6ES72110AA230XB0 SIMATIC S7-200 CPU211,DC/DC/DC,6输入/4输出
6ES72110BA230XB0 SIMATIC S7-200 CPU211,AC/DC/Rly,6输入/4输出
6ES72121AB230XB0 SIMATIC S7-200 CPU222,DC/DC/DC,8输入/6输出
6ES72121BB230XB0 SIMATIC S7-200 CPU222,AC/DC/Rly,8输入/6输出
6ES72141AD230XB0 SIMATIC S7-200 CPU224,DC/DC/DC,14输入/10输出
6ES72141BD230XB0 SIMATIC S7-200 CPU224,AC/DC/Rly,14输入/10输出
6ES72142AD230XB0 SIMATIC S7-200 CPU224XP,DC/DC/DC,14输入/10输出,集成2AI/1AO
6ES72142AS230XB0 SIMATIC S7-200 CPU224XPsi,DC/DC/DC,14输入/10输出,集成2AI/1AO
6ES72142BD230XB0 SIMATIC S7-200 CPU224XP,AC/DC/Rly,14输入/10输出(NPN输出),集成2AI/1AO
6ES72162AD230XB0 SIMATIC S7-200 CPU226,DC/DC/DC,24输入/16输出
6ES72162BD230XB0 SIMATIC S7-200 CPU226,AC/DC/Rly,24输入/16输出
6ES72121AB230XB8 S7-200CN CPU222,DC/DC/DC,8输入/6输出
6ES72121BB230XB8 S7-200CN CPU222,AC/DC/Rly,8输入/6输出
6ES72141AD230XB8 S7-200CN CPU224,DC/DC/DC,14输入/10输出
6ES72141BD230XB8 S7-200CN CPU224,AC/DC/Rly,14输入/10输出
6ES72142AD230XB8 S7-200CN CPU224XP,DC/DC/DC,14输入/10输出,集成2AI/1AO
6ES72142AS230XB8 S7-200CN CPU224XPsi,DC/DC/DC,14输入/10输出,集成2AI/1AO
6ES72142BD230XB8 S7-200CN CPU224XP,AC/DC/Rly,14输入/10输出(NPN输出),集成2AI/1AO
6ES72162AD230XB8 S7-200CN CPU226,DC/DC/DC,24输入/16输出
6ES72162BD230XB8 S7-200CN CPU226,AC/DC/Rly,24输入/16输出
6ES72211BF220XA0 SIMATIC S7-200, EM221 数字量输入模块, 8输入24V DC
6ES72211BH220XA0 SIMATIC S7-200, EM221 数字量输入模块, 16输入24V DC
6ES72211EF220XA0 SIMATIC S7-200, EM221 数字量输入模块, 8输入 交流120/230V AC
6ES72221BD220XA0 SIMATIC S7-200, EM222 数字量输出模块,4输出24V DC 5A
6ES72221BF220XA0 SIMATIC S7-200, EM222 数字量输出模块,8输出24V DC
6ES72221EF220XA0 SIMATIC S7-200, EM222 数字量输出模块,8输出 交流120/230V AC
6ES72221HD220XA0 SIMATIC S7-200, EM222 数字量输出模块,4输出继电器 10A
6ES72221HF220XA0 SIMATIC S7-200, EM222 数字量输出模块,8输出继电器
6ES72231BF220XA0 SIMATIC S7-200, EM223 数字量输入/输出模块,4输入 24V DC/4输出 24V DC
6ES72231BH220XA0 SIMATIC S7-200, EM223 数字量输入/输出模块,8输入 24V DC/8输出 24V DC
6ES72231BL220XA0 SIMATIC S7-200, EM223 数字量输入/输出模块,16输入 24V DC/16输出 24V DC
6ES72231BM220XA0 SIMATIC S7-200, EM223 数字量输入/输出模块,32输入 24V DC/32输出 24V DC
6ES72231HF220XA0 SIMATIC S7-200, EM223 数字量输入/输出模块,4输入 24V DC/4输出继电器
6ES72231PH220XA0 SIMATIC S7-200, EM223 数字量输入/输出模块,8输入 24V DC/8输出继电器
6ES72231PL220XA0 SIMATIC S7-200, EM223 数字量输入/输出模块,16输入 24V DC/16输出继电器
6ES72231PM220XA0 SIMATIC S7-200, EM223 数字量输入/输出模块,32输入 24V DC/32输出继电器
6ES72310HC220XA0 SIMATIC S7-200, EM231 模拟量输入模块,4输入
6ES72310HF220XA0 SIMATIC S7-200, EM231 模拟量输入模块,8输入
6ES72317PB220XA0 SIMATIC S7-200, EM231 热电阻模块,2输入
6ES72317PC220XA0 SIMATIC S7-200, EM231 热电阻模块,4输入
6ES72317PD220XA0 SIMATIC S7-200, EM231 热电偶模块,4输入
6ES72317PF220XA0 SIMATIC S7-200, EM231 热电偶模块,8输入
6ES72320HB220XA0 SIMATIC S7-200, EM232 模拟量输出模块,2输出
6ES72320HD220XA0 SIMATIC S7-200, EM232 模拟量输出模块,4输出
6ES72350KD220XA0 SIMATIC S7-200, EM235 模拟量输入输出模块,4输入/1输出
