AR823|Êý×ÖʽÕնȼÆ|¹âÕÕ¼Æ|ÕÕ¶ÈÒÇ|¹â¶È¼ÆAR823 AR823|Êý×ÖʽÕնȼÆ|¹âÕÕ¼Æ|ÕÕ¶ÈÒÇ|¹â¶È¼ÆAR823µÄÏêϸ½éÉÜ AR-823|Êý×ÖʽÕնȼÆ|¹âÕÕ¼Æ|ÕÕ¶ÈÒÇ|¹â¶È¼Æ|µÄÏêϸ½éÉÜ GENERAL FEATURES & SPECIFICATIONS Ò»°ã¹¦Äܺ͹æ¸ñ AR-813 AR-833 AR-823 Measuring Range 1¡«100,000lux 0.01¡«50,000lux 1¡«100,000lux ²âÁ¿·¶Î§ Accuracy <4%rgd¡À0.5%f.s <3%rgd¡À0.5%f.s <3%rgd¡À0.5%f.s ²âÁ¿¾«È·¶È Unit Selection Lux Lux Lux/Fc µ¥Î»×ª»» Measure Level Seletion Auto Auto Auto/MANUAL ²âÁ¿µµÎ»Ñ¡Ôñ Data Hold Function ¡Ì ¡Ì ¡Ì Êý¾Ý±£³ÖÏÔʾ¹¦ÄÜ Auto Power Shut Off ¡Ì ¡Ì ¡Ì ×Ô¶¯¹Ø»ú¹¦ÄÜ Low Battery Indication ¡Ì ¡Ì ¡Ì µÍµçÏÔʾ¹¦ÄÜ LCD Back Light Selection _______ _____ ¡Ì ±³¹âÏÔʾѡÔñ¹¦ÄÜ Repeatability ¡À2% ¡À2% ¡À2% ÖØ¸´ÐÔ The Change As Temperature Change 0.1%/¡æ 0.1%/¡æ 0.1%/¡æ ζÈÌØÐÔ Samping Frequency 1.5times/sec 1.5times/sec 1.5times/sec È¡ÑùÂÊ Resolution 1Lux 0.01¡«1Lux 1Lux ½âÎö¶È Response Time 1s 1s 1s ÏìӦʱ¼ä Over level Indication ¡Ì ¡Ì ¡Ì ¹ýÔØÌáʾ Max And MinReading Hold Function ____ ____ ¡Ì ×î´ó¡¢×îÐ¡ÖµËø¶¨¹¦ÄÜ GENERAL CHARACTERISTICS Ò»°ãÌØÕ÷ Power 9v Battery 9v Battery 9v Battery ¹©µç 9vµç³Ø 9vµç³Ø 9vµç³Ø LCD size 48*31.8mm 48*31.8mm 59.0*51.0mm LCD³ß´ç Product Color Dark Gray+black balck+yellow Dark Gray ²úÆ·ÑÕÉ« Éî»Ò+ºÚ ºÚ+»Æ Éî»Ò Product Net Weight 116.5g 116.5g 209.0g ²úÆ·¾»ÖØ Product Size 166.2*64.0*30.5mm 166.2*64.0*30.5mm 151*83*26.5mm ²úÆ·³ß´ç PACKING INFORMATION °ü×° °ü×°·½Ê½1(Öйú) ²ÊºÐ ²ÊºÐ ²ÊºÐ ±ê×¼ÍâÏäÈÝÁ¿ 40 40 40 ±ê×¼ÍâÏä³ß´ç 45.5*44.8*40.5cm 45.5*44.8*40.5cm 55.0*45.0*32.5cm ±ê×¼ÍâÏäÃ«ÖØ 9.85kg 9.85kg 14.7kg °ü×°·½Ê½2(Other Countries) Blister Blister Blister Standard Quantity Per Carton 40 40 40 Standard Carton Size 36.8*36.8*25.7cm 36.8*36.8*25.7cm 37.1*36.5*28.0cm Standard Carton Gross Weight 11.84kg 11.84kg 6.48kg
