Description ¸ÅÊö:
MAX481¡¢MAX483¡¢MAX485¡¢MAX487¡¢MAX488, MAX489, MAX490, MAX491ÒÔ¼°MAX1487ÊÇÓÃÓÚRS-485ÓëRS-422ͨÐŵĵ͹¦ºÄÊÕ·¢Æ÷£¬Ã¿¸öÆ÷¼þÖж¼¾ßÓÐÒ»¸öÇý¶¯Æ÷ºÍÒ»¸ö½ÓÊÕÆ÷¡£MAX483¡¢MAX487¡¢MAX488ÒÔ¼°MAX489¾ßÓÐÏÞ°ÚÂÊÇý¶¯Æ÷£¬¿ÉÒÔ¼õСEMI£¬²¢½µµÍÓɲ»Ç¡µ±µÄÖÕ¶ËÆ¥ÅäµçÀÂÒýÆðµÄ·´É䣬ʵÏÖ×î¸ß250kbpsµÄÎÞ²î´íÊý¾Ý´«Êä¡£MAX481¡¢MAX485¡¢MAX490¡¢MAX491¡¢MAX1487µÄÇý¶¯Æ÷°ÚÂʲ»ÊÜÏÞÖÆ£¬¿ÉÒÔʵÏÖ×î¸ß2.5MbpsµÄ´«ÊäËÙÂÊ¡£
ÕâЩÊÕ·¢Æ÷ÔÚÇý¶¯Æ÷½ûÓõĿÕÔØ»òÂúÔØ×´Ì¬Ï£¬ÎüÈ¡µÄµçÔ´µçÁ÷ÔÚ120µAÖÁ500µAÖ®¼ä¡£ÁíÍ⣬MAX481¡¢MAX483ÓëMAX487¾ßÓе͵çÁ÷¹Ø¶Ïģʽ£¬½öÏûºÄ0.1µA¡£ËùÓÐÆ÷¼þ¶¼¹¤×÷ÔÚ5Vµ¥µçÔ´Ï¡£
Çý¶¯Æ÷¾ßÓжÌ·µçÁ÷ÏÞÖÆ£¬²¢¿ÉÒÔͨ¹ýÈȹضϵç·½«Çý¶¯Æ÷Êä³öÖÃΪ¸ß×è״̬£¬·ÀÖ¹¹ý¶ÈµÄ¹¦ÂÊËðºÄ¡£½ÓÊÕÆ÷ÊäÈë¾ßÓÐʧЧ±£»¤ÌØÐÔ£¬µ±ÊäÈ뿪·ʱ£¬¿ÉÒÔÈ·±£Âß¼¸ßµçƽÊä³ö¡£
MAX487ÓëMAX1487¾ßÓÐ1/4µ¥Î»¸ºÔصĽÓÊÕÆ÷ÊäÈë×迹£¬Ê¹µÃ×ÜÏßÉÏ×î¶à¿ÉÒÔÓÐ128¸öMAX487/MAX1487ÊÕ·¢Æ÷¡£Ê¹ÓÃMAX488, MAX489, MAX490, MAX491¿ÉÒÔʵÏÖȫ˫¹¤Í¨ÐÅ£¬¶øMAX481¡¢MAX483¡¢MAX485¡¢MAX487ÓëMAX1487ÔòΪ°ëË«¹¤Ó¦ÓÃÉè¼Æ¡£
The MAX481, MAX483, MAX485, MAX487¡¢MAX488, MAX489, MAX490, MAX491, and MAX1487 are low-power transceivers for RS-485 and RS- 422 communication. Each part contains one driver and one receiver. The MAX483, MAX487, MAX488, and MAX489 feature reduced slew-rate drivers that minimize EMI and reduce reflections caused by improperly terminated cables, thus allowing error-free data transmission up to 250kbps. The driver slew rates of the MAX481, MAX485, MAX490, MAX491, and MAX1487 are not limited, allowing them to transmit up to 2.5Mbps.
