http://www.gkong.com 2008-05-09 16:41 来源:发改委
标准号 |
英文题目 |
中文题目 |
技术机构 |
发布日期 |
适用指令 |
EN 50382-2:2008 |
Railway applications - Railway rolling stock high temperature power cables having special fire performance -- Part 2: Single core silicone rubber insulated cables for 120 °C or 150 °C |
铁路应用---铁路全部车辆有专门着火性能的高温动力电缆---第2部分:120 °C或150 °C单芯硅橡胶绝缘电缆 |
CLC/TC 20 |
2008-03-20 |
EN 50382-1:200 |
Railway applications - Railway rolling stock high temperature power cables having special fire performance -- Part 1: General requirements |
铁路应用---铁路全部车辆有专门着火性能的高温动力电缆---第1部分:总要求 |
CLC/TC 20 |
2008-03-20 |
EN 61158-5-13:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-13: Application layer service definition - Type 13 elements |
工业通信网络---现场总线规范---第5-13部分:应用层服务定义――类型13要素 |
CLC/TC 65CX |
2008-03-14 |
EN 61158-5-14:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-14: Application layer service definition - Type 14 elements |
工业通信网络---现场总线规范---第5-14部分:应用层服务定义――类型14要素 |
CLC/TC 65CX |
2008-03-14 |
EN 61158-5-15:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-15: Application layer service definition - Type 15 elements |
工业通信网络---现场总线规范---第5-15部分:应用层服务定义――类型15要素 |
CLC/TC 65CX |
2008-03-14 |
EN 61158-5-16:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-16: Application layer service definition - Type 16 elements |
工业通信网络---现场总线规范---第5-16部分:应用层服务定义――类型16要素 |
CLC/TC 65CX |
2008-03-14 |
EN 61158-5-17:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-17: Application layer service definition - Type 17 elements |
工业通信网络---现场总线规范---第5-17部分:应用层服务定义――类型17要素 |
CLC/TC 65CX |
2008-03-14 |
EN 61158-5-18:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-18: Application layer service definition - Type 18 elements |
工业通信网络---现场总线规范---第5-18部分:应用层服务定义――类型18要素 |
CLC/TC 65CX |
2008-03-14 |
EN 61158-5-19:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-19: Application layer service definition - Type 19 elements |
工业通信网络---现场总线规范---第5-19部分:应用层服务定义――类型19要素 |
CLC/TC 65CX |
2008-03-14 |
EN 61158-5-20:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-20: Application layer service definition - Type 20 elements |
工业通信网络---现场总线规范---第5-20部分:应用层服务定义――类型20要素 |
CLC/TC 65CX |
2008-03-14 |
EN 140101-806:2008 |
Detail Specification: Fixed low power film resistors - Metal film resistors on high grade ceramic, conformal coated or molded, axial or preformed leads |
详细规范:固定低功率膜电阻---高级陶瓷金属膜电阻,敷形涂覆或模塑,轴向或预制引线 |
CLC/TC 40XB |
2008-03-14 |
EN 61753-021-2:2008 |
Fibre optic interconnecting devices and passive components performance standard -- Part 021-2: Grade C/3 single-mode fibre optic connectors for category C - Controlled environment |
光学纤维连接器件和无源元件性能标准---第021-2部分: C/3级单模光纤连接器,C类—可控环境 |
CLC/TC 86BXA |
2008-03-14 |
EN 61228:2008 |
Fluorescent ultraviolet lamps used for tanning - Measurement and specification method |
制革用荧光紫外灯---测试和规范方法 |
CLC/SR 34A |
2008-03-14 |
EN 60901:1996/A4:2008 |
Single-capped fluorescent lamps - Performance specifications |
单帽荧光灯 |
CLC/SR 34A |
2008-03-14 |
EN 61158-5-12:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-12: Application layer service definition - Type 12 elements |
工业通信网络---现场总线规范---第5-12部分:应用层服务定义――类型12要素 |
CLC/TC 65CX |
2008-03-14 |
EN 61158-5-11:2008 |
Industrial communication networks - Fieldbus specifications - Part 5-11: Application layer service definition - Type 11 elements |
工业通信网络---现场总线规范---第5-11部分:应用层服务定义――类型11要素 |
CLC/TC 65CX |
2008-03-14 |
