Integrated Application of Delta Electromechanical Product in Packing Machine of Aluminum-Plastc Froth Cover 中达电通上海机电HMI/PLC产品处 赵越锦 Zhao Yuejin 摘 要:简述了铝塑泡罩包装机的工作原理,介绍了台达变频器、PLC、触摸屏及温控器模块在高速铝塑泡罩包装机上的整合应用,最后概略地讨论了泡罩包装机的工艺控制要求和控制相关问题。 关键词:制药包装机械 PLC 触摸屏 变频器 Modbus通讯 Abstract: It is simply described to the working principle of packing machine for Aluminum-plastc froth cover in this paper. And also it is intruduced to the integrated application of Delta inverter, PLC, intouch screen and temperature controller module in high speed packing machine for Aluminum-plastc froth cover. Finally it is roughly discussed to the technology control demand and the related control prolems of froth cover packing machine. Key Words: Pharmacy packing mechanism PLC Intouch screen Interver Modbus communication [中图分类号] TP273 [文献标识码] B 文章编号 1 引言 铝塑泡罩包装是目前药机行业中主要的产品包装方式,绝大部分片式成品药最后都需要经过此工序才能作为产品在市场销售。其工作过程是将各种药片用PVC成型包装于铝塑板上,适用于各种规格的片剂、胶囊、胶丸、素片及各种异型片。为实现大小形状各不相同药片的高速包装,要求控制系统具有高速、准确、协调的控制功能,台达机电产品的整合应用正是符合这些要求的一个综合解决方案,它可使包装效率由一般150板/分钟提高到200板/分钟, 铝塑泡罩包装机如图1所示。