These transceivers draw between 120µA and 500µA of supply current when unloaded or fully loaded with disabled drivers. Additionally, the MAX481, MAX483, and MAX487 have a low-current shutdown mode in which they consume only 0.1µA. All parts operate from a single 5V supply.
Drivers are short-circuit current limited and are protected against excessive power dissipation by thermal shutdown circuitry that places the driver outputs into a high-impedance state. The receiver input has a fail-safe feature that guarantees a logic-high output if the input is open circuit.
The MAX487 and MAX1487 feature quarter-unit-load receiver input impedance, allowing up to 128 MAX487/ MAX1487 transceivers on the bus. Full-duplex communications are obtained using the MAX488-MAX491, while the MAX481, MAX483, MAX485, MAX487, and MAX1487 are designed for half-duplex applications.
Key Features ¹Ø¼üÌØÐÔ
ÈÝ´íÓ¦ÓÃMAX3430: ¡À80V¹ÊÕϱ£»¤¡¢Ê§Ð§±£»¤¡¢1/4µ¥Î»¸ºÔØ¡¢+3.3V¡¢RS-485ÊÕ·¢Æ÷ MAX3440E-MAX3444E: ¡À15kV ESD±£»¤¡¢¡À60V¹ÊÕϱ£»¤¡¢10Mbps¡¢Ê§Ð§±£»¤¡¢RS-485/J1708ÊÕ·¢Æ÷
¶ÔÓÚ¿Õ¼äÊÜÏÞÓ¦ÓÃMAX3460-MAX3464: +5V¡¢Ê§Ð§±£»¤¡¢20Mbps¡¢Profibus RS-485/RS-422ÊÕ·¢Æ÷ MAX3362: +3.3V¡¢¸ßËÙ¡¢RS-485/RS-422ÊÕ·¢Æ÷£¬²ÉÓÃSOT23·â×° MAX3280E-MAX3284E: ¡À15kV ESD±£»¤¡¢52Mbps¡¢+3VÖÁ+5.5V¡¢SOT23¡¢RS-485/RS-422¡¢ÕæÊ§Ð§±£»¤½ÓÊÕÆ÷ MAX3293/MAX3294/MAX3295: 20Mbps¡¢+3.3V¡¢SOT23¡¢RS-485/RS-422·¢ËÍÆ÷
¶ÔÓÚ¶àͨµÀÊÕ·¢Æ÷Ó¦ÓÃMAX3030E-MAX3033E: ¡À15kV ESD±£»¤¡¢+3.3V¡¢ËÄ·RS-422·¢ËÍÆ÷
¶ÔÓÚʧЧ±£»¤Ó¦ÓÃMAX3080-MAX3089: ʧЧ±£»¤¡¢¸ßËÙ(10Mbps)¡¢ÏÞ°ÚÂÊRS-485/RS-422ÊÕ·¢Æ÷
¶ÔÓڵ͵çѹӦÓÃMAX3483E/MAX3485E/MAX3486E/MAX3488E/MAX3490E/MAX3491E: +3.3V¹©µç¡¢¡À15kV ESD±£»¤¡¢12Mbps¡¢ÏÞ°ÚÂÊ¡¢ÕæÕýµÄRS-485/RS-422ÊÕ·¢Æ÷
For Fault-Tolerant Applications MAX3430: ¡À80V Fault-Protected, Fail-Safe, 1/4 Unit Load, +3.3V, RS-485 Transceiver MAX3440E-MAX3444E: ¡À15kV ESD-Protected, ¡À60V Fault-Protected, 10Mbps, Fail-Safe, RS-485/J1708 Transceivers
For Space-Constrained Applications MAX3460-MAX3464: +5V, Fail-Safe, 20Mbps, Profibus RS-485/RS-422 Transceivers MAX3362: +3.3V, High-Speed, RS-485/RS-422 Transceiver in a SOT23 Package MAX3280E-MAX3284E: ¡À15kV ESD-Protected, 52Mbps, +3V to +5.5V, SOT23, RS-485/RS-422, True Fail-Safe Receivers MAX3293/MAX3294/MAX3295: 20Mbps, +3.3V, SOT23, RS-855/RS-422 Transmitters
