产品名称: CPU224XPDC/DC/DC14输入/10输出集成2AI/1AO
型  号: 6ES72142AD230XB8
6ES72110AA230XB0    SIMATIC S7-200 CPU211,DC/DC/DC,6输入/4输出
6ES72110BA230XB0    SIMATIC S7-200 CPU211,AC/DC/Rly,6输入/4输出
6ES72121AB230XB0    SIMATIC S7-200 CPU222,DC/DC/DC,8输入/6输出
6ES72121BB230XB0    SIMATIC S7-200 CPU222,AC/DC/Rly,8输入/6输出
6ES72141AD230XB0    SIMATIC S7-200 CPU224,DC/DC/DC,14输入/10输出
6ES72141BD230XB0    SIMATIC S7-200 CPU224,AC/DC/Rly,14输入/10输出
6ES72142AD230XB0    SIMATIC S7-200 CPU224XP,DC/DC/DC,14输入/10输出,集成2AI/1AO
6ES72142AS230XB0    SIMATIC S7-200 CPU224XPsi,DC/DC/DC,14输入/10输出,集成2AI/1AO
6ES72142BD230XB0    SIMATIC S7-200 CPU224XP,AC/DC/Rly,14输入/10输出(NPN输出),集成2AI/1AO
6ES72162AD230XB0    SIMATIC S7-200 CPU226,DC/DC/DC,24输入/16输出
6ES72162BD230XB0    SIMATIC S7-200 CPU226,AC/DC/Rly,24输入/16输出
6ES72121AB230XB8    S7-200CN CPU222,DC/DC/DC,8输入/6输出
6ES72121BB230XB8    S7-200CN CPU222,AC/DC/Rly,8输入/6输出
6ES72141AD230XB8    S7-200CN CPU224,DC/DC/DC,14输入/10输出
6ES72141BD230XB8    S7-200CN CPU224,AC/DC/Rly,14输入/10输出
6ES72142AD230XB8    S7-200CN CPU224XP,DC/DC/DC,14输入/10输出,集成2AI/1AO
6ES72142AS230XB8    S7-200CN CPU224XPsi,DC/DC/DC,14输入/10输出,集成2AI/1AO
6ES72142BD230XB8    S7-200CN CPU224XP,AC/DC/Rly,14输入/10输出(NPN输出),集成2AI/1AO
6ES72162AD230XB8    S7-200CN CPU226,DC/DC/DC,24输入/16输出
6ES72162BD230XB8    S7-200CN CPU226,AC/DC/Rly,24输入/16输出
6ES72211BF220XA0    SIMATIC S7-200, EM221 数字量输入模块, 8输入24V DC
6ES72211BH220XA0    SIMATIC S7-200, EM221 数字量输入模块, 16输入24V DC
6ES72211EF220XA0    SIMATIC S7-200, EM221 数字量输入模块, 8输入 交流120/230V AC
6ES72221BD220XA0    SIMATIC S7-200, EM222 数字量输出模块,4输出24V DC 5A
6ES72221BF220XA0    SIMATIC S7-200, EM222 数字量输出模块,8输出24V DC
6ES72221EF220XA0    SIMATIC S7-200, EM222 数字量输出模块,8输出 交流120/230V AC
6ES72221HD220XA0    SIMATIC S7-200, EM222 数字量输出模块,4输出继电器 10A
6ES72221HF220XA0    SIMATIC S7-200, EM222 数字量输出模块,8输出继电器
6ES72231BF220XA0    SIMATIC S7-200, EM223 数字量输入/输出模块,4输入 24V DC/4输出 24V DC
6ES72231BH220XA0    SIMATIC S7-200, EM223 数字量输入/输出模块,8输入 24V DC/8输出 24V DC
6ES72231BL220XA0    SIMATIC S7-200, EM223 数字量输入/输出模块,16输入 24V DC/16输出 24V DC
6ES72231BM220XA0    SIMATIC S7-200, EM223 数字量输入/输出模块,32输入 24V DC/32输出 24V DC
6ES72231HF220XA0    SIMATIC S7-200, EM223 数字量输入/输出模块,4输入 24V DC/4输出继电器
6ES72231PH220XA0    SIMATIC S7-200, EM223 数字量输入/输出模块,8输入 24V DC/8输出继电器
6ES72231PL220XA0    SIMATIC S7-200, EM223 数字量输入/输出模块,16输入 24V DC/16输出继电器
