Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¼ÆÊýÆ÷ ¼ÆÃׯ÷ ¼ÆÊ±Æ÷GX7-P61E GX7-P41E GX7-P62E GX7-P42E
²úÆ·Ãû³Æ£º ¼ÆÊýÆ÷ ¼ÆÃׯ÷ ¼ÆÊ±Æ÷GX7-P61E GX7-P41E GX7-P62E GX7-P42E
ÐÍ ºÅ£º GX7-PϵÁÐ
Æ· ÅÆ£º HANYOUNG£¨º«ÈÙ£©
MODEL GX7-P
Appearance(©L) 72(W)¡Á72(H)¡Á112(D)
Sort Freeset
Control method Up, Down, Up/Down
Display digit 7Segment L.E.D , LED Height PV : 10©L, SV : 8©L
Stage 1stage, 2stage
Number of digits 4, 6 digits
Counting speed 30 / 1K / 3K / 5Kcps
Counting input Contact, Non-contact
Reset External reset : Min. input signal width 0.02sec
-------------- ( Contact, Non-contact input )
Power reset : Min. power opening time 0.5sec
Inhibit input Voltage input ( D.C input )
¡ºH¡»level 5 ~ 30VDC, ¡ºL¡»level 0 ~ 2VDC ( input resistance Approx. 4.7£¦#13248;)
Memory protection Semi-permanent
Power voltage 100 ~ 240VAC ( 50/60Hz )
Power consumption Approx. 5VA ( 220VAC 60Hz )
Supply power to sensor 12VDC 50mA Max
Control output Contact output : 1c 250VAC 3A ( resistance load )
Non-Contact output : 30VDC 100mA Max
Insulation resistance Min, £¦#13249; ( At 500VDC ) part of conduction terminal and exposured non-electrify metal part
Dielectric strength 2,000VAC 50/60Hz for 1minute
( Between + and - charging terminals )
Vibration Malfunction 2-55Hz, X, Y, Z, each positions for 10 minutes
Durability 10-55Hz, 0.76©L, X, Y, Z each positions for 2 hours
Shock Malfunction 100£¦#13224; 6 positions, Each 3 times
Durability 300£¦#13224; 6 positions, Each 3 times
Life Mechanical 10 millions operations Min ( Relay type )
Electrical 0.3 million operation Min. ( Relay type )
