MODEL DX9
Appearance (mm) 96(W)¡Á96(H)¡Á100(D)
Function PID Auto-tuning, Input correction function,
¡æ/¨H selectable, Alarm (ALH, ALL), Decimal point movable
Power voltage 100 - 240 VAC (50/60Hz)
Power consumption Max 15VA
Input Thermocouple (K,J,R), R.T.D (DIN/JIS Pt 100£¦#8486;),
£¦#13239; & £¦#13187;
Control output Current output : 4~20£¦#13187; DC (load resistance Max 600£¦#8486;),
Relay contact output : AC250V 3A (Resistive load),
SSR driving : 12V DC (Constant voltage pulse)
------------[Load resistance more than 800£¦#8486;]
Control action P.I.D (Auto-tuning funtion), ON/OFF, P£¦#12685;PI£¦#12685;PD
Alarm output Relay contact : AC250V 3A (AL-2, LBA), 3A(AL-1)
Loop Break Alarm Relay contact : AC250V 3A (Resistive load)
Setting by Up/Down key on the front
Display L.E.D Display (PV : Green, SV : Red)
PV : 14mm, SV : 10.5mm
Setting and display accuracy T/C : Within ¡À3¡æ(6¨H) [Whichever is larger],
R.Input : 0~199¡æ(0~390¨H) within ¡À5¡æ(10¨H),
R.T.D : Within ¡À2¡æ (3¨H) [Whichever is larger]
Memory pretection Semi-permanent
Dielectric strength AC 2,000V 50/60Hz for 1 minute
(Between terminal and earth)
Vibration Malfunction 2~55Hz, X, Y, Z each positions for 10 minutes
Durability 10~55Hz, 0.76mm, X, Y, Z each positions for 2 hours
Shock Malfunction 100£¦#13224; 6 positions, Each 3 tiems
Durability 300£¦#13224; 6 positions, Each 3 tiems
Life Malfunction Min. 10 millions times (Relay type)
Electrial Min. 0.3 million times
Ambient temperature and humidity 0~50¡æ(32~122¨H)£¦#12685;35~85%RH (No icing)
¹«Ë¾µØÖ·£ºÖÐɽÊÐ»ð¾æ¿ª·¢Çøå©Í·å©¶«»¨Ô°¶þÆÚ25¿¨
µç»°£¨TEL£©£º0760-3896378 ÊÖ»ú£º13528175992
´«Õ棨FAX£©£º0760-3896379
ÖÐɽÊÐÃúÔ¶×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ÊÇÒ»¼ÒרҵÏúÊÛ¸÷¹úµÍѹµçÆøºÍ´úÀíº«¹ú¹¤Òµ¿ØÖÆ×Ô¶¯»¯²úÆ·µÄÆóÒµ£¬ÎÒ¹«Ë¾±¾×Å¡°ÒÔ·þÎñΪ×ÚÖ¼£¬ÒÔ³ÏÐÅΪÔÔò£¬ÒÔ¿Í»§ÎªºËÐÄ£¬ÒÔÊг¡Îªµ¼Ïò¡±¡£Ö÷Òª´Óʹ¤Òµ×Ô¶¯»¯ÁìÓò²úÆ·µÄÍÆ¹ã¼°¼¼Êõ·þÎñ£¬ÖÂÁ¦ÓÚ¹¤Òµ×Ô¶¯»¯¿ØÖÆÁìÓò¡£
