| 产品名称: |
研华PCA-6006 全长CPU卡
| 型 号: |
PCA-6006 |
| 价 格: |
0.00 |
| 品 牌: |
研华 |
产品介绍: |
支持/DDR/VGA/Fast Ethernet Lan/HISA (400/533 MHz FSB)Socket 478 Pentium 4/Celeron |
主要特点
- 支持 Socket 478 Pentium 4/Celeron CPU,最高达3.06/2.2GHz
- 支持Intel超线程技术
- Intel 845GV芯片组,400/533MHz前端总线
- 板载高性能 VGA 控制器, 共享系统内存
- 支持双10/100/1000 Base-T 网络控制器
- 2 个USB 2.0
- 防止BIOS设置信息在故障时丢失,可提供CMOS数据自动备份/恢复功能
- HISA 驱动器
| PCA-6006 Pentium 4 full-sized single board computer successfully deployed Intels most advanced 845GV chipset, which supports high CPU frequencies up to 3.06 GHz and above with front side bus running at 400 or 533MHz. PCA-6006 also provides high memory capacities up to 2 GB DDR SDRAM (DDR 200/DDR 266). Memory transmission rate is as high as 2.1Gb/ sec. | |
| 关 键 词: |
研华 PCA-6006 CPU |
