美卡诺可调的监视器支撑臂
http://www.gkong.com 2019-05-13 10:07 来源:美卡诺元器件(上海)有限公司
Height adjustable monitor support arms (400 mm travel)
Easy manual height adjustment and positioning via a spring-loaded fixing bolt
1
The connecting technology division has added two new support arm models to the RK monitor mounting systems product portfolio.
2
The twin and telescopic support arms are now both available in a height adjustable version. Mounted on a vertical holder, the support arms can be manually adjusted over a range of 400 mm. By simply pulling out and holding the fixing bolt, the support arm can be freely moved to the required height. On release, the fixing bolt then locks the support arm in the selected position. The height adjustment feature is particularly useful for ergonomic workstations.
3
