Russian energy market. The new Siemens system will replace the existing systems and will add new functions. The use of the new system guarantees higher operating reliability of all equipment, a reduction of overall network losses and improved utilization of power plant capacity. The order has a value of about 80 million euros; commissioning is planned for the middle to end of 2008.
西门子电力传输和分配公司(PTD)正在为俄罗斯提供顶级的电力系统控制以装备其超高压电力系统。这样,该系统的操作者——俄罗斯统一电力系统中央分派办公室响应了管制解除之后俄罗斯电力市场的要求。这个新的西门子系统将取代现有的系统,而且将增加新的功能。新系统的使用保证了所有设备更高的操作可靠性,减少了整个网络的损失,提高了发电厂容量的利用率。这份合同价值大约8千万欧元,计划在2008年中后期进行调试。
Russia is not only the world’s largest country in terms of surface area. It also has one of the largest and most complex power networks in the world with correspondingly high requirements as regards data volume and the efficiency of the power system control. The complete system for the Russian 220-kV and 500-kV extra-high voltage system to be delivered by Siemens consists of the central power system control center in Moscow and seven supra regional control centers distributed across the whole of Russia. Two of these supra regional control centers are configured as backup control centers for the central power system control center.
俄罗斯不但是世界上国土面积最大的国家,它还拥有世界上最大和最复杂的电力网络之一,考虑到数据量和电力系统控制的效率,因而要求相对较高。西门子向俄罗斯220-kV 和 500-kV超高压系统提供的一整套系统包括位于莫斯科的中央电力系统控制中心以及七个分布于整个俄罗斯的区域控制中心。其中的两个区域控制中心是作为中央电力系统控制中心的后援控制中心而配置。
The power system control which is based on the latest Advanced-PowerCC architecture provides the necessary SCADA/EMS/EMM functions for real-time monitoring of the entire extra-high voltage network. Furthermore, the system provides all interfaces and programs for data exchange with the operator of the power trading system and all other market players such as distribution companies, producers and qualified users.
该电力系统控制基于最新的Advanced-PowerCC 架构,为整个超高压网络的实时监测提供了必要的SCADA/EMS/EMM 功能。此外,通过电力贸易系统工作者以及例如分销公司、生产者和用户等其他所有市场参与者,该系统为数据交换提供了所有的接口和程序。
The system operates with open standards such as the IEC 61970 standard for the CIM data model and the relevant program interfaces and with IEC 60870-5 and IEC 60870-6 for communication and data exchange with other systems. In this new project for Russia all data relating to the extra-high voltage network will also be gathered centrally in the internationally standardized CIM format for the first time. These standards create the basis for expansions such as are to be expected in an increasingly deregulated energy market. Siemens is making allowance for the specific requirements of the Russian market model for the deregulated energy market with energy management functions (EMS) and energy market management functions (EMM) matched specifically to the stipulations of the Russian market regulations.
该系统带有CIM数据模型IEC 61970标准等开放式标准和其它相关程序界面,以及通过IEC 60870-5 和 IEC 60870-6 与其它系统进行通信和数据交换。在俄罗斯这个新项目里,所有关于超高压网络的数据将首次按照国际标准化的CIM形式集中起来。这些标准创造了例如在一个不断解除管制的电力市场期待的扩张的基础。利用特定适合俄罗斯市场规则约束的能源管理功能(EMS)和能源市场管理功能(EMM),西门子正在为解除管制的能源市场制定符合俄罗斯市场特定要求的准许。
The Siemens Power Transmission and Distribution Group (PTD), headquartered in Erlangen, Germany, is one of the leading global players in its market sector. As a product supplier, system integrator, solution designer and service provider, Siemens PTD ensures - for utilities and industry alike - the efficient and reliable transmission of electrical energy from the power plant to the consumer. With a worldwide workforce of about 25,850 and operations in nearly 90 countries, PTD had sales of 4.3 billion euros in fiscal 2005 (ended September 30).
西门子电力传输和分配公司(PTD)总部位于德国Erlangen市,是行业内全球领先公司之一。作为一个产品供应商、系统集成商、解决方案设计者以及服务提供商,PTD保证了电力和相似行业从发电厂到用户之间电力有效且可靠的传输。PTD业务遍及全球近90个国家,员工大约25,850人,2005财年的销售收入为43亿欧元(截至9月30日)。
(本文由中华工控网翻译,转载请注明出处,更多中英对照资料请进异域来风http://world.gkong.com)
