http://www.gkong.com 2011-10-02 16:33 来源:杭州东田科技有限公司
艾讯宏达即将推出一款采用英特尔G41芯片组的ATX主板SYM76941VGGA。
SYM76941VGGA采用Socket LGA775架构,支持英特尔酷睿4核/酷睿2双核/奔腾D/赛扬D处理器。采用英特尔G41+ICH7(或ICH7R)芯片组,最大支持8GB DDR3 内存。集成2个英特尔82574E PCI-E千兆网络控制器,6个RS232串口,8个USB2.0接口;支持1 个 PCI-EX16, 1个 PCI-EX1, 5 个 PCI扩展槽。
详细规格: >> System Processor Socekt LGA775 Support Core 2 Quad Q9000 Series/Core 2 Duo/ Pentium D/Celeron D Chipset Intel G41 + ICH7/ ICH7R(option by MOQ), FSB 800/1066/1333MHz DRAM 2 x 240PIN DIMM DDR3 800/1066 max up to 8GB BIOS 8Mb AMI Flash ROM Power Supply 1 x 24Pin ATX power connector, support AT/ATX mode Watchdog Watchdog timer function (Reset: 1~65535 level) Dimension >> I/O Ports HDD 4 x SATA-300 Interface, support RAID FDD 1 x FDD port Parallel 1 x Parallel pin-header Audio Realtek ALC662 HD audio codec, support 5.1CH audio Keyboard/Mouse 2 x PS/2 for Keyboard and Mouse LAN 2 x Intel USB 8 x USB2.0 (4 by onboard header) Digital I/O 4 input; 4 output Expansion 1 x PCIeX16, 1 x PCIeX1, 5 x PCI slots Expansion >> Display Graphics Intel GMA X4500, Max. shared system memory up to 1759MB VGA 2048 x 1536 maximum resolution DVI 2048 x 1536 maximum resolution >> Environment Operation Temperature 0°~ Humidity 10~90% SYM76941VGGA主板具备高性价比特点,即将量产,敬请期待!
