6AV2124-0UC02-0AX0
SIMATIC HMI, TP1900 精智面板18.5 寸,1600 万色 LED 背光,16:9 宽屏显示,触摸屏,24 MB 用户内存
精智面板 精智面板 6AV21242DC010AX0
6AV21241DC010AX0
6AV21240GC010AX0
6AV21241GC010AX0
6AV21240JC010AX0
6AV21241JC010AX0
6AV21240MC010AX0
6AV21241MC010AX0
6AV21240QC020AX0
6AV21241QC020AX0
6AV21240UC020AX0
6AV21240XC020AX0
6AV21448GC100AA0
6AV21448MC100AA0
精智面板产品推广包 6AV21814DB200AX0
6AV21814DB100AX0
6AV21814GB000AX0
6AV21814GB100AX0
6AV21814JB000AX0
6AV21814JB100AX0
6AV21814MB000AX0
6AV21814MB100AX0
6AV21814QB000AX0
6AV21814QB100AX0
6AV21814UB000AX0
6AV21814XB000AX0
精智面板附件 6AV21818XP000AX0
6AV21246DJ000AX0
6AV21246GJ000AX0
6AV21246JJ000AX0
6AV21246MJ000AX0
6AV21246QJ000AX1
6AV21246UJ000AX1
6AV21246XJ000AX1
"第二代
移动面板" "第二代
移动面板" 6AV21252GB030AX0
6AV21252GB230AX0
6AV21252JB030AX0
6AV21252JB230AX0
"第二代
移动面板附件" 6AV21252AE130AX0
6AV21252AE230AX0
6AV21815AF020AX0
6AV21815AF050AX0
6AV21815AF080AX0
6AV21815AF100AX0
6AV21815AF150AX0
6AV21815AF200AX0
6AV21815AF250AX0
6AV21815AG800AX0
新一代精简面板 6AV21232DB030AX0
6AV21232GA030AX0
6AV21232GB030AX0
6AV21232JB030AX0
6AV21232MA030AX0
6AV21232MB030AX0
精简面板 6AV66470AH113AX0
6AV66470AA113AX0
6AV66470AK113AX0
6AV66470AJ113AX0
6AV66470AB113AX0
6AV66470AC113AX0
6AV66470AD113AX0
6AV66470AE113AX0
6AV66470AF113AX0
6AV66470AG113AX0
按键面板 按键面板 6AV36883AY360AX0
6AV36883AF370AX0
6AV36883EH470AX0
按键面板附件 6AV66713XY384AX0
6AV66713XY484AX0
6AV66713XY584AX0
移动面板 移动面板 6AV66450AA010AX0
6AV66450AB010AX0
6AV66450AC010AX0
6AV66450BA010AX0
6AV66450BB010AX0
6AV66450BC010AX0
6AV66450CA010AX0
6AV66450CB010AX0
6AV66450CC010AX0
6AV66450BE020AX0
6AV66450DD010AX1
6AV66450DE010AX1
6AV66450EB010AX1
6AV66450EC010AX1
6AV66450EF010AX1
移动面板附件 6XV14404AH20
6XV14404AH50
6XV14404AH80
6XV14404AN10
6XV14404AN15
6XV14404AN20
6XV14404AN25
6XV14404BH20
6XV14404BH50
6XV14404BH80
6XV14404BN10
6XV14404BN15
6XV14404BN20
6XV14404BN25
6AV66715AE000AX0
6AV66715AE010AX0
6AV66715AE100AX0
6AV66715AE110AX0
6AV65741AF044AA0
6AV66715CE000AX1
6AV66715CM000AX1
