产品介绍
Specifically designed for factory floors and other harsh industrial environments, the IPC-6608 Wall-mount industrial computer chassis is ideal for system integrators or users who require a compact, rugged PC/AT compatible system. The IPC-6608 features an 8-slot passive backplane and a wide selection of power supplies to meet different application needs. The chassis is only 6.8" wide and can easily be mounted bi-directionally on panels or walls with the supplied bracket.
