----中达电通上海机电业务处 李强
   摘  要: 局限于技术条件,目前生产中在统计生产产品产量方面不少还是依靠人工进行统计。在实际操作过程中,往往出现产品严重丢失,投入的原料量和产出的成品量严重失衡,因此,有必要采用工厂产量监控查询系统对整个工厂的产品产量进行准确的计量,文章基于台达PLC与组态软件技术,成功开发了一个工厂产量监控查询系统。
 关键字: PLC  组态软件  监控查询系统
 Abstract: Limited to the technical conditions,it makes statistic of production output still to be depended on manual work in factory product output statistic for the production process. It always appears that the product  loses graveness and the input of raw material does not balance with product quantity of output in the pratical manipulation process. Therefore it is necessary to use Querying System of Factory Output Monitoring for accuracy measure of product output in whole factory. The paper discussed that it is made good winning  to querying system of factory output monitoring based on Delta PLC.
 1 引 言
 2 系统结构与功能 图1  产量查询系统结构示意图
 3 系统设计
   工厂产量监控查询系统的设计主要在于软件系统的设计,以下问题是考虑的重点。
 4 系统调试考虑
 5 结束语
 参考文献[略]
 作者简介