6ES72531AA220XA0 SIMATIC S7-200, EM253 定位模块
6ES72770AA220XA0 SIMATIC S7-200, EM277 Profibus-DP 从站模块
6ES72211BF220XA8 S7-200CN, EM221 数字量输入模块, 8输入24V DC
6ES72211BH220XA8 S7-200CN, EM221 数字量输入模块, 16输入24V DC
6ES72221BF220XA8 S7-200CN, EM222 数字量输出模块,8输出24V DC
6ES72221HF220XA8 S7-200CN, EM222 数字量输出模块,8输出继电器
6ES72231BF220XA8 S7-200CN, EM223 数字量输入/输出模块,4输入 24V DC/4输出 24V DC
6ES72231BH220XA8 S7-200CN, EM223 数字量输入/输出模块,8输入 24V DC/8输出 24V DC
6ES72231BL220XA8 S7-200CN, EM223 数字量输入/输出模块,16输入 24V DC/16输出 24V DC
6ES72231BM220XA8 S7-200CN, EM223 数字量输入/输出模块,32输入 24V DC/32输出 24V DC
6ES72231HF220XA8 S7-200CN, EM223 数字量输入/输出模块,4输入 24V DC/4输出继电器
6ES72231PH220XA8 S7-200CN, EM223 数字量输入/输出模块,8输入 24V DC/8输出继电器
6ES72231PL220XA8 S7-200CN, EM223 数字量输入/输出模块,16输入 24V DC/16输出继电器
6ES72231PM220XA8 S7-200CN, EM223 数字量输入/输出模块,32输入 24V DC/32输出继电器
6ES72310HC220XA8 S7-200CN, EM231 模拟量输入模块,4输入
6ES72317PB220XA8 S7-200CN, EM231 热电阻模块,2输入
6ES72317PD220XA8 S7-200CN, EM231 热电偶模块,4输入
6ES72320HB220XA8 S7-200CN, EM232 模拟量输出模块,2输出
6ES72350KD220XA8 S7-200CN, EM235 模拟量输入输出模块,4输入/1输出
6EP13321LA00 PS207电源,输入: 100-240 V AC (110-300 V DC),输出: 24 V DC/2.5 A
6EP13321LA10 PS207电源,输入: 100-240 V AC (110-300 V DC),输出: 24 V DC/4 A
6ES72906AA200XA0 SIMATIC S7-200, 扩展电缆, 0.8米
6ES72918BA200XA0 SIMATIC S7-200, 电池卡
6ES72918GF230XA0 SIMATIC S7-200, 64K存储卡
6ES72918GH230XA0 SIMATIC S7-200, 256K存储卡
6ES72971AA230XA0 SIMATIC S7-200, CPU221/222时钟卡(包括电池卡功能)
6ES79013CB300XA0 SIMATIC S7-200, PC/PPI 电缆, RS232/RS485转换,带光电隔离,最大187.5K波特率,支持多主站
6ES79013DB300XA0 SIMATIC S7-200, PC/PPI 电缆, USB/RS485转换,带光电隔离,最大187.5K波特率,支持多主站
产品信息
本机集成8输入/6输出共14个数字量I/O点。可连接2个扩展模块。6K字节程序和数据存储空间。4个独立的30kHz高速计数器,2路独立的20kHz高速脉冲输出。1个RS485通讯/编程口,具有PPI通讯协议、MPI通讯协议和自由方式通讯能力。非常适合于小点数控制的微型控制器。
本机集成14输入/10输出共24个数字量I/O点。可连接7个扩展模块,最大扩展至168路数字量I/O点或35路模拟量I/O 点。13K字节程序和数据存储空间。6个独立的30kHz高速计数器,2路独立的20kHz高速脉冲输出,具有PID控制器。1个RS485通讯/编程口,具有PPI通讯协议、MPI通讯协议和自由方式通讯能力。I/O端子排可很容易地整体拆卸。是具有较强控制能力的控制器。
本机集成14输入/10输出共24个数字量I/O点,2输入/1输出共3个模拟量I/O点,可连接7个扩展模块,最大扩展值至168路数字量I/O点或38路模拟量I/O点。20K字节程序和数据存储空间,6个独立的高速计数器(100KHz),2个100KHz的高速脉冲输出,2个RS485通讯/编程口,具有PPI通讯协议、MPI通讯协议和自由方式通讯能力。本机还新增多种功能,如内置模拟量I/O,位控特性,自整定PID功能,线性斜坡脉冲指令,诊断LED,数据记录及配方功能等。是具有模拟量I/O和强大控制能力的新型CPU。
功能与设计
CPU单元设计
集成的24V负载电源:可直接连接到传感器和变送器(执行器),CPU 221,222具有180mA输出, CPU 224,CPU 224XP,CPU 226分别输出280,400mA。可用作负载电源。
不同的设备类型
CPU 221~226各有2种类型CPU,具有不同的电源电压和控制电压。
本机数字量输入/输出点
CPU 221具有6个输入点和4个输出点,CPU 222具有8个输入点和6个输出点,CPU 224具有14个输入点和10个输出点,CPU 224XP具有14个输入点和10个输出点,CPU 226具有24个输入点和16个输出点。
本机模拟量输入/输出点
CPU 224XP具有2个输入点,1个输出点。
中断输入
允许以极快的速度对过程信号的上升沿作出响应。
高速计数器
-CPU 221/222
4个高速计数器(30KHz),可编程并具有复位输入,2个独立的输入端可同时作加、减计数,可连接两个相位差为90°的A/B相增量编码器
-CPU 224/224XP/226
6个高速计数器(30KHz),具有CPU 221/222相同的功能。
模拟电位器
CPU 221/222 1个
CPU 224/224XP/226 2个