For Multiple Transceiver Applications MAX3030E-MAX3033E: ¡À15kV ESD-Protected, +3.3V, Quad RS-422 Transmitters
For Fail-Safe Applications MAX3080-MAX3089: Fail-Safe, High-Speed (10Mbps), Slew-Rate-Limited RS-485/RS-422 Transceivers
For Low-Voltage Applications MAX3483E/MAX3485E/MAX3486E/MAX3488E/ MAX3490E/MAX3491E: +3.3V Powered, ¡À15kV ESD-Protected, 12Mbps, Slew-Rate-Limited, True RS-485/RS-422 Transceivers
Ó¦ÓÃ:
¹¤Òµ¿ØÖƾÖÓòÍø; µçƽת»»Æ÷;µÍ¹¦ºÄRS-422ÊÕ·¢Æ÷;µÍ¹¦ºÄRS-485ÊÕ·¢Æ÷;ÓÃÓÚEMIÃô¸ÐÓ¦ÓõÄÊÕ·¢Æ÷
µÍ¹¦ºÄ¡¢ÏÞ°ÚÂÊ¡¢RS-485/RS-422ÊÕ·¢Æ÷¡£¶©¹ºÐͺţºMAX485MJA MAX485C MAX485D MAX485CPA+ MAX485CPA MAX485EPA+ MAX485EPA MAX485CSA+T MAX485CSA+ MAX485CSA MAX485CSA-T MAX485ESA+T MAX485ESA+ MAX485ESA MAX485ESA-T MAX485CUA MAX485CUA-T MAX485CUA+ MAX485CUA+T MAX1487C MAX1487D MAX1487CPA+ MAX1487CPA MAX1487EPA+ MAX1487EPA MAX1487CSA MAX1487CSA-T MAX1487CSA+ MAX1487CSA+T MAX1487ESA+T MAX1487ESA+ MAX1487ESA-T MAX1487ESA MAX1487CUA-T MAX1487CUA MAX1487CUA+ MAX1487CUA+T MAX481MJA MAX481C MAX481CD MAX481CPA MAX481CPA+ MAX481EPA+ MAX481EPA MAX481CSA+T MAX481CSA MAX481CSA-T MAX481CSA+ MAX481ESA+T MAX481ESA+ MAX481ESA-T MAX481ESA MAX481CUA MAX481CUA-T MAX483MJA MAX483C MAX483CD MAX483CPA+ MAX483CPA MAX483EPA+ MAX483EPA MAX483CSA MAX483CSA+T MAX483CSA+ MAX483CSA-T MAX483ESA-T MAX483ESA MAX483ESA+ MAX483ESA+T MAX483CUA-T MAX483CUA MAX483CUA+ MAX483CUA+T MAX488MJA MAX488C MAX488D MAX488CPA+ MAX488CPA MAX488EPA+ MAX488EPA MAX488CSA MAX488CSA+T MAX488CSA+ MAX488CSA-T MAX488ESA-T MAX488ESA MAX488ESA+ MAX488ESA+T MAX488CUA-T MAX488CUA MAX488CUA+ MAX488CUA+T MAX489MJD MAX489C/D MAX489CPD+ MAX489CPD MAX489EPD+ MAX489EPD MAX489CSD+T MAX489CSD+ MAX489CSD MAX489CSD-T MAX489ESD+T MAX489ESD-T MAX489ESD MAX489ESD+ MAX490MJA MAX490C/D MAX490CPA+ MAX490CPA MAX490EPA+ MAX490EPA MAX490CSA+T MAX490CSA+ MAX490CSA MAX490CSA-T MAX490ESA+T MAX490ESA+ MAX490ESA-T MAX490ESA MAX490CUA+ MAX490CUA MAX490CUA-T MAX490CUA+T MAX491MJD MAX491C MAX491D MAX491CPD+ MAX491CPD MAX491EPD+ MAX491EPD MAX491CSD+T MAX491CSD+ MAX491CSD-T MAX491CSD MAX491ESD-T MAX491ESD MAX491ESD+ MAX491ESD+T
