| 产品名称: |
研华ADAM-6542带以太网的单模光纤转换器
| 型 号: |
ADAM-6542 |
| 价 格: |
0.00 |
| 品 牌: |
研华 |
产品介绍: |
带以太网的单模光纤转换器
主要特点
- 自动流通和存储
- 单模光纤电缆允许单路传输和接受差分浪涌
- 10/100Base-TX & 100Base-FX
- 内置隔离浪涌保护
- MDI/MDI-X自动侦察
- 传输距离:20000米
| The ADAM-6542 adopts WDM technology that increases the information carrying capacity of fiber via multiplex transmit and receive signals at different wavelengths on the single strand cable. The WDM technology is implemented in couples. One site is installed ADAM-6542/W15 which transmit channel is 1550nm and receive channel is 1310nm. The other site is installed ADAM6542/W13 which transmit channel is 1310nm and receive channel is 1550nm. Both transmit and receive channels of ADAM-6542/W15 and ADAM-6542/W13 are multiplexed to a single strand cable. You can save half cabling cost when you use ADAM-6542/W15 and ADAM-6542/W13 instead of your original dual fiber converter. | |
| 关 键 词: |
研华 ADAM-6542 转换器 |