Ambient temperature and humidity 0~50¡æ(32~122¨H)£¦#12685;35~85%RH (No icing)
¹«Ë¾µØÖ·£ºÖÐɽÊÐ»ð¾æ¿ª·¢Çøå©Í·å©¶«»¨Ô°¶þÆÚ25¿¨
µç»°£¨TEL£©£º0760-3896378 ÊÖ»ú£º13528175992
´«Õ棨FAX£©£º0760-3896379
ÖÐɽÊÐÃúÔ¶×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ÊÇÒ»¼ÒרҵÏúÊÛ¸÷¹úµÍѹµçÆøºÍ´úÀíº«¹ú¹¤Òµ¿ØÖÆ×Ô¶¯»¯²úÆ·µÄÆóÒµ£¬ÎÒ¹«Ë¾±¾×Å¡°ÒÔ·þÎñΪ×ÚÖ¼£¬ÒÔ³ÏÐÅΪԭÔò£¬ÒÔ¿Í»§ÎªºËÐÄ£¬ÒÔÊг¡Îªµ¼Ïò¡±¡£Ö÷Òª´Óʹ¤Òµ×Ô¶¯»¯ÁìÓò²úÆ·µÄÍÆ¹ã¼°¼¼Êõ·þÎñ£¬ÖÂÁ¦ÓÚ¹¤Òµ×Ô¶¯»¯¿ØÖÆÁìÓò¡£
ÎÒ¹«Ë¾´úÀíµÄ¹¤Òµ¹¤¿Ø×Ô¶¯»¯¶àÖÖ²úÆ·¡¢¸÷ÖÖ¿ª¹Ø¡¢¼ÌµçÆ÷¡¢ÎÂ¿Ø±í¡¢Î¶ȿØÖÆÆ÷¡¢ÒÇÆ÷ÒÇ±í¡¢Ê±¼ä¼ÌµçÆ÷¡¢¹Ì̬¼Ìµç˳¡¢Ê±¼ä¼ÌµçÆ÷¡¢°´Å¥¿ª¹Ø¡¢×ª»»¿ª¹Ø¡¢Í¹ÂÖ¿ª¹Ø¡¢Í¬ÆÚ¿ª¹Ø¡¢Ñ¡Ôñ¿ª¹Ø¡¢ÍòÄÜת»»¿ª¹Ø¡¢Ìì³µ¿ª¹Ø¡¢¿ØÖÆ¿ª¹Ø¡¢µõ³µ¿ª¹Ø¡¢´øµÆ¼±Í£¿ª¹Ø¡¢½Å̤¿ª¹Ø¡¢Î¢¶¯¿ª¹Ø¡¢ÏÞλ¿ª¹Ø¡¢Ê®×Ö¿ª¹Ø¡¢·½Ïò¿ª¹Ø¡¢Ðгµ¿ª¹Ø¡¢ÍòÏò¿ª¹Ø¡¢ÒºÎ»¿ª¹Ø¡¢¿ÕÆø¿ª¹Ø¡¢¹âµç¿ª¹Ø¡¢½Ó½ü¿ª¹Ø¡¢Ìì³µ¿ª¹Ø¡¢¹âÏË¿ª¹Ø¡¢µçÔ´°´Å¥¿ª¹Ø¡¢Ðг̿ª¹Ø¡¢·À±¬¿ª¹Ø¡¢µçÔ´¿ª¹Ø¡¢¼±Í£¿ª¹Ø¡¢½Å̤µ÷ËÙÆ÷¡¢½Å̤¿ØÖÆÆ÷¡¢´«¸ÐÆ÷¡¢Ðźŵơ¢Ö¸Ê¾µÆ¡¢×éºÏ¹â×ÖÅÅ¡¢°´Å¥Ö¸Ê¾µÆ¡¢×éºÏָʾµÆ¡¢¾¯Ê¾µÆ¡¢¶à²ãÐźŵơ¢ËþµÆ¡¢²ãµÆ¡¢ÐýתÐźŵơ¢¶à²ã´øÉÁ¹âÐźŵơ¢¶àÖÖÉùÒô¶à²ãÐźŵơ¢±¨¾¯µÆ¡¢¶àÒô±¨¾¯Æ÷¡¢·À±¬Ðźŵơ¢·À±¬±¨¾¯µÆ¡¢·À±¬µÆ¡¢À®°ÈÐźŵơ¢Éù¹â±¨¾¯µÆ¡¢·À±¬Éù¹âÒ»Ì嵯¡¢Éù¹âÒ»ÌåÐýתµÆ¡¢·À±¬±¨¾¯Æ÷¡¢·äÃùÆ÷¡¢¶àÒô·äÃùÆ÷¡¢·À±¬·äÃùÆ÷¡¢·À±¬À®°È¡¢¶àÒôÀ®°È¡¢¼ÆÊýÆ÷¡¢¼ÆÊ±Æ÷¡¢±àÂëÆ÷¡¢Ðýת±àÂëÆ÷¡¢¹¤Òµ±àÂëÆ÷¡¢µçÁ÷±í¡¢µçѹ±í¡¢½Ó´¥Æ÷¡¢¼Ç¼Æ÷¡¢Êý×ÖÏÔʾÆ÷¡¢Êý×ÖÏÔʾÎÂ¿Ø±í¡¢¹¦ÂÊ¿ØÖÆÆ÷¡¢×éºÏ¿ª¹ØºÐ¡¢Ãܷ⿪¹ØºÐ¡¢¿É¿Ø¹è¹¦Âʵ÷ÕûÆ÷¡¢¶Ë×ÓÅÅ¡¢×éºÏ¶Ë×ÓÅÅ¡¢¹Ì¶¨¶Ë×ÓÅÅ¡¢¿ØÖÆÏä¡¢±ß½ÓÆ÷¡¢Ãæ°å±í¡¢×ªËټơ¢Êý×ÖתËÙ±í¡¢°´Å¥¿ª¹ØºÐ¡¢¹ý³ÌζȿØÖÆÆ÷¡¢ÓÐÖ½¼Ç¼ÒÇ£¬ÎÞÖ½¼Ç¼ÒÇ¡¢µç»ú±£»¤Æ÷¡¢Âí´ï±£»¤Æ÷µÈ
