☆XK-CD194I-2X4☆可编程三相电流表
可编程数显仪表乐清天康仪表0577-61725572 黄13676575538适用于电流、电压、频率、功率等电量参数进行直接测量和显示,精度高、稳定性好、抗震动,数字校零、校调、精度高、性价比高等优点。设计院指定厂商。
☆XK-CD194I-2X4☆ 产品特点:
◎真有效值测量、整四位显示
◎三排LED同时显示A、B、C三相电压或电流
◎软件调校、内部无电位器(精度高、稳定性好、长期工作免调校)
◎可编程通过面板按键任意调节显示值1~9999
◎可选带通讯功能、通讯地址、波特率
◎可选带上下限报警控制功能
☆XK-CD194I-2X4☆ 技术指标:
精度等级:测量精度:0.5、0.2级;显示位数:整四位LED(9999)显示、整五位LED(99999)、液晶LCD显示。
输入:电压:AC100V、AC220V、AC380、DC75mV等/电流:AC5A、1A、DC20mA等
过量程:持续:1.2倍,瞬时:电流10倍/5秒,电压2倍/10秒
频率:50±10%
隔离耐压:电源与输入变送输出、通讯接口为AC2KV输入、变送输出、通讯接口两间为AC1KV
绝缘电阻:≧100MΩ
平均无故障工作时间:≧50000h
☆XK-CD194I-2X4☆工作条件:环境温度:-10~55℃,相对湿度≦93%,无腐蚀气体场所,海拔≦2500m
输出:模拟量/数字量/继电器输出 (上下限报警输出)
☆XK-CD194I-2X4☆ 选型
☆XK-CD194I-2X4☆ 编程操作见说明书
☆XK-CD194I-2X4☆ 注意事项
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4三相电流表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4三相电压表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4数显三相电流表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4乐清天康生产三相电流表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4乐清天康生产数显三相电流表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4乐清天康仪表生产
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4可编程数显三相电流表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4乐清天康专业生产数显三相电流表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4单相电压表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4单相电流表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4数显三相电压表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4供应功率表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4乐清天康生产频率表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4乐清天康生产多功能表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4乐清天康生产数显功率因数表
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4天康电子生产电流变送器
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4天康电子生产电压变送器
XK-CD194I-2X4, XK-CD194I-3X4, XK-CD194I-AX4, XK-CD194I-DX4, XK-CD194I-9X4,XK-CD194I-2K4乐清天康专业生产数显单相电压表
