µÂ¹úCOAX·§ µç´Å·§ ͬÖá·§ µÂ¹úCO-AX¹«Ë¾³ÉÁ¢ÓÚ1960Ä꣬ÒÔÉú²úͬÖá·§Öø³Æ£¬Æ¾½è·á¸»µÄ¾Ñ飬¿É¿¿¶ø¾¹ýÑϸñ²âÊԵIJÄÖÊ£¬¹ýÓ²µÄÖÊÁ¿¹ÜÀí£¬CO-AXµÄ·§¹ã·ºÊÊÓÃÓÚÕæ¿Õ¡¢ÆøÌ¬¡¢ÒºÌ¬¡¢½º×´¡¢Ä¥Á£¡¢ÎÛȾÐÔÒÔ¼°ÇÖÊ´ÐԵȸ÷ÖÖ½éÖÊ¡£Óë³£¹æ·§Ïà±È£¬Í¬Öá·§Äܹ»ÒÔ¸ßÁ÷Á¿À´¿ØÖƸßѹ½éÖÊ£¬ÓÐÁ½Î»Á½Í¨ºÍÈýλÁ½Í¨¿ÉÑ¡£¬Á¬½Ó·½Ê½ÔÊÐíÂÝÎÆÁ¬½ÓºÍ·¨À¼Á¬½Ó£¬¿Éͨ¹ýÖ±¶¯Ê½ÂÝÏ߹ܺÍÍⲿֱ½Ó¿ØÖÆ¡£ µÂ¹úCO-AXͬÖá·§ÆäÓÅÔ½ÐÔÖ÷ÒªÌåÏÖÔÚ£º high cycle life ʹÓÃÊÙÃü³¤ fast actuation ¿ìËÙÖ´ÐÐ compact design Éè¼Æ½ô´Õ maintenance free Ãâά»¤ bi-directional flow ¿ÉË«ÏòÁ÷¶¯ pressure balanced ѹÁ¦Æ½ºâ back pressure tight ±³Ñ¹ÃÜ·â installation position optional ¿Éѡʽ°²×°Î»Öà valves operate from 0 bar upward ´ÓÁãѹÏòÉϲÙ×÷ application with contaminated media ¿ÉÊÊÓÃÓÚÎÛȾÐÔ½éÖÊ Æä²úÆ·Ö÷ÒªÈçÏ 2/2 WAY DIRECT ACTING¡ªÁ½Î»Á½Í¨Ö±¶¯Ê½ ¿×¾¶ DIN10-80 £¬Ñ¹Á¦·¶Î§ 0-1500PSI£¬ÂÝÎÆ»ò·¨À¼Á¬½Ó£¬IP65·À»¤£¬¹¤×÷µçѹ24VDC£¬110VAC£¬230VAC£» 3/2 WAY DIRECT ACTING¡ªÈýλÁ½Í¨Ö±¶¯Ê½ ¿×¾¶ DIN10-80 £¬Ñ¹Á¦·¶Î§ 0-600PSI£¬ÂÝÎÆ»ò·¨À¼Á¬½Ó£¬IP65·À»¤£¬¹¤×÷µçѹ24VDC£¬110VAC£¬230VAC£» 2/2 WAY EXTERNALLY CONTROLLED¡ªÁ½Î»Á½Í¨Íⲿ¿ØÖÆÐÍ ¿×¾¶ DIN10-250 £¬Ñ¹Á¦·¶Î§ 0-1500PSI£¬ ÃÜ·â²ÄÁÏNBR, PTFE, FPM, PU, PE, CR, EPDM£» 3/2 WAY EXTERNALLY CONTROLLED¡ªÈýλÁ½Í¨Íⲿ¿ØÖÆÐÍ ¿×¾¶ DIN10-250 £¬Ñ¹Á¦·¶Î§ 0-1500PSI£¬ ·§Ìå²ÄÖÊÂÁ¡¢»ÆÍ¡¢¶ÆÐ¿¸Ö¡¢¶ÆÄø»ÆÍ¡¢¶ÆÄø¸Ö£» CERTIFICATED VALVES¡ªÐ£Ñé·§ ¿×¾¶ DIN15-75 £¬Ñ¹Á¦·¶Î§ 0-600PSI£¬ ·§Ìå²ÄÖʶÆÐ¿¸Ö£¬³£±Õ£» CARTRIDGE VALVES¡ª²å×°·§ ¿×¾¶ DIN10-15 £¬Ñ¹Á¦·¶Î§ 0-3000PSI£¬ÃÜ·â²ÄÖÊPU, NBR, PTFE, PE, FPM, EPDM, HNBR£¬³£¿ª»ò³£±Õ£» LATERAL VALVES¡ªÅÔ··§ ¿×¾¶ DIN15-50 £¬Ñ¹Á¦·¶Î§ 0-150PSI£¬ÂÝÎÆÁ¬½Ó£» HIGH PRESSURE VALVES COAXIAL¡ª¸ßѹͬÖá·§ A45-¿×¾¶ DIN2-6 £¬Ñ¹Á¦·¶Î§ 0-1950PSI£» KB-¿×¾¶ DIN2-14 £¬Ñ¹Á¦·¶Î§ 0-6000PSI£»MCF-H-¿×¾¶ DIN8 £¬Ñ¹Á¦·¶Î§ 0-2400PSI£»VMK-H/VFK-H-¿×¾¶ DIN15-50 £¬Ñ¹Á¦·¶Î§ 0-3000PSI£» HIGH PRESSURE VALVES LATERAL¡ª¸ßѹÅÔ··§ ECD-H-¿×¾¶ DIN10 £¬Ñ¹Á¦·¶Î§ 0-3000PSI£» ECD-H DR-¿×¾¶ DIN10 £¬Ñ¹Á¦·¶Î§ 0-2250PSI£»KBS-¿×¾¶ DIN1.5-3 £¬Ñ¹Á¦·¶Î§ 0-7500PSI£» MODULES¡ª·§×é MK-¿×¾¶ DIN10-25 £¬Ñ¹Á¦·¶Î§ 0-1500PSI£»VMK-¿×¾¶ DIN10-32 £¬Ñ¹Á¦·¶Î§ 0-1500PSI£»PCD¡¢PCS-¿×¾¶ DIN10-15 £¬Ñ¹Á¦·¶Î§ 0-3000PSI£»ÂÝÎÆÁ¬½Ó£» PRESSURE CONTROL VALVE¡ªÑ¹Á¦¿ØÖÆ·§ HPB¡¢SPB-¿×¾¶ DIN8-65 £¬Ñ¹Á¦·¶Î§ 0-3000PSI£¬IP65£» FLOW CONTROL VALVE¡ªÁ÷Á¿¿ØÖÆ·§ RMQ¿×¾¶ DIN1-32 £¬Ñ¹Á¦·¶Î§ 0-960PSI£¬ÂÝÎÆÁ¬½Ó£¬¶î¶¨µçѹAC/DC24V£»