xP 77系列面板 6AV66410CA010AX1
6AV66420BA011AX1
6AV66420BC011AX1
6AV66420BD013AX0
6AV66420DA011AX1
6AV66420DC011AX1
6AV66420EA013AX0
6AV66425EA100CG0
6AV66428BA100AA0
6AV66430AA011AX0
6AV66430BA011AX0
6AV66430CB011AX1
6AV66430CD011AX1
6AV66430DB011AX1
6AV66430DD011AX1
6AV66430ED012AX0
6AV66440AA012AX0
6AV66440AB012AX0
6AV66440AC012AX1
6AV66440BA012AX1
6AV66440CB012AX0
6AV66442AB012AX0
6AV66448AB200AA1
6ES75184AP000AB0 CPU 1518-4 PN/DP,4 MB 程序,20 MB 数据;1 ns;集成 2x PN 接口,2x 以太网接口,1x DP接口
6ES75173AP000AB0 CPU 1517-3 PN/DP,2 MB 程序,8 MB 数据;2 ns;集成 2x PN 接口,1x 以太网接口,1x DP接口
6ES75163AN010AB0 CPU 1516-3 PN/DP,1 MB 程序,5 MB 数据;10 ns ;集成 2xPN 接口,1x 以太网接口,1x DP 接口
6ES75152AM010AB0 CPU 1515-2 PN,500 KB 程序,3 MB 数据;30 ns;集成 2x PN 接口,1x 以太网接口
6ES75131AL010AB0 CPU 1513-1 PN,300 KB 程序,1.5 MB 数据;40 ns;集成 2x PN 接口
6ES75111AK010AB0 CPU 1511-1 PN,150 KB 程序,1 MB 数据;60 ns;集成 2x PN 接口
6ES75121CK000AB0 CPU 1512C-1 PN, 250 KB程序,1 MB数据;48 ns;集成2x PN接口;集成 32 DI/32 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75111CK000AB0 CPU 1511C-1 PN, 175 KB程序,1 MB数据;60 ns;集成2x PN接口;集成 16 DI/16 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75121DK010AB0 CPU 1512SP-1 PN,200KB 程序,1 MB 数据;48 ns;集成 1x PN 接口 (可用ET 200SP总线适配器再拓展2个PN 接口)
6ES75101DJ010AB0 CPU 1510SP-1 PN,100KB 程序,750 KB 数据;72 ns;集成 1x PN 接口(可用ET 200SP总线适配器再拓展2个PN 接口)
6ES76772AA310EB0 CPU 1515SP PC,2 GB RAM,8 GB CFAST; 预装32位WINDOWS EMBEDDED STANDARD 7 E,预装CPU 1505S V1.7软件控制器
6ES76772AA410FB0 CPU 1515SP PC,4 GB RAM,16 GB CFAST; 预装64位WINDOWS EMBEDDED STANDARD 7 P,预装CPU 1505S V1.7软件控制器
6ES76772AA410FK0 CPU 1515SP PC,4 GB RAM,16 GB CFAST; 预装64位WINDOWS EMBEDDED STANDARD 7 P,预装CPU 1505S V1.7软件控制器和WINCC ADVANCED RUNTIME(带有128点授权)
6ES76772AA410FL0 CPU 1515SP PC,4 GB RAM,16 GB CFAST; 预装64位WINDOWS EMBEDDED STANDARD 7 P,预装CPU 1505S V1.7软件控制器和WINCC ADVANCED RUNTIME(带有512点授权)
6ES76772AA410FM0 CPU 1515SP PC,4 GB RAM,16 GB CFAST; 预装64位WINDOWS EMBEDDED STANDARD 7 P,预装CPU 1505S V1.7软件控制器和WINCC ADVANCED RUNTIME(带有2048点授权)
