ADAM4000系列模块
产品主要特性:
通道:16 操作电压:30 Vmax 数字量输出:集电极开路30V(100 mA最大负载) 功耗:0.5 W (典型); 0.84 W (最大) 功耗:每个通道450 mW LED显示:亮:输出逻辑电平1 输出状态保持功能
内容介绍
The ADAM-5056D features sixteen digital output channels with LED indicators. The digital outputs are open-collector transistor switches that you can control from the ADAM-5000 main unit. You also can use the switches to control solid-state relays.