ÎÒ¹«Ë¾´úÀíµÄ¹¤Òµ¹¤¿Ø×Ô¶¯»¯¶àÖÖ²úÆ·¡¢¸÷ÖÖ¿ª¹Ø¡¢¼ÌµçÆ÷¡¢ÎÂ¿Ø±í¡¢Î¶ȿØÖÆÆ÷¡¢ÒÇÆ÷ÒÇ±í¡¢Ê±¼ä¼ÌµçÆ÷¡¢¹Ì̬¼Ìµç˳¡¢Ê±¼ä¼ÌµçÆ÷¡¢°´Å¥¿ª¹Ø¡¢×ª»»¿ª¹Ø¡¢Í¹ÂÖ¿ª¹Ø¡¢Í¬ÆÚ¿ª¹Ø¡¢Ñ¡Ôñ¿ª¹Ø¡¢ÍòÄÜת»»¿ª¹Ø¡¢Ìì³µ¿ª¹Ø¡¢¿ØÖÆ¿ª¹Ø¡¢µõ³µ¿ª¹Ø¡¢´øµÆ¼±Í£¿ª¹Ø¡¢½Å̤¿ª¹Ø¡¢Î¢¶¯¿ª¹Ø¡¢ÏÞλ¿ª¹Ø¡¢Ê®×Ö¿ª¹Ø¡¢·½Ïò¿ª¹Ø¡¢Ðгµ¿ª¹Ø¡¢ÍòÏò¿ª¹Ø¡¢ÒºÎ»¿ª¹Ø¡¢¿ÕÆø¿ª¹Ø¡¢¹âµç¿ª¹Ø¡¢½Ó½ü¿ª¹Ø¡¢Ìì³µ¿ª¹Ø¡¢¹âÏË¿ª¹Ø¡¢µçÔ´°´Å¥¿ª¹Ø¡¢Ðг̿ª¹Ø¡¢·À±¬¿ª¹Ø¡¢µçÔ´¿ª¹Ø¡¢¼±Í£¿ª¹Ø¡¢½Å̤µ÷ËÙÆ÷¡¢½Å̤¿ØÖÆÆ÷¡¢´«¸ÐÆ÷¡¢Ðźŵơ¢Ö¸Ê¾µÆ¡¢×éºÏ¹â×ÖÅÅ¡¢°´Å¥Ö¸Ê¾µÆ¡¢×éºÏָʾµÆ¡¢¾¯Ê¾µÆ¡¢¶à²ãÐźŵơ¢ËþµÆ¡¢²ãµÆ¡¢ÐýתÐźŵơ¢¶à²ã´øÉÁ¹âÐźŵơ¢¶àÖÖÉùÒô¶à²ãÐźŵơ¢±¨¾¯µÆ¡¢¶àÒô±¨¾¯Æ÷¡¢·À±¬Ðźŵơ¢·À±¬±¨¾¯µÆ¡¢·À±¬µÆ¡¢À®°ÈÐźŵơ¢Éù¹â±¨¾¯µÆ¡¢·À±¬Éù¹âÒ»Ì嵯¡¢Éù¹âÒ»ÌåÐýתµÆ¡¢·À±¬±¨¾¯Æ÷¡¢·äÃùÆ÷¡¢¶àÒô·äÃùÆ÷¡¢·À±¬·äÃùÆ÷¡¢·À±¬À®°È¡¢¶àÒôÀ®°È¡¢¼ÆÊýÆ÷¡¢¼ÆÊ±Æ÷¡¢±àÂëÆ÷¡¢Ðýת±àÂëÆ÷¡¢¹¤Òµ±àÂëÆ÷¡¢µçÁ÷±í¡¢µçѹ±í¡¢½Ó´¥Æ÷¡¢¼Ç¼Æ÷¡¢Êý×ÖÏÔʾÆ÷¡¢Êý×ÖÏÔʾÎÂ¿Ø±í¡¢¹¦ÂÊ¿ØÖÆÆ÷¡¢×éºÏ¿ª¹ØºÐ¡¢Ãܷ⿪¹ØºÐ¡¢¿É¿Ø¹è¹¦Âʵ÷ÕûÆ÷¡¢¶Ë×ÓÅÅ¡¢×éºÏ¶Ë×ÓÅÅ¡¢¹Ì¶¨¶Ë×ÓÅÅ¡¢¿ØÖÆÏä¡¢±ß½ÓÆ÷¡¢Ãæ°å±í¡¢×ªËټơ¢Êý×ÖתËÙ±í¡¢°´Å¥¿ª¹ØºÐ¡¢¹ý³ÌζȿØÖÆÆ÷¡¢ÓÐÖ½¼Ç¼ÒÇ£¬ÎÞÖ½¼Ç¼ÒÇ¡¢µç»ú±£»¤Æ÷¡¢Âí´ï±£»¤Æ÷µÈ
ÎÒ¹«Ë¾´úÀíÆ·ÅÆ£ºº«¹úÁúÉùµç»úÖêʽ»áÉç(YongSung Electric CO;ltd)´úÀí¡¢ HANYOUNG(º«ÈÙµç×Ó)¡¢AUTONICS(°ÂÍÐÄá¿Ë˹)¡¢KOINO(½¨ÐË)¡¢¿À¥£¨KACON£©×Ô¶¯ÖÆÓùÓëÅäµçϵͳ ¡¢ YONGSUNG(º«¹úÁúÉù)¡¢Q.LIGHT(¿ËÀ³ÌØ-¾¯±¨µÆ¡¢Ðźŵơ¢²ãµÆ)¡¢EOCR(º«¹úÈýºÍµç»ú±£»¤Æ÷)¡¢ HEDSS(º£µÂ)Ðýת±àÂë¡¢WOONYOUNG(ÔÆÓÀ)¡¢ DAEYANG(´óÑó) ¡¢KWANGWOO(¹âÓî) TEND(̨ÍåÌìµÃµç»ú) ¡¢ OMRON(ÈÕ±¾Å·Ä·Áú) ¡¢ MOUJEN(̨ÍåïÈÊ) ¡¢ SICK(µÂ¹úÊ©¿Ë) ¡¢º«¹úKONICS ¡¢ÃÀ¹úHONEYWELL(»ôÄáΤ¶û) ¡¢ LGµÍѹµçÆ÷ ¡¢ SAMYOUNG(º«¹úÈýÈÙ) ¡¢ SUNHO(º«¹ú³ÉºÆ) ¡¢ ÈÕ±¾¸»Ê¿¡¢AP£¨Ì¨Í庺£© FOX(DAESUNGº«¹ú´ó³É) ¡¢ º«¹úFAS ¡¢ ÈÕ±¾SMCÆø¶¯ ¡¢ ̨ÍåHIWINÖ±Ïßµ¼¹ì ¡¢ ·¨¹ú¸ßŵ˹(Crouzet) ¡¢ ÈÕ±¾ºÍȪ(IDEC) ¡¢ÈýÁâ»úµç¡¢Î÷ÃÅ×Ó¡¢ ̨ÍåANLY(°²Á¼»úµç) ̨ÍåÆÕÄÍ¡¢ HIBOX(º«¹úº£²©¿ª¹ØºÐ/½ÓÏߺÐ)µÈ¶à¸öÆ·ÅÆ¡£È«·½Î»Îª¸÷ÆóÒµ·þÎñ£¡»¶ÓÁªÏµ¡£