6ES76727AC000YA0 CPU 1507S,VERSION 1.8(1个浮点授权), 仅能在SIMATIC IPC上使用
6ES78062CD000YA0 S7-1500软件控制器用ODK,使用C/C++扩展S7-1500软件控制器的功能
6ES71936AR000AA0 总线适配器BA 2×RJ45
6ES71936AF000AA0 总线适配器BA 2×FC快连式
6ES71936AP000AA0 总线适配器BA 2×SCRJ光纤
6ES75455DA000AB0 S7-1510/1512 SP CPU DP通信模块 (RS-485 PROFIBUS-DP)
6ES79548LC020AA0 S7-1200/1500 4M 存储卡
6ES79548LE020AA0 S7-1200/1500 12M 存储卡
6ES79548LF020AA0 S7-1200/1500 24M 存储卡
6ES79548LL020AA0 S7-1200/1500 256M 存储卡
6ES79548LP010AA0 S7-1200/1500 2G 存储卡
6ES79548LT020AA0 S7-1200/1500 32G 存储卡
6ES71555AA000AB0 ET 200MP IM 155-5 PN ST 标准型接口模块
6ES71555AA000AC0 ET 200MP IM 155-5 PN HF 高性能型接口模块
6ES71555BA000AB0 ET 200MP IM 155-5 DP ST 标准型接口模块
6ES75070RA000AB0 PS:60 W,额定输入电压 AC/DC 120/230 V
6ES75050RA000AB0 PS:60 W,额定输入电压 DC 24/48/60 V
6ES75050KA000AB0 PS:25 W,额定输入电压 DC 24 V
6EP1332-4BA00 PM 1507:72W, 24 V/3 A,额定输入电压 AC 120/230 V
6EP1333-4BA00 PM 1507:192W, 24 V/8 A,额定输入电压 AC 120/230 V
6ES75325HF000AB0 AQ 8:模拟输出模块,高速 AQ 8x U/I HS, 35mm模块,不含前连接器
6ES75325HD000AB0 AQ 4:模拟输出模块,AQ 4x U/I ST, 35mm模块,不含前连接器
6ES75325NB000AB0 AQ 2:模拟输出模块,AQ 2x U/I ST, 25mm模块,含前连接器
6ES75317KF000AB0 AI 8:模拟输入模块,AI 8x U/I/RTD/TC ST, 35mm模块,不含前连接器
6ES75317NF100AB0 AI 8:模拟输入模块,高速,AI 8x U/I HS, 35mm模块,不含前连接器
6ES75317QD000AB0 AI 4:模拟输出模块,AI 4x U/I/RTD/TC ST, 25mm模块,含前连接器
6ES75347QE000AB0 AI4/AQ2:模拟量输入/输出模块 AI/AO 4x U/I/RTD/TC 2x U/I ST, 25mm模块,含前连接器
6ES75221BL000AB0 DQ 32:数字输出模块,晶体管 DQ 32 x 24 VDC/ 0.5A ST, 35mm模块,不含前连接器
6ES75221BL100AA0 DQ 32:数字输出模块,晶体管 DQ 32 x 24 VDC/ 0.5A BA, 25mm模块,含前连接器
6ES75221BH000AB0 DQ 16:数字输出模块,晶体管 DQ 16 x 24 VDC/ 0.5A ST, 35mm模块,不含前连接器
6ES75221BH100AA0 DQ 16:数字输出模块,晶体管 DQ 16 x 24 VDC/ 0.5A BA, 25mm模块,含前连接器
6ES75225FH000AB0 DQ 16:数字输出模块,可控硅 DQ 16x 230 VAC/ 1A ST (TRIAC), 35mm模块,不含前连接器
6ES75225HH000AB0 DQ 16:数字输出模块,继电器 DQ 16x 230 VAC/ 2A ST (RELAY), 35mm模块,不含前连接器
6ES75221BF000AB0 DQ 8:数字输出模块,高性能 DQ 8x 24VDC/ 2A HF, 35mm模块,不含前连接器
6ES75225FF000AB0 DQ 8:数字输出模块,可控硅 DQ 8 x 230 VAC/ 2A ST (TRIAC), 35mm模块,不含前连接器
