ADAM5000系列模块
产品主要特性:
通道:3
有效分辨率:16位
输入类型:PT100 或Ni RTD
隔离电压:3000 VDC
采样速率:10采样点/秒(总共)
输入接线方式:2线,3线或4线
精确度:±0.1%或更高
内容介绍
The ADAM-5013 is a 16-bit, 3-channel RTD input module that features programmable input ranges on all channels. This module is an extremely cost-effective solution for industrial measurement and monitoring applications. Its optical isolated inputs provide 3,000 VDC of isolation between the analog input and the module, protecting the module and peripherals from damage due to high input line voltage.