6ES72231PM220XA0    SIMATIC S7-200, EM223 数字量输入/输出模块,32输入 24V DC/32输出继电器
6ES72310HC220XA0    SIMATIC S7-200, EM231 模拟量输入模块,4输入
6ES72310HF220XA0    SIMATIC S7-200, EM231 模拟量输入模块,8输入
6ES72317PB220XA0    SIMATIC S7-200, EM231 热电阻模块,2输入
6ES72317PC220XA0    SIMATIC S7-200, EM231 热电阻模块,4输入
6ES72317PD220XA0    SIMATIC S7-200, EM231 热电偶模块,4输入
6ES72317PF220XA0    SIMATIC S7-200, EM231 热电偶模块,8输入
6ES72320HB220XA0    SIMATIC S7-200, EM232 模拟量输出模块,2输出
6ES72320HD220XA0    SIMATIC S7-200, EM232 模拟量输出模块,4输出
6ES72350KD220XA0    SIMATIC S7-200, EM235 模拟量输入输出模块,4输入/1输出
6ES72531AA220XA0    SIMATIC S7-200, EM253 定位模块
6ES72770AA220XA0    SIMATIC S7-200, EM277 Profibus-DP 从站模块
6ES72211BF220XA8    S7-200CN, EM221 数字量输入模块, 8输入24V DC
6ES72211BH220XA8    S7-200CN, EM221 数字量输入模块, 16输入24V DC
6ES72221BF220XA8    S7-200CN, EM222 数字量输出模块,8输出24V DC
6ES72221HF220XA8    S7-200CN, EM222 数字量输出模块,8输出继电器
6ES72231BF220XA8    S7-200CN, EM223 数字量输入/输出模块,4输入 24V DC/4输出 24V DC
6ES72231BH220XA8    S7-200CN, EM223 数字量输入/输出模块,8输入 24V DC/8输出 24V DC
6ES72231BL220XA8    S7-200CN, EM223 数字量输入/输出模块,16输入 24V DC/16输出 24V DC
6ES72231BM220XA8    S7-200CN, EM223 数字量输入/输出模块,32输入 24V DC/32输出 24V DC
6ES72231HF220XA8    S7-200CN, EM223 数字量输入/输出模块,4输入 24V DC/4输出继电器
6ES72231PH220XA8    S7-200CN, EM223 数字量输入/输出模块,8输入 24V DC/8输出继电器
6ES72231PL220XA8    S7-200CN, EM223 数字量输入/输出模块,16输入 24V DC/16输出继电器
6ES72231PM220XA8    S7-200CN, EM223 数字量输入/输出模块,32输入 24V DC/32输出继电器
6ES72310HC220XA8    S7-200CN, EM231 模拟量输入模块,4输入
6ES72317PB220XA8    S7-200CN, EM231 热电阻模块,2输入
6ES72317PD220XA8    S7-200CN, EM231 热电偶模块,4输入
6ES72320HB220XA8    S7-200CN, EM232 模拟量输出模块,2输出
6ES72350KD220XA8    S7-200CN, EM235 模拟量输入输出模块,4输入/1输出
6EP13321LA00    PS207电源,输入: 100-240 V AC (110-300 V DC),输出: 24 V DC/2.5 A
6EP13321LA10    PS207电源,输入: 100-240 V AC (110-300 V DC),输出: 24 V DC/4 A
6ES72906AA200XA0    SIMATIC S7-200, 扩展电缆, 0.8米
6ES72918BA200XA0    SIMATIC S7-200, 电池卡
6ES72918GF230XA0    SIMATIC S7-200, 64K存储卡
6ES72918GH230XA0    SIMATIC S7-200, 256K存储卡
6ES72971AA230XA0    SIMATIC S7-200, CPU221/222时钟卡(包括电池卡功能)
6ES79013CB300XA0    SIMATIC S7-200, PC/PPI 电缆, RS232/RS485转换,带光电隔离,最大187.5K波特率,支持多主站
6ES79013DB300XA0    SIMATIC S7-200, PC/PPI 电缆, USB/RS485转换,带光电隔离,最大187.5K波特率,支持多主站
功能与设计
CPU单元设计
集成的24V负载电源:可直接连接到传感器和变送器(执行器),CPU 221,222具有180mA输出, CPU 224,CPU 224XP,CPU 226分别输出280,400mA。可用作负载电源。
不同的设备类型
