PCI系列数据采集控制卡
产品主要特性:
High-density 24-ch analog output channels Flexible Output Range: +/-10 V, 0~20 mA and 4~20 mA Synchronized output function Keeps output values after system hot reset BoardID switch
内容介绍
The PCI-1724U is an isolated high-density multiple channel analog card for the PCI bus, where each analog output channel is equipped with a 14-bit DAC.
