6AV6647-0AC11-3AX0
SIMATIC HMI, KTP600 DP 精简面板 5.7 寸,256 色,6 个功能键,MPI / Profibus DP 接口
精智面板 精智面板 6AV21242DC010AX0
6AV21241DC010AX0
6AV21240GC010AX0
6AV21241GC010AX0
6AV21240JC010AX0
6AV21241JC010AX0
6AV21240MC010AX0
6AV21241MC010AX0
6AV21240QC020AX0
6AV21241QC020AX0
6AV21240UC020AX0
6AV21240XC020AX0
6AV21448GC100AA0
6AV21448MC100AA0
精智面板产品推广包 6AV21814DB200AX0
6AV21814DB100AX0
6AV21814GB000AX0
6AV21814GB100AX0
6AV21814JB000AX0
6AV21814JB100AX0
6AV21814MB000AX0
6AV21814MB100AX0
6AV21814QB000AX0
6AV21814QB100AX0
6AV21814UB000AX0
6AV21814XB000AX0
精智面板附件 6AV21818XP000AX0
6AV21246DJ000AX0
6AV21246GJ000AX0
6AV21246JJ000AX0
6AV21246MJ000AX0
6AV21246QJ000AX1
6AV21246UJ000AX1
6AV21246XJ000AX1
"第二代
移动面板" "第二代
移动面板" 6AV21252GB030AX0
6AV21252GB230AX0
6AV21252JB030AX0
6AV21252JB230AX0
"第二代
移动面板附件" 6AV21252AE130AX0
6AV21252AE230AX0
6AV21815AF020AX0
6AV21815AF050AX0
6AV21815AF080AX0
6AV21815AF100AX0
6AV21815AF150AX0
6AV21815AF200AX0
6AV21815AF250AX0
6AV21815AG800AX0
新一代精简面板 6AV21232DB030AX0
6AV21232GA030AX0
6AV21232GB030AX0
6AV21232JB030AX0
6AV21232MA030AX0
6AV21232MB030AX0
精简面板 6AV66470AH113AX0
6AV66470AA113AX0
6AV66470AK113AX0
6AV66470AJ113AX0
6AV66470AB113AX0
6AV66470AC113AX0
6AV66470AD113AX0
6AV66470AE113AX0
6AV66470AF113AX0
6AV66470AG113AX0
按键面板 按键面板 6AV36883AY360AX0
6AV36883AF370AX0
6AV36883EH470AX0
按键面板附件 6AV66713XY384AX0
6AV66713XY484AX0
6AV66713XY584AX0
移动面板 移动面板 6AV66450AA010AX0
6AV66450AB010AX0
6AV66450AC010AX0
6AV66450BA010AX0
6AV66450BB010AX0
6AV66450BC010AX0
6AV66450CA010AX0
6AV66450CB010AX0
6AV66450CC010AX0
6AV66450BE020AX0
6AV66450DD010AX1
6AV66450DE010AX1
6AV66450EB010AX1
6AV66450EC010AX1
6AV66450EF010AX1
移动面板附件 6XV14404AH20
6XV14404AH50
6XV14404AH80
6XV14404AN10
6XV14404AN15
6XV14404AN20
6XV14404AN25
6XV14404BH20
6XV14404BH50
6XV14404BH80
6XV14404BN10
6XV14404BN15
6XV14404BN20
6XV14404BN25
6AV66715AE000AX0
6AV66715AE010AX0
6AV66715AE100AX0
6AV66715AE110AX0
6AV65741AF044AA0
6AV66715CE000AX1
6AV66715CM000AX1
xP 77系列面板 6AV66410CA010AX1
6AV66420BA011AX1
6AV66420BC011AX1
6AV66420BD013AX0
6AV66420DA011AX1
6AV66420DC011AX1
6AV66420EA013AX0
6AV66425EA100CG0
6AV66428BA100AA0
6AV66430AA011AX0
6AV66430BA011AX0
6AV66430CB011AX1
6AV66430CD011AX1
6AV66430DB011AX1
6AV66430DD011AX1
6AV66430ED012AX0
6AV66440AA012AX0
6AV66440AB012AX0
6AV66440AC012AX1
6AV66440BA012AX1
6AV66440CB012AX0
6AV66442AB012AX0
6AV66448AB200AA1
一般信息
信号模块或 I/O 设备组件将控制器和过程连接在一起。控制单元通过相连的传感器记录当前过程状态,并对执行器发出相应的响应。
通过数字量模块和模拟量模块,可以准确便捷地输入/输出特定任务所需的数据。这些模块既可以直接在 CPU 中进行集中式处理,也可以通过 ET200MP I/O 系统进行分布式处理。
To the top of the page
特性和客户收益
与S7-1500 CPU 类似,信号模块同样可以最大程度地提升生产力和生产效率。最优的系统性能可确保最短的响应时间。创新的操作机制可确保安装过程快速、可靠且无任何故障。
模块具有高度可扩展性,可根据客户需求量身定制,降低了成本的同时还提高了生产效率
模块可以具有不同的通道数量和功能
集成更多功能,实现紧凑设计,减少了变量的使用
U 型连接器,可自行连接背板总线
节省了安装空间,安装导轨上可安装更多组件
最优系统性能,实现快速处理并最大程度确保控制质量
增强了各种功能,通过 PROFINET IO 统一进行高效诊断
通道级诊断消息,支持快速故障修复
可读取电子识别码,快速识别所有组件
智能化的产品设计,降低了机柜组装成本
所有模块都可以在 ET200MP I/O 系统中集中和分布使用
统一采用 40 针前连接器,适用于所有模块
同一引脚上的信号相同。即,电路图中宏指令创建后,即可无限次重复使用,从而避免了接线错误
集成短接片,简化了接线操作
可扩展的电缆存放机制,为使用厚绝缘层的导线节省了更多空间
预先设计的电缆定位槽可在进行电气连接之前实现直接预接线
采用机械式插头连接器编码模式,可防止插入错误和模块连接错误
印刷电路接线图,无需参考文档即可直接进行连接
坚固的设计确保设备无错运行
