AR813|Êý×ÖʽÕնȼÆ|¹âÕÕ¼Æ|ÕÕ¶ÈÒÇ|¹â¶È¼Æ AR813
AR813|Êý×ÖʽÕնȼÆ|¹âÕÕ¼Æ|ÕÕ¶ÈÒÇ|¹â¶È¼Æ AR813µÄÏêϸ½éÉÜ
AR813|Êý×ÖʽÕնȼÆ|¹âÕÕ¼Æ|ÕÕ¶ÈÒÇ|¹â¶È¼Æ|µÄÏêϸ½éÉÜ
GENERAL FEATURES & SPECIFICATIONS Ò»°ã¹¦Äܺ͹æ¸ñ
AR-813 AR-833 AR-823
Measuring Range 1¡«100,000lux 0.01¡«50,000lux 1¡«100,000lux
²âÁ¿·¶Î§
Accuracy <4%rgd¡À0.5%f.s <3%rgd¡À0.5%f.s <3%rgd¡À0.5%f.s
²âÁ¿¾«È·¶È
Unit Selection Lux Lux Lux/Fc
µ¥Î»×ª»»
Measure Level Seletion Auto Auto Auto/MANUAL
²âÁ¿µµÎ»Ñ¡Ôñ
Data Hold Function ¡Ì ¡Ì ¡Ì
Êý¾Ý±£³ÖÏÔʾ¹¦ÄÜ
Auto Power Shut Off ¡Ì ¡Ì ¡Ì
×Ô¶¯¹Ø»ú¹¦ÄÜ
Low Battery Indication ¡Ì ¡Ì ¡Ì
µÍµçÏÔʾ¹¦ÄÜ
LCD Back Light Selection _______ _____ ¡Ì
±³¹âÏÔʾѡÔñ¹¦ÄÜ
Repeatability ¡À2% ¡À2% ¡À2%
ÖØ¸´ÐÔ
The Change As Temperature Change 0.1%/¡æ 0.1%/¡æ 0.1%/¡æ
ζÈÌØÐÔ
Samping Frequency 1.5times/sec 1.5times/sec 1.5times/sec
È¡ÑùÂÊ
Resolution 1Lux 0.01¡«1Lux 1Lux
½âÎö¶È
Response Time 1s 1s 1s
ÏìӦʱ¼ä
Over level Indication ¡Ì ¡Ì ¡Ì
¹ýÔØÌáʾ
Max And MinReading Hold Function ____ ____ ¡Ì
×î´ó¡¢×îÐ¡ÖµËø¶¨¹¦ÄÜ
GENERAL CHARACTERISTICS Ò»°ãÌØÕ÷
Power 9v Battery 9v Battery 9v Battery
¹©µç 9vµç³Ø 9vµç³Ø 9vµç³Ø
LCD size 48*31.8mm 48*31.8mm 59.0*51.0mm
LCD³ß´ç
Product Color Dark Gray+black balck+yellow Dark Gray
²úÆ·ÑÕÉ« Éî»Ò+ºÚ ºÚ+»Æ Éî»Ò
Product Net Weight 116.5g 116.5g 209.0g
²úÆ·¾»ÖØ
Product Size 166.2*64.0*30.5mm 166.2*64.0*30.5mm 151*83*26.5mm
²úÆ·³ß´ç
PACKING INFORMATION °ü×°
°ü×°·½Ê½1(Öйú) ²ÊºÐ ²ÊºÐ ²ÊºÐ
±ê×¼ÍâÏäÈÝÁ¿ 40 40 40
±ê×¼ÍâÏä³ß´ç 45.5*44.8*40.5cm 45.5*44.8*40.5cm 55.0*45.0*32.5cm
±ê×¼ÍâÏäÃ«ÖØ 9.85kg 9.85kg 14.7kg
°ü×°·½Ê½2(Other Countries) Blister Blister Blister
Standard Quantity Per Carton 40 40 40
Standard Carton Size 36.8*36.8*25.7cm 36.8*36.8*25.7cm 37.1*36.5*28.0cm
Standard Carton Gross Weight 11.84kg 11.84kg 6.48kg
