产品介绍
Specially designed for factory floor and other harsh industrial environments, the IPC-6806 wallmount IPC chassis is ideal for system integrators or users who require a compact, rugged PC/AT-compatible system. The IPC-6806 features a 6-slot passive backplane and a 150-watt power supply. The chassis is less than 8" wide and can be easily mounted on panels or walls with the supplied brackets.
