最新推出一款FEBC-3530嵌入式工控机
http://www.gkong.com 2009-07-01 15:05 来源:深圳市集和诚科技开发有限公司
    集和诚嵌入式公司于5月新推出一款无风扇嵌入式箱体电脑(FEBC-3530),此款电脑支持四个千兆网口、MXM Support  、Intel Core 2 Duo T7500 2.2GHz Processor。即使复杂的环境,同样拥有闪电的的速度。 详细资料如下:
Features
●COM Express CPU模块采用 Intel 965GME 芯片组,支持Intel Core 2      Duo T7500 2.2GHz处理器
●两个DDRII SODIMM 插槽, 最大支持4GB内存
●COM x 4, USB 2.0 x 4
●4个千兆RJ-45网口
●2个SATA-II接口,2个2.5寸硬盘架
●DVI-I x 1(VGA By Y Cable)
●MXM Support-PCI-Express界面的图形处理器接口
●两个PCI扩展
●ATX Power Function-ATX方式供电
系统规格
 Processor-Intel T7500 2.2GHz processor
 System Memory-DDRII SDRAM SODIMM x 2, Max. 4GB.
 Expansion-PCI x 2
 VGA/ Keyboard/ Mouse -DVI-I x 1 (DB-15 VGA Connector by VGA adapter), PS/2 Keyboard & Mouse x 1
 Ethernet-Gigabit Ethernet, RJ-45 x 4
 SSD-CompactFlash Socket x 1
 Hard Disk Storage-SATA/IDE Hard Disk Drive bracket x 2(SATA II Port x2 Support Raid 0/Raid 1)
 Serial Port-COM x 4(RS232/422/485x2, RS232x2)
 Audio-Line-in x 1, Line-out x 1, Mic-in x 1 by extend cable
 USB-USB2.0 x 4
 System Control-Power switch x 1,Reset switch x 1
 LED Indicator-Power LED x 1, Hard Disk Drive LED x 1
 Watchdog Timer-Generates a Time-out System Reset, setting via Software
 Power Supply-1. ATX Power function
 2. DC Input 9-30 (Phoenix connector 3 pin)
 3. Power Board Support (80W)operation output
 4. Optional AC power adapter , input voltage range 100~240 V
 Power Consumption-Intel Core 2 Duo 2.2GHz (T7500), 1.97A @ DC19V+17W=53.43W
 MTBF (Hours)-32,000
 OS Support-Windows CE 6.0, Windows XP Pro, Windows XP Embedded, Linux Red Hat, Windows Vista
结构规格
 Construction-Rugged Aluminum Alloy Chassis
 Color-White & Black
 Mounting-Wall mount/Desk top
 Dimension-214mm x 99.2mmx 237.5mm
 Net Weight-5.63Kg
 环境规格
 Operating Temperature--15℃ ~ 60℃ (CFD with a RAM Module)
 -10℃ ~ 55℃( Hard Disk Drive with a RAM Module)
 Storage Temperature--20℃ ~ 70℃
 Storage Humidity-5 ~ 95% @ 40℃, non-condensing
 Vibration-5g rms / 5 ~ 500Hz / operation  CFD
 1g rms / 5 ~ 500Hz / operation  HDD
 Shock-50g peak acceleration (11 msec. duration)  CFD
 EMC-CE/FCC Class A
