Form Factor |
Mini-ITX Motherboard (170 x 170 mm) |
Processor |
Intel Core 2 Quad/Core 2 Duo Desktop / Pentium D / Pentium 4 LGA775 533/800/1066 FSB.( Don''''''''''''''''t support Intel® Pentium® Processor Extreme Edition ) |
Memory |
2 x DDR2 533/667/800 MHz support up to 3.0 GB |
Chipset |
Intel Q965 & ICH8DO Chipset |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode ATX PSU |
VGA Interface |
Intel Q965 integrated GMA 3000 Technology |
DVI / LVDS Interface |
Optional DVI or LVDS interface |
Video Memory |
Up to 384MB shared with system memory |
Serial ATA Interface |
6 x Serial ATA II Interface with 300MB/s transfer rate Support RAID 0,1,5,10 function |
Audio Interface |
Intel ICH8DO integrated with Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel 82573L Gigabit Ethernet Controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x PCI slot & 1 x Min-PCI socket |
External I/O Port |
2 x RJ45 LAN port, 1x DB15 VGA port,1x PS/2 Keyboard / Mouse ports 1x RS232 Serial port , 2 x IEEE1394 ports, 4 x USB 2.0 ports , 1 x SPDIF , HD Audio ports |
Internal I/O Port |
1 x slim FDD, 1 x IrDA , 2 x USB 2.0 , 1 x Audio , 1 x CDIN
1 x Inverter( Optional ) , 1 x LVDS ( Optional ) ,
1 x DVI ( Optional ) , 1 x RS232/422/485 |
Power Requirement |
Standard 24-pin ATX power supply and P4 4-pin 12V . ( 20-pin is compatible) |
Board Dimension |
170mm x 170 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