6ES75225HF000AB0 DQ 8:数字输出模块,继电器 DQ 8x 230VAC/ 5A ST (RELAY), 35mm模块,不含前连接器
6ES75211BL000AB0 DI 32:数字输入模块,高性能 DI 32x 24VDC HF, 35mm模块,不含前连接器
6ES75211BL100AA0 DI 32:数字输入模块,DI 32x 24VDC BA, 25mm模块,含前连接器
6ES75211BH000AB0 DI 16:数字输入模块,高性能 DI 16x 24VDC HF, 35mm模块,不含前连接器
6ES75211BH100AA0 DI 16:数字输入模块,DI 16x 24VDC BA, 25mm模块,含前连接器
6ES75211BH500AA0 DI 16:数字输入模块,源型,DI 16x 24VDC SRC BA, 35mm模块,不含前连接器
6ES75211FH000AA0 DI 16:数字输入模块,DI 16x 230V AC BA, 35mm模块,不含前连接器
6ES75231BL000AA0 DI16/DQ16:数字量输入/输出模块,16x 24VDC/16x 24VDC/ 0.5A BA, 25mm模块,含前连接器
6ES75501AA000AB0 TM Count 2 x 24 V:2通道高速计数器与位置采集(增量型编码器,24V信号), 35mm模块,不含前连接器
6ES75511AB000AB0 TM PosInput 2,2通道计数与位置采集(增量型/绝对值编码器SSI,RS422和5V TTL信号), 35mm模块,不含前连接器
6ES75521AA000AB0 TM Timer DIDQ 16x24V 带时间戳、高速计数、PWM等功能, 35mm模块,不含前连接器
6ES75401AB000AA0 PtP RS422/485 通讯模块
6ES75411AB000AB0 PtP RS422/485,高性能通讯模块(支持Modbus RTU)
6ES75401AD000AA0 PtP RS232通讯模块
6ES75411AD000AB0 PtP RS232,高性能通讯模块(支持Modbus RTU)
6ES75901BC000AA0 S7-1500 安装导轨:2000 mm
6ES75901AJ300AA0 S7-1500 安装导轨:830 mm
6ES75901AF300AA0 S7-1500 安装导轨:530 mm
6ES75901AE800AA0 S7-1500 安装导轨:482 mm
6ES75901AC400AA0 S7-1500 安装导轨:245 mm
6ES75901AB600AA0 S7-1500 安装导轨:160 mm
6ES75922AX000AA0 标签,35mm模板适用,100片
6ES75921AX000AA0 标签,25mm模板适用,100片
6ES75921AM000XB0 35mm模板前连接器,螺钉型,40针,含4根跳线
6ES75921BM000XB0 35mm模板前连接器,快连型,40针,含4根跳线
6ES75921BM000XA0 25mm模板前连接器,快连型,40针,含4根跳线
6ES75905AA000AA0 "用于连接PE(地)到S7-1500安装导轨的接地元件,
对于2000mm的安装导轨是必须的 每个包装20片"
6ES75911AA000AA0 S7-1511/13CPU显示面板
6ES75911BA000AA0 S7-1515/16/17/18CPU显示面板
6ES75908AA000AA0 S7-1500 PS/PM供电模板连接头,内含10片
6ES75280AA707AA0 接口模块(6ES7 155-5AA00-0AB0)前盖板5片/包
6ES75280AA007AA0 I/O模块前盖板5片/包,35mm模板适用
6ES75280AA000AA0 I/O模块前盖板5片/包,25mm模板适用
6ES75900AA000AA0 U型连接器,,5片/包
6ES75923AA000AA0 跳线,20片/包
6ES75905CA000AA0 屏蔽套件:含屏蔽端子,框架以及24VDC接线端
6ES75905BA000AA0 模拟量/技术模板专用屏蔽端子
6ES76772AA300AA0 CPU 1515SP PC,2 GB RAM,不带CFAST卡,无预装软件,仅作备件使用
6ES76772AA400AA0 CPU 1515SP PC,4 GB RAM,不带CFAST卡,无预装软件,仅作备件使用