ÎÒ¹«Ë¾´úÀíÆ·ÅÆ£ºº«¹úÁúÉùµç»úÖêʽ»áÉç(YongSung Electric CO;ltd)´úÀí¡¢ HANYOUNG(º«ÈÙµç×Ó)¡¢AUTONICS(°ÂÍÐÄá¿Ë˹)¡¢KOINO(½¨ÐË)¡¢¿­À¥£¨KACON£©×Ô¶¯ÖÆÓùÓëÅäµçϵͳ ¡¢ YONGSUNG(º«¹úÁúÉù)¡¢Q.LIGHT(¿ËÀ³ÌØ-¾¯±¨µÆ¡¢Ðźŵơ¢²ãµÆ)¡¢EOCR(º«¹úÈýºÍµç»ú±£»¤Æ÷)¡¢ HEDSS(º£µÂ)Ðýת±àÂë¡¢WOONYOUNG(ÔÆÓÀ)¡¢ DAEYANG(´óÑó) ¡¢KWANGWOO(¹âÓî) TEND(̨ÍåÌìµÃµç»ú) ¡¢ OMRON(ÈÕ±¾Å·Ä·Áú) ¡¢ MOUJEN(̨ÍåïÈÊ) ¡¢ SICK(µÂ¹úÊ©¿Ë) ¡¢º«¹úKONICS ¡¢ÃÀ¹úHONEYWELL(»ôÄáΤ¶û) ¡¢ LGµÍѹµçÆ÷ ¡¢ SAMYOUNG(º«¹úÈýÈÙ) ¡¢ SUNHO(º«¹ú³ÉºÆ) ¡¢ ÈÕ±¾¸»Ê¿¡¢AP£¨Ì¨Í庺£© FOX(DAESUNGº«¹ú´ó³É) ¡¢ º«¹úFAS ¡¢ ÈÕ±¾SMCÆø¶¯ ¡¢ ̨ÍåHIWINÖ±Ïßµ¼¹ì ¡¢ ·¨¹ú¸ßŵ˹(Crouzet) ¡¢ ÈÕ±¾ºÍȪ(IDEC) ¡¢ÈýÁâ»úµç¡¢Î÷ÃÅ×Ó¡¢ ̨ÍåANLY(°²Á¼»úµç) ̨ÍåÆÕÄÍ¡¢ HIBOX(º«¹úº£²©¿ª¹ØºÐ/½ÓÏߺÐ)µÈ¶à¸öÆ·ÅÆ¡£È«·½Î»Îª¸÷ÆóÒµ·þÎñ£¡»¶Ó­ÁªÏµ¡£
¹«Ë¾Ãû³Æ£º ¹ã¶«ÖÐɽÊÐÃ÷ÑïΰҵµçÆøÓÐÏÞ¹«Ë¾
µç »°£º 0760 88332295 / ÑîÉ£
ÊÖ»ú£º 13528175992
µØ Ö·£º ¹ã¶«Ê¡ÖÐɽÊÐ»ð¾æ¿ª·¢Çø
ÓÊ ±à£º 528400
Ö÷ Ò³£º http://www.mygkong.com
  • KOINO½¨ÐËKH-2022£¬KH-3022£¨22£¬25mmͨÓÃϵÁУ©°´Å¥¿ª¹Ø£¬¼±Í£¿ª¹Ø£¬Ðýת¿ª¹Ø£¬Ñ¡Ôñ¿ª¹Ø
  • KOINO½¨ÐËKH-301£¬KH-302£¬KCR-303ϵÁÐÍòÄÜת»»¿ª¹Ø£¬Í¹ÂÖ¿ª¹Ø£¬Ô¿³×¿ª¹Ø£¬Ñ¡Ôñ¿ª¹Ø
  • KOINO½¨ÐËKPSϵÁйâµç´«¸ÐÆ÷£¬¹âÏË´«¸ÐÆ÷
  • KOINO½¨ÐËKH-702£¬KH-704£¬KH-706£¬KH-7062£¬KH-712/714/716ϵÁÐÐгµ¿ª¹Ø£¬Ìì³µ¿ª¹Ø£¬ÆðÖØ¿ª¹Ø
  • KOINO½¨ÐËKPX-D04£¬KPX-D08£¬KPX-D12£¬KPX-D18£¬KPX-D30£¬KPX-D17/D25/D30/D40ϵÁнӽü¿ª¹Ø£¬¹âµç¿ª¹Ø
  • KOINO½¨ÐËKH-5001£¬KH-5002£¬KH-500TL£¬KH-5020L£¬KH-5030L/L-T£¬KH-5040¹â×ÖÅÅ£¬×éºÏ¹â×ÖÅÅ
  • KOINO½¨ÐËKH-308£¬KH-3008£¬KH-3081/EB£¬KH-311ϵÁУ¨30mm£©°´Å¥¿ª¹Ø£¬Ñ¡Ôñ¿ª¹Ø£¬×ª»»¿ª¹Ø£¬Ô¿³×¿ª¹Ø£¬¼±Í£¿ª¹Ø
  • KOINO½¨ÐËKH-503£¬KH-504£¬KH-513£¬KH-514£¬KH-3030£¬KH-3040/3065EB/3066EBÔ¿³×¿ª¹Ø£¬³¬¼¶¼±Í£°´Å¥¿ª¹Ø£¬´øµÆ°´Å¥¿ª¹Ø
  • KOINO½¨ÐËKH-2201£¬KH-2201EB/ER£¬KH-2201S£¬KH-2202L/S£¬KH-2203£¬KH-2204/P/EB/ER¼±Í£°´Å¥¿ª¹Ø£¬´øµÆ°´Å¥¿ª¹Ø£¬Ñ¡Ôñ¿ª¹Ø