CPU 221~226各有2种类型CPU,具有不同的电源电压和控制电压。
本机数字量输入/输出点
CPU 221具有6个输入点和4个输出点,CPU 222具有8个输入点和6个输出点,CPU 224具有14个输入点和10个输出点,CPU 224XP具有14个输入点和10个输出点,CPU 226具有24个输入点和16个输出点。
本机模拟量输入/输出点
CPU 224XP具有2个输入点,1个输出点。
中断输入
允许以极快的速度对过程信号的上升沿作出响应。
高速计数器
-CPU 221/222
4个高速计数器(30KHz),可编程并具有复位输入,2个独立的输入端可同时作加、减计数,可连接两个相位差为90°的A/B相增量编码器
-CPU 224/224XP/226
6个高速计数器(30KHz),具有CPU 221/222相同的功能。
模拟电位器
CPU 221/222 1个
CPU 224/224XP/226 2个
2路高频率脉冲输出(最大20KHz),用于控制步进电机或伺服电机实现定位任务。
实时时钟
例如为信息加注时间标记,记录机器运行时间或对过程进行时间控制。
EEPROM存储器模块(选件)
可作为修改与拷贝程序的快速工具(无需编程器),并可进行辅助软件归档工作。
电池模块
用于长时间数据后备。用户数据(如标志位状态,数据块,定时器,计数器)可通过内部的超级电容存贮大约5天。选用电池模块能延长存贮时间到200天(10年寿命)。电池模块插在存储器模块的卡槽中。
编程
STEP 7-Micro/WIN32 V3.1编程软件可以对所有的CPU 221/222/224/224XP/226功能进行编程。同时也可以使用STEP 7-Micro/WIN16 V2.1软件包,但是它只支持对S7-21x同样具有的功能进行编程。
STEP 7-Micro/DOS不能对CPU 221/222/224/224XP/226编程。如果使用PG/PC的串口编程,则需要使用PC/PPI电缆。
如果使用STEP 7-Micro/WIN32 V3.1编程软件,则也可以通过SIMATIC CP 5511或CP 5611编程。在这种情况下,通讯速率可高达187.5kbit/s。  可以利用PC/PPI 电缆和自由口通讯功能把 S7-200 CPU 连接到许多和RS-232标准兼容的设备。
有两种不同型号的 PC/PPI 电缆:
带有RS-232口的隔离型 PC/PPI 电缆,用5个DIP开关设置波特率和其它配置项 (见下图)。
带有RS-232口的非隔离型 PC/PPI 电缆,用4个DIP开关设置波特率。 有关非隔离型PC/PPI电缆的技术规范,请参阅S7-200 可编程控制器系统手册。
维修服务
»我们的全球维修服务网络帮助您将此类风险降为最低。西门子维修服务将帮助您的现场故障得到及时排除,是设备停机时快捷而实惠的解决方案。«
watch the Podcast
维修服务——您的获益
工厂生产中设备停机不仅带来一系列麻烦,而且还要为此付出高昂的成本代价。使用西门子维修服务,您将:大大缩短停机时间;轻松联络全球维修网络;获得可靠的维修质量保障;获得独家原厂备件。
维修服务价格政策
我们的多数产品实行一口价维修。 当您询价时,我们无需计算维修工时即可立刻提供维修价格。同时,应您的需要我们可以为您提供维修报告。
根据您的需求,我们拥有不同类型的维修服务可供选择:
标准维修:通常的维修时间为收到产品后的5个工作日以内。
加急维修:在紧急情况下,我们为多数产品提供维修时间为2个工作日以内的服务。客户需为此支付额外费用。
非工作时间维修:在紧急情况下可以为多数产品在周末及节假日提供服务。
上门取件:针对部分产品提供上门取件及维修后送回的服务。
现场维修:对于体积较大或较重的产品,我们也可以应您的要求在客户现场提供维修服务。
关 键 词: 西门子PLC模块 S7200CN模块 CPU224XP
公司名称: 上海展驭自动化科技有限公司
联 系 人: 陈超
电  话: 021-60341726
手  机: 18019725477
地  址: 上海市松江区玉树北路
邮  编: 201600
6AV6647-0AC1(6AV6647-0AC11-3AX0)
西门子ET200S电源模(6ES7138-4CA01-0AA0)
西门子CPU319-3P(6ES73183EL010AB0)
西门子CPU317-2P(6ES73172EK140AB0)
西门子CPU317-2D(6ES73172AK140AB0)
西门子处理器CPU315(6ES73152EH140AB0)
西门子CPU315-2D(6ES73152AH140AB0)
CPU314C-2PN/(6ES73146EH040AB0)
西门子CPU314C-(6ES73146CH040AB0)
西门子CPU314C-2(6ES73146CH040AB0)
西门子处理器CPU314(6ES73146CH040AB0)
西门子CPU314C-2(6ES73146BH040AB0)
西门子处理器CPU314(6ES73146BH040AB0)
西门子CPU314厂家直(6ES73141AG140AB0)
原装西门子CPU314(6ES73141AG140AB0)
德国西门子CPU314 (6ES73141AG140AB0)
西门子处理器CPU314(6ES73141AG140AB0)
西门子处理器CPU313(6ES73136CG040AB0)
原装西门子CPU313C(6ES73136CG040AB0)
