Proxitron(piros)°ØÎ÷ÌúÁú¹«Ë¾¨D¨D¨D¸ÖÌúÐÐҵרÓòúÆ·
¸ÖÌúÐÐҵרҵ²úÆ·£¬Ö÷ÒªÉú²úÆøÌåÁ÷Á¿²âÁ¿´«¸ÐÆ÷¡¢¸ßνӽü¿ª¹Ø¡¢ÈȽðÊô̽
²âÒÇ¡¢¸ÖÌúÐÐҵרÓúìÍâ²âÎÂÒÇ±í¡£²úÆ·¶ÀÒ»ÎÞ¶þ£¬Ä͸ßΡ¢¿Á¿ÌÄÜÁ¦ÒÔ¼°¼«¸ß
µÄÐÔÄܼ۸ñ±È,¹úÄÚÓй㷺µÄÓû§¡£
¸ßνӽü¿ª¹Ø£¬M18½ðÊôÍâ¿Ç£¬Ð¡µÄ¹¤×÷¾àÀë.ÒòΪÔöÇ¿ÐÍζȷ¶Î§£¬ËùÒÔ´«
¸ÐÆ÷Êʺϸßλ·¾³Ó¦Óá£80mm¹¤×÷¾àÀë
ÐͺÅIKB 080.38 G
Art.-No. 2485A
Rated operating distance (Sn) 80 mm
Output PNP n.o. + n.c.
Operating distance adjustable no
Target steel St37, 1 mm thick 240 x 240 mm
Location at metal non flush
Supply voltage (UB) 10 - 55 V DC
Ripple voltage < 15 %
Load current max. 0 - 400 mA
Short- time load current 0,8 A / 100 ms
2 A / 10 ms
Short circuit protection yes, pulsing
No-load current (I0) < 10 mA
Voltage drop (Ud) < 2 V
Operating frequency (f) 50 Hz
Switching hysteresis (H) 1 - 15 %
Ambient temperature -25 ... +70 ¡ãC
(without cooling)
Protection class IP 67
Connection 2 m POKT-Therm
cable up to +175 ¡ãC
(optional teflon cable
up to +260 ¡ãC)
Function display no
Housing material PTFE (Teflon) up
to +260 ¡ãC / brass
Water flow rate about 1l / min
